Member postings for speelwerk
Here is a list of all the postings speelwerk has made in our forums. Click on a thread name to jump to the thread.
Thread: 1/6" x 28tpi tap & die.
16/08/2017 18:57:20
Phil, thank you for your offer but I have that one with corresponding die. I did consider going to M5 but the washer only had a bore of 4.6 mm, and being made from that very hard and brittle material are not easy enlarged. Niko.
16/08/2017 14:44:31
OK, not the greatest engineering event making 10 screws of 1/6" x 28, but musical box restoration is much donkey work before it gets interesting, on the rigth is one of the damaged original screws. Asked a quote for a special made die, if they give it will I let it know. Niko.
13/08/2017 11:25:05
Yes Phil, those are the comb screws, you would like to keep it as original as possible but they can have had a hard live giving you no other option then to make slightly larger sized ones. The 0.32 & 0.38 mm module is another of those problems, you can try this one **LINK** . I use a 19th century rounding-up machine and cutters to make it mesh the other gear in the governor. It goes a little over 0.40 mm modern module but the Swiss must also have had rounding-up machines for large size wheels, but sofar never found one. I think your loft will look similar to mine. Niko.
Edited By speelwerk on 13/08/2017 11:26:01
Edited By speelwerk on 13/08/2017 11:27:22
12/08/2017 22:34:47
Thanks for the help, however it is a full form thread. Niko.
12/08/2017 21:16:03
It must be some kind of Swiss size from 1870. It is used much in musical boxes from that period. Many times the thread on the screw is gone and I have to thread cut new ones which takes too much time or use an oversize which is not ideal. Niko.
12/08/2017 20:56:23
Posted by JasonB on 12/08/2017 20:51:49:
Do you mean 1/4" x 28 as that would be UNF?
No, I am looking for 1/6" x 28, if it exists.
12/08/2017 20:45:50
Perhaps someone knows a supplier for tap & die 1/6" x 28 tpi. I have tried to find one with no luck. Niko.
Thread: Which oil for blueing steel screws?
23/07/2017 21:40:35
You can use water, it is only for stopping the colour from running further, the only advantage of oil is that the steel will not rust if you forget to remove the water. Niko.
Thread: polishing clock plates
16/07/2017 22:34:26
Leave the plates a little oversized, polish them to mirror finish, aply a tape to protect the surfaces as good as possible, then cut them to size and drill and tap the holes. Niko.
Thread: Best quality M2 taps
16/07/2017 08:57:22
Posted by JasonB on 16/07/2017 08:08:40:
Although I have dormneones in teh larger sizes they get a bit spendy as the size reduces so I use Volkel ones M2.5 and below, usually get them from Rotagrip via their e-bay shop
Small size good quality taps are indeed spendy, the time you bougth them in the hardware store around the corner is long gone. I returned the 1.4mm ones from Bergeon since 110 euro ex. VAT was a shock. Niko.
Thread: Myford Super 7 chuck alignment issues.
03/07/2017 22:06:31
Try fitting a catch- or faceplate first before you try a chuck, because you can acces the thread of a those plates from both sides they are easier to clean, if they fit you know the spindle thread is fine. Niko.
03/07/2017 21:11:27
You will have to check the spindle thread very thoroughly, small chips can embed themself in the thread and swiping it with a cloth or brush will not remove them. You will have to remove them with a small tool. The same is true for the thread of the chuck you try to fit. Niko.
Thread: Ebay chuckle
10/06/2017 12:13:05
Posted by wheeltapper on 10/06/2017 11:02:32:
I've got one like that, had it at least 25 years, got it in buy and queue for £30.
it, s done everything I needed.
Roy.
Same with me, have it now for over 30 years. German made it came with a Rohm 1-13 mm drill chuck. No idea what I paid for it but not much. Niko.
Edited By speelwerk on 10/06/2017 12:41:05
Thread: Getting to be short sighted: Vision Magnification advice please
04/06/2017 19:43:06
In warm/hot weather the headband of Optivisor becomes very uncomfortable for me, it makes me sweat a lot. Niko.
Thread: Did we go to the moon in 1969
27/05/2017 12:52:29
Best is to send Trump with a Russian rocket to the moon so he can check for himself if its fake or not. Niko.
Thread: Jaeger 4 day car clock
05/05/2017 20:57:39
you can mail them and ask what the nearist is they have. 0.22 mm will be difficult to get, normal is 0.20 and then 0.25 mm. if you have acces to a surface grinder you can easily make the width smaller altough that leaves a very sharp edge that will happily cut your fingers during assembly. niko
Edited By speelwerk on 05/05/2017 20:58:02
05/05/2017 18:11:56
google VOF van de gevel, they have a large selection under klok - veer. Niko
Thread: Westminster Attack 22 March 2017
22/03/2017 21:16:14
One year after the Brussels atacks again we are shocked by another barbaric act. Regardless of Brexit we as Europa must stay together and form one front against those very sick persons who do this. Niko.
Edited By speelwerk on 22/03/2017 21:20:41
Edited By speelwerk on 22/03/2017 21:30:28
Thread: pinions
08/03/2017 22:28:34
This is perhaps worthwhile buying, they try of course to sell there products but it gives also useful information. Niko.
Thread: Stalling Lathe
24/02/2017 00:54:00
Before you make adjustments, which should be minimal, mark the position of the split collar and the left adjusting ring for rear bearings. It gives you more control over what you are doing and you can easily return to the original setting. Niko.
Ausee.com.au
