Here is a list of all the postings speelwerk has made in our forums. Click on a thread name to jump to the thread.
Thread: Hardening clock pinions in EN8 steel |
06/06/2022 09:08:15 |
It is obvious but to reduce wear it also important that pinion and wheel are made as accurate matching (diameter/pitch/modul) as possible. Niko. |
05/06/2022 12:51:10 |
Apart from buying a hardness tester you can use these to get an indication of the hardness**LINK** Niko. Edited By speelwerk on 05/06/2022 13:03:08 |
Thread: More beginner questions |
02/06/2022 17:23:33 |
Posted by Oldiron on 02/06/2022 09:00:53:
Posted by speelwerk on 30/05/2022 20:17:22:
In the pictures I can see at least one of the clamping studs is missing indicating that installation/lathe set-up is not done properly. A good turning result starts with a good set-up of your lathe, generally called “leveling”. although it is not the correct expression. You can find much information about it on this form since it is a popular topic. Niko. How can you say that a stud is missing ? Just because a few are missing from the rest of the toolpost does not mean that there are not 3 holding the tool. It is probably behind the toolpost centre bolt. In any case 2 clamping bolts are more than adequate for the size of tool being used which as AndrewD says appears to be in the wrong orientation. regards Very sorry for the misunderstanding, only behind a lathe since 1971 and Myford since 1979, therefore will leave it to the UK experts to comment. Niko.
30/05/2022 20:17:22 |
In the pictures I can see at least one of the clamping studs is missing indicating that installation/lathe set-up is not done properly. A good turning result starts with a good set-up of your lathe, generally called “leveling”. although it is not the correct expression. You can find much information about it on this form since it is a popular topic. Niko. |
Thread: Looking for a non-magnetic, strong, easily glued material |
04/05/2022 17:09:18 |
- Copper & Brass Perhaps silverplated copper or brass would be OK. Niko. |
Thread: Acceptable runout on drill chuck |
22/03/2022 10:38:37 |
Here you find the maximum concentricity deviation that Rohm gives for its drill chucks, **LINK** Niko. |
Thread: Changing my Email client |
17/03/2022 20:40:40 |
I don't like Thunderbird at all, use it only because I cannot find a better program. It changes font, font size and how mails are sorted randomly, cannot get spelling checker for English and German working, just a few of the most annoying things. No doubt it is me that is the problem but why is there not a program for digital dummies like me. Niko. |
Thread: Myford Super 7 gib screws |
16/03/2022 18:22:49 |
They are longer because the later S7 has power cross feed therefore the apron is wider to accommodate the gears for it. Niko. |
16/03/2022 16:48:57 |
Not from the UK but these seems the ones you are looking for, Niko. **LINK** |
Thread: Myford ML7 feedscrew misalignment |
10/03/2022 21:50:43 |
To set the gib strip correctly you remove the bracket and lead screw from the cross slide. Niko. |
Thread: How hard is gauge plate? |
07/03/2022 11:31:21 |
Do not know about postage but should be reasonable coming from Germany. "Form A" does have a slightly longer lead but this "form B" should also be OK. Niko. https://www.gewindebohrer-shop.de/gewindebohrer-schneideisen-maschinengewindebohrer-verstaerktem-schaft/maschinengewindebohrer-durchgangsloechermit-verstaerktem-schaft-form-4022835745105-p-631.html Edited By speelwerk on 07/03/2022 11:31:56 |
Thread: If epoxy adhesives fail to set within 24 hours, is there any hope that they will EVER do so? |
14/02/2022 17:22:18 |
"Not sure of the shelf life of some of them." Steve, the Araldite AW 106 I have now for 40+ years still works as new. Niko |
Thread: New highway code rule. |
06/02/2022 16:12:50 |
Of topic but still cycling, the Dutch Against the Wind Cycling Championship. The bicycle is a ordinary Dutch bike with no gears. **LINK** Niko. |
Thread: Small MT2 Tailstock Chuck for ML7 |
27/01/2022 14:27:22 |
I use a Rhom supra 0 - 4 mm B10, top one in the supra list, Niko. Edited By speelwerk on 27/01/2022 14:29:10 |
24/01/2022 13:48:41 |
Done my driving test almost 50 years ago but never heard of the "Dutch reach" and I am sure 99% of my countrymen also. But if you do not look over your shoulder when opening your car door you will fail your driving test in The Netherlands. Niko. |
Thread: Highway Code |
05/01/2022 14:35:47 |
Here you find links to the Dutch highway (trafic) rules **LINK** , under the heading "Belangrijkste verkeersregels voor fietsers" you find the main rules for cyclist, all in Dutch of course but Google translate will help you. Over 45 years I have driven many miles on UK roads, from the deep south of Cornwall to Orkney in the north. However I will never ever cycle on your roads, far to dangerous. Niko. |
Thread: Where to buy hss sets at good price in european online shops? |
21/12/2021 14:54:46 |
This Dutch supplier is also possible, **LINK** Niko. https://www.hbm-machines.com/producten/gereedschap-en-toebehoren/beitels-en-beitelsets/beitels-en-beitelsets-1/hbm-16-x-16-mm-8-delige-hss-beitelset |
21/12/2021 14:36:41 |
I have used this German supplier a few times, **LINK** Niko. https://www.svh24.de/search?sSearch=HSS%2Bdrehmeissel&p=1
Edited By speelwerk on 21/12/2021 14:39:32 |
Thread: Digital Caliper - again, sorry |
09/12/2021 14:41:39 |
"Or buy a caliper with a high IP rating - I see this Mitutoyo is IP67." Have that one and use it daily, have not kept track of battery live but it certainly is long, I guess somewhere 2 years. However I would not buy it again since it has the disadvantage that you cannot zero it to measure differences without the need to re-calibrate again. The other type Mitutoyo 500-181-30 I have is much handier to use. Niko. Edited By speelwerk on 09/12/2021 14:42:14 |
Thread: 3.5mm hex. head screws |
21/11/2021 14:56:55 |
Not quite, because it is hex with a slot, but perhaps useable, Niko. **LINK** https://www.ebay.de/itm/265158626286?hash=item3dbcaf8bee:g:YwIAAOSwHd5gnPZY |
