Member postings for Yngvar F
Here is a list of all the postings Yngvar F has made in our forums. Click on a thread name to jump to the thread.
Thread: Four Index Thread Indicator
21/06/2022 19:55:46
Universal Thread Dial Indicator - Inch and Metric
Thread: Book on lathe operation ?
18/06/2022 22:59:35
This one is the Atlas version of how to run a lathe.
Thread: Boxford AUD/BUD single phase conversion
11/05/2022 17:41:04
1963 Boxford
This is the minimalistic approach. Original switches with a potentiometer added on the side.
Edited By Yngvar F on 11/05/2022 17:41:51
Thread: Moving a Bridgeport
10/01/2022 13:36:38
Thread: Boxford ?
15/10/2021 15:00:26
Read this
15/10/2021 14:54:48
Check the gear train The lever on the left must be in the up or down position.
Thread: Limp Probe
03/07/2021 08:46:01
Hi
There is a plastic ring that must be removed. Right over the probe.
yf
Thread: Huanyang VFD help please
08/11/2020 20:34:52
A resistor in series with the switch would do this, but is quite limiting compared to a potmeter.
Thread: Grafton tools (who?) - rotary table
17/06/2020 09:15:10
Don`t know anything about Grafton, but that drill press looks very much like a Atlas.
Maybe some badge engineering?
Thread: Topslide vice for Boxford lathe
06/06/2020 08:53:29
There is a small piece of metal rod under each screw. Remove the screw and Get some thin oil in there.
Thread: Non standard taps - what are they ?
03/06/2020 19:42:52
Posted by Andrew Cox 3 on 03/06/2020 17:07:05:
although relatively unusual in the wider world, finds widespread use in the old Citroen cars I dearly love.
Only come across them on old Vespas. Not the 1,1 version.
Thread: boxford model c
10/05/2020 21:47:25
Grease for the spindle bearings and oil for everything else I think.
Thread: Tool holder. What to do
03/05/2020 07:34:49
6001f752-79e9-40ec-8f03-304bfeb5e2c8.jpegWood toolrest
Made one that hangs over the edge of the top slide.
Thread: Boxford Tailstock Accessories
14/04/2020 17:05:53
The Boxford book is very good.
A search of south bend 9 inch lathe on you tube will give lots of results. Except for the spindle bearings your lathe is very similar.
A classic how to book is The amateur`s lathe Link .
14/04/2020 14:16:26
You are right , it is a model C made in 1958.
Your lathe has the same rear drive as the original South Bends.
Most later Boxfords had the motor inside the stand, or a under drive UD.
Edited By Yngvar F on 14/04/2020 14:16:58
Thread: Hello! young'un from Devon here
17/12/2019 08:54:44
Welcome.
That is a great looking workshop. The placement of the vdf is not so clever though.
Thread: Stevensons original collet blocks & Arc Euro 6" grinder
14/12/2019 20:37:45
ER collets have to be snapped into the nut. I did not do this when i first got a mill and was very dissapointed with the chuck`s runout.
Thread: My Lathe Dog
30/05/2019 09:51:49
Show us your cat`s head too
Thread: kerry super 8 bench drill
26/05/2019 11:56:14
The spring goes into the slot,you wind it up by turning the lid with two hands and secure it with your third hand when it`s thight.
26/05/2019 11:52:34
Mine came without a spring. Guess someone took it out to get a replacement and never did.
I ordered a spring on ebay. Works fine.
Don`t remember the size as it is ten years ago.
Rapid RC
Dreweatts
