Member postings for fizzy
Here is a list of all the postings fizzy has made in our forums. Click on a thread name to jump to the thread.
Thread: MACH 3 Display Question
30/03/2019 09:47:02
as Jason says, go bigger so you can have the jog screen at the side and not on top of the screen - very helpful
You can download mach3 free and get used to it in sim mode
Thread: Turning over a new Leaf
28/03/2019 19:46:09
Hi John. I too am in Lancashire and am not native to these parts. I also run a little company called Pendle Steam Boilers and have owned a fair few lathes and the like over many years. Welcome to the forum and if you need help with anything just pm me.
Thread: Collet Chuck or not ?
26/03/2019 09:20:30
A word of caution....I bought a cheap collet holder and set oft bay via china for my mill. Great at holding things rigid but a lot of runout...dont be tempted!
Thread: Smoke detectors
24/03/2019 19:11:42
I added fire detectors in my workshop...too much smoke!
Thread: combined BOB with drivers or seperate?
14/03/2019 20:01:43
Thanks all - Jason, thats similar to what I had in mind but the board has the drivers built in. I think direct USB is quite a new thing. Ive also looked at ethernet connected boards but im way out of my comfort zone with those. Im also wondering if the new boards will run with windows 7 64bit. The simulator has no problems with it.
Thread: Vertical Boiler - blower?
14/03/2019 19:53:49
Incomplete combustion is something we see with small burners, just put a CO meter near one, be they ceramic, mesh or brass. All three have different burn characteristics. I use solid brass in my commercially availible boilers as they produce the most heat, they are quiet fierce compared to ceramic. I only use ceramic in the twin flue 5" boiler as their sublime nature makes for much easier firing of both flues at the same time. A well designed burner needs no chimney as all of the combustion products are supplied from outside the burner. You will see slits in the sides of PSB burners but these have absolutely nothing to do with the combustion process. Invariably if you have your gas mix too rich a blue flame will be seen where it exits the chimney - check with lights off as it can be difficult to see. Whilst a more stable flame is seen when a chimney is present I can produce effective boilers without a chimney. An option is to have the steam return plumbed into the chimney but this is for authenticity rather than efficiency and i have not noticed any improvment in output.. My advice is...run exit steam through chimney but there should be no reason to add a stand alone blower, especially in a boiler so small.
14/03/2019 09:39:34
bump
14/03/2019 09:38:46
all depends on what your firing it with - gas=no, coal=definately. Ive never seen any coal fired boiler without one...and ive made and seen a few.
13/03/2019 19:51:03
Looking for a USB breakout board to run Mach3 and see that we can buy a control board with integrated driver. Anyone tried the new integrated boards? Something tells me to stick to separate parts.
Thread: Chimneys & Steam Pipes : Copper or Brass : Why ?
08/03/2019 15:31:36
For the record in the UK under current club rules it is perfectly acceptible to make boilers out of brass. They are much stronger and thus can be made much lighter than copper, and are a lot tougher to work with. I do get asked to make boilers frombrass from time to time but dont like making them! Bushes are all bronze.
Thread: Laser Cutting Costs
06/03/2019 19:46:21
Give Malc a ring **LINK**
and tell him i will get his burner sorted soon!
Thread: Nine months in the acid bath!
06/03/2019 09:20:53
Me too Brian, thought this might put a few minds at rest!
Thread: Myford Lathe on Ebay
05/03/2019 21:03:46
Bet it goes over a grand -great starter for someone new to the hobby.
Thread: Round top inner firebox
05/03/2019 21:01:56
Im mid build on a couple of 5" gauge Sweetpea boilers which have totally round fire boxes. No stays of any kind for the firebox tube is a massive bonus - both end plates are stayed. If the top of a conventional type loco boiler is half round no stays are needed in it (joing sides and ends stayed as usual) but as stated previously you lose a lot of tube space compared to a square section plate.
05/03/2019 20:50:16
Whilst making a 2" scale boiler for a traction engine mid 2018 I missplaced one of the inner firebox plates, so made a new one and carried on. Yesterday I was forced to extract a boiler from the acid bath by hand (vets full arm glove) and to my suprise came across the lost plate laying on the bottom. I had always wondered what effect long term acid soaking would have on copper. Anything over a day with brass is very bad news - im using 30% Sulphuric Acid so its strong stuff. The plate in question has a little crystalisation of acid salts on its surface but other than that was in perfect condition - I wont be using it but I wasnt expecting it to look as well as it does.img_0004.jpg
Thread: Can opener - the holy grail in engineering?
04/03/2019 21:01:11
Seems the jury is out....definate opportunity me thinks
03/03/2019 18:54:13
Over the years we have bought countless can openers, the type you squeeze in one hand and turn with the other. Quite quickly they all fail. Can it be that difficult to design onethat doesnt fail? And now the big question - are modern can openers designed to cut the lid from the inside or the top off the can from the outside? Wife says outside, I say inside (of can lip).
Thread: Western Steam
02/03/2019 09:53:41
I would like to wish Helen a speedy recovery. As a full time boiler maker (not touting as I make them for marine and stationary engines) I can say with confidence that you will not be able to buy a better made boiler anywhere in the world than by WS, and that is why you have to wait so long. You can rush a boiler build but you cant rush quality.
Thread: Straightening a wayward hole
27/02/2019 18:01:36
you will most likely snap the end of the centre drill off in the job. Use an end mill instead and take it very slowly as it will easily deflect.
Thread: Silver soldering bronze
26/02/2019 18:14:32
You left it in the pickle too long...had it happen to me. No telling what went into making your bronze but it will and does turn black. Ive had brass do it as well. Get a bit of Tenicity 5 flux, mix it thick and it should work fine on clean metal. You need the extra temp flux due to the small piece of work getting hotter quicker. Good luck.
EngineDIY
