Here is a list of all the postings Bazyle has made in our forums. Click on a thread name to jump to the thread.
Thread: Acceptable runout on drill chuck |
22/03/2022 13:46:16 |
If you are coordinate drilling on your mill then it gets important. You should make a high accuracy holder, not collet blah blah system to hold a spotting drill dead true. The old fashioned system of marking out on a surface plate, centre popping by feel at the intersection of the microgrooved lines produced, then drilling in stages could get things as accurate as your height gauge. (and skill). A wobbly chuck mattered less, within reason. It also makes sense to have a small chuck for a small drill to start things off. edit - by which I mean a 0-1/4" not a 0-3/8" Edited By Bazyle on 22/03/2022 13:50:17 |
Thread: Todays daft question |
21/03/2022 19:38:29 |
Posted by Andrew Johnston on 21/03/2022 14:52:07:
Possibly to distinguish them from side and face or slab cutters as used on horizontal milling machines. Andrew Agree and because they have cutting edges on the end. They probably developed from spot face cutters which are intended to cut only on the end but someone thought that with a little extra filing they could make it cut a bit sideways to increase the area of the spot face. |
Thread: Simple grinding rest. |
19/03/2022 22:36:16 |
Looks like a good system Huub. |
Thread: Setting up a Warco BH600G |
19/03/2022 20:00:43 |
There is also a version of the G.Meek screwcutting clutch for the BH600 somewhere. |
Thread: Damp shed: what’s the best way to add ventilation? |
19/03/2022 19:13:40 |
Posted by Peter Cook 6 on 19/03/2022 16:50:23:
when the sun is shining and the air is fairly warm and dry, When the air is warm it is able to hold more moisture. Having drawn it into your workshop when it cools down it will drop it's excess moisture. |
Thread: What is this |
19/03/2022 18:45:46 |
It is a surface planer, possibly experimental adaptation for metal of the form used in drilling machines for wood. They are not very good for wood. |
17/03/2022 18:53:22 |
The centre of gravity of a lot of lathes is about where the chuck is. If slinging round the bed (full turn INSIDE the leadscrew by the way) remove the chuck and thread a bit of rope through the spindle and use it to pull the the strop up to the head so it can't accidentally slide down the bed. With any luck then the lathe will be tailstock down and a light rope to the crane hook will set it horizontal. |
16/03/2022 18:04:12 |
Surprise ! the UK is damp in winter (and most of summer). If you make holes in a shed it will be damp. Best thing is to seal it up and just open the door after very frosty nights when the air will be dry and really hot days in summer. You especially don't want to open the door on a day when it has changed from cold to feeling warm because a wet warm front has moved over the country. |
Thread: Boiler making torch |
15/03/2022 20:41:19 |
Just on Friday at an EDMES meeting one member told me he couldn't get a calor refill because they had no small cylinders - bit of a run on them due to people perhaps cooking on gas to save electricity. He had to get a 19kg one to exchange. |
Thread: How Many People Does it Take to Change a Lightbulb on the Forum? |
15/03/2022 20:16:37 |
I was just wondering today when electricity started its journey to becoming essential for normal life. Particularly in relation to the telephone and in my village. Although the electricity and phone lines march up the lane on the same poles for some reason at the edge of my garden they diverge and come in on different sides necessitating two poles one each side. So which came first and why diverge at this point? The electricity people trim the trees their side but the phone line used them as support - until Eunice. So currently no wire and using a BT supplied mobile minihub. We didn't get piped water until the '30s so imagine electricity came later, but would people have installed a phone while still reading by oil lamp? |
Thread: Screw cutting problem |
15/03/2022 19:36:20 |
Er, i know lots of people like the topslide parallel but that's not what it is for. Lots of early lathes didn't have one so it was added to enable tapers etc, You should be able to set it over and leave it there, except for the infernal nuisance of Whitworth and BA being different from unified and metric. |
Thread: Converting brick outhouse to (very small) workshop... |
15/03/2022 19:24:46 |
Get your priorities right. Make your outhouse a bedroom and use your bedroom as a workshop. If you have a partner make bunk beds The space is after all bigger than a camper van. Apart from kings and lords the separate bedroom is a recent invention of the affluent. |
Thread: Hello from Cambridgeshire |
15/03/2022 17:44:37 |
Aren't clubs fantastic. Your experience at Bournemouth saved you from blacking out while driving and probable death. You will make some great friends if you try out our local club either by contacting them through their website or perhaps turning up at one of their advertised meetings or open days. Ask to speak to a committee member as if you just pick a random person they too might be a visitor, or with clubs being very inclusive places the person might have communication issues.
Thread: Dividing head for Tom Senior Mill advice |
10/03/2022 21:12:12 |
The Elliott one shown on a recent thread was intended for that size machine (Elliott equivalent) but does not tilt. |
Thread: Anybody want a Virginia |
10/03/2022 17:31:31 |
Ah, that explains why I couldn't find it. If it helps any I can offer transport to region of Reading or St Albans if you could get it to the Exeter club. I will also mention it to the EDMES club members at the meeting on Friday. |
Thread: Hammer Handle Supplier?? |
09/03/2022 18:05:57 |
The Men's Shed get given a lotof tools that need new handles. Nowadays it is cheaper to buy a complete new tool. As for using hickory, surely that;s only in America and ash is the norm in the UK. |
Thread: Financial surnames |
09/03/2022 00:02:04 |
Parents may or may not recognise the effects of names they choose for their children. The composer Vincent Knight named his daughter Stella and not shying away from it she deliberately lives in Knightsbridge. However a colleague at work named Peter whose surname began with E perpetuated the schooldays pain by calling his son Paul. |
Thread: T pylons |
08/03/2022 23:08:03 |
The individual metal elements of the old ones were thin so if not on the skyline but seen with a backgouund of trees they blend in better. The driving force behind them is probably lifecycle costs. The metal ones have to be painted regularly which is a very manual and expensive process. |
Thread: Shed insulation |
08/03/2022 00:34:20 |
Posted by DMB on 07/03/2022 14:48:25:
.........and voids stuffed tightly with mineral wool ....... Keep it loose, it is the trapped air in it that does the business. |
07/03/2022 13:44:43 |
Note this is ventilation for the inside surface of the metal skin only NOT the whole shed. If possible use plastic sheet to make the inside surface of the insulation as airtight as possible and use a dehumidifier to remove the moisture you breathe out. |
