Member postings for Deltic007
Here is a list of all the postings Deltic007 has made in our forums. Click on a thread name to jump to the thread.
Thread: injector drawings
19/10/2018 23:00:54
Having recently made some ejectors from an ME drawing that work well
I now would like to make an injector
Is there any drawings someone can point me at?
Thread: Newall Spherosyn Repair
16/04/2017 17:34:00
Thanks
16/04/2017 16:29:03
HI,
I need a new 7 pin plug putting on one of my reader heads,is it possible to do yourself and if so where do you buy the plugs
Thread: Steam pump
30/03/2017 15:25:23
Chris,
All lines are clear,i am trying it again tomorrow so will report back.
cheers
30/03/2017 13:23:10
30/03/2017 13:22:59
Hi Julian,
Drawings were from Allen models in the US
No idea if it works with the water side disconnected and connected to pressure vessel(Good point and would answer your next question).
IT does work under steam all connected but only pumps a couple of times stops and after a minute restarts only to stop and the cycle goes on.
Pump is at the front of the loco about 14" from the steam valve
Steam cylinder bore is 1" water is 5/8
Cannot see the exhaust as it is piped into the smokebox.
Hope this helps and thanks for taking time to help me.
30/03/2017 07:52:02
Ah yes
There are no drain cocks at all in this design.
cheers
29/03/2017 22:17:39
No checked the clacks and pipework blockages,Glands were leaking so repacked them ,just need to test again.
When i tried it last week it would pump twice then stop,wait a minute or two and it would start n stop again,strange.
29/03/2017 20:11:30
Hi all,
I have just made a worthington single type steam water feed pump and it works a treat until it goes under pressure when on the loco.Any ideas what the problem could be?
Cheers
Thread: Ejectors Help Needed
20/03/2016 22:10:32
You really expect me to furnish that with something sensible?
20/03/2016 19:39:52
Hi,
I need to fit an ejector to my 71/4 model,does anyone have a drawing they could let me have or is there an article in one of the magazines?
Cheers n thanks
Thread: Vacuum Brakes
14/03/2016 22:36:35
Hi
I am looking at fitting brakes to my new 71/4 loco,the diaphragms that i see for sale on the net seem to be very expensive £37.50 plus,anyone got any ideas or experiences to help me save some wonga? as i need 2 plus reservoir and brake shoes.
Thread: O rings
24/01/2016 17:00:50
Hi anyone ever joined a SILICONE O ring what did you use?
Cheers
Thread: Superheater elements
08/01/2016 20:02:45
cheers
Hi all
Is it possible to buy elements(2tubes welded together) professionally?
If so where from?
Thread: Boiler Bushes,Headers Etc
03/01/2016 17:37:12
Hi all,
What materials are preferred to use on a copper boiler for the bushes,Gunmetal,SAE660 PB1 Colphos 90 or PB102.
I have seen various suggestions but i wanted your valuable opinions.I believe that Colphos,SAE660 and Gunmetal have small amounts of Zinc in them which i believe are a NO NO ? yet GLR Kennions are quoting SAE as "Ideal for boiler fittings" Very confusing!
Anyway thanks for your input in advance.
Thread: Fusible Plugs
30/12/2015 18:54:10
What material would you recommend? Drawing actually says soft solder.
30/12/2015 18:24:52
The reason i originally posted was because i am building a New Zealand designed loco and it has one fitted.I will have to consult our boiler inspector to see if it is OK to omit it.
30/12/2015 18:18:51
Why would you do that Mark?
29/12/2015 10:03:36
Any reason Jason
29/12/2015 09:58:13
Got to make one of these for my next project,is normal soft solder Ok or am i better with white metal or lead?
Dreweatts
Rapid RC
