Member postings for trev
Here is a list of all the postings trev has made in our forums. Click on a thread name to jump to the thread.
Thread: Dykem
02/04/2021 09:25:33
Hi Allan
I recently bought a small a small bottle of red Dykem marking out ink from Amazon at a reasonable price if that is of any help and it arrived in a couple of days
Thread: I C Engine Piston rings sticking
10/03/2019 18:22:48
Hi guys can anybody help me out with a problem of sticking piston rings on an IC engine when the engine has been left for a couple of weeks the rings appear to be stuck in the ring groves with what I would say is expended fuel from the last time it was run on ,the only way to get the engine running again is to remove the piston clean up the rings and groves any ideas on how to stop this happening would be great look forward to hearing from you out there
Thread: Electronic ignition
20/03/2017 18:59:47
Thanks for all the replies to my query about ignition systems I will look at some of links ,I have used a cdi ignition unit for rc models and that works quite well
07/03/2017 19:25:18
can anyone out there suggest what ignition system to use on a model I c engine apart from the buzz coil
Thread: Woodpecker engine castings
14/02/2017 18:14:57
Hi Jason thanks for the information that's a good idea I will contact smokstak
13/02/2017 19:19:40
hi has anyone built a woodpecker engine from castings if so what do you think of this engine are there any problems with the machining
Thread: Timing a twin cylinder
10/04/2015 20:41:49
Hi could somebody please help with a way to time a twin cylinder horizontal steam engine ,mine is the sir william armstrong twin ,how do you set up the cylinders ? Are they at opposite ends of the stroke? Any help would be appreciated
Dreweatts
Rapid RC
