Member postings for D John Maycock
Here is a list of all the postings D John Maycock has made in our forums. Click on a thread name to jump to the thread.
Thread: Dividing
30/07/2014 10:33:14
Hi All
Thank you all for the information supplied, job done.
21/07/2014 12:59:51
Hi Everybody, I would be grateful if anybody could provide me with the method by which a Circle can be divided into equal divisions, 125 in this case using TurboCad 15, thanking you in anticipation. Regards John Maycock
Thread: Alexander Tool and Cutter Grinnder
01/10/2012 19:22:21
Hello Neil,
Thanks for the welcome,I am away from home at the moment so I have found this Deckel Drill Jig on the web, it is the same machine as the Alexander, I will try to post in the album section.
Thanks John
21/09/2012 10:50:05
Hi All,
I am just coming to the end of a rebuild of one of the above machine which was given to me some time ago, it had stood in the cojner of a workshop for some years but apart from being very dirty it was ok only requireing some paint. an inverter and a new drive belt.
Included with the tooling etc was a Drill Gringing Jig which for some reason was in a box and dismantled, has anyone out there access to a instruction manual for the Drill Grinding Jig part of this machine as it is not included in the main manual which I have a copy of.
There is no problem rebuilding the Jig just its use.Regards John.
Dreweatts
Rapid RC
