Here is a list of all the postings Emgee has made in our forums. Click on a thread name to jump to the thread.
Thread: My compact workshop |
15/01/2021 22:54:02 |
Had a PM reply from Roger, copied below. I've made contact with the outside world ! Thanks for your reply. My current project is a horizontal mill type engine, 2" bore 2" stroke, entirely made from odd castings and bar stock ,cylinder covers are 80mm c i bar stock, crankshaft an unmachined casting of unknown origin, flywheel Stuart 5a, cylinder Stuart no 1, steam chest brass bar. Eccentric straps brass 3/8" plate. Bearing blocks steel bar. You can see pics on my album. Above written by Roger Hills 1 |
15/01/2021 15:52:23 |
Hi Roger Certainly a compact workshop but that hasn't prevented you from making some very nice looking engines, although you say compact it looks very well equipped with tooling. Welcome to the forum, what's your current or next project ?
Emgee
Thread: Machining Brass |
14/01/2021 16:42:39 |
Posted by SillyOldDuffer on 14/01/2021 15:15:29:
I don't know why I confess simple mistakes - they're embarrassing now I can't really claim to be a beginner! Perhaps one day I'll get it right... Check the cutting point too. Maybe it's been knocked off. Dave Don't feel too bad about it Dave, from another site somewhere "The man who hasn't made a mistake has likely made nothing" Over the years I have to admit spending many hours machining parts that turned out to be scrap, I think that's what is called gaining experience. Emgee |
Thread: Standards of Electrical Wiring |
14/01/2021 16:32:43 |
They seem to have left some spare cable in case the communication cables needed re-terminating.!!! Only guessing now but the boxes could be metered supplies with some kind of switch/mcb positioned at the bottom behind a hinged cover. Emgee |
Thread: V-Twin 100cc Design & Build |
14/01/2021 12:04:50 |
For some reason Craig stopped posting here on his build but the engine is now completed and has been test run. See it at this link **LINK** Sounds good and seems powerful by the stats provided. Emgee
Edited By JasonB on 14/01/2021 12:11:51 |
Thread: Making go kart parts |
12/01/2021 22:57:11 |
Nick, 7075T6 is a very good material but supply in the UK is by specialised dealers and most charge high rates. Emgee |
Thread: capacitor droppers and power factor |
12/01/2021 10:47:21 |
Posted by Anthony Knights on 18/08/2020 09:02:59:
Low current yes. I recently looked inside a defunct central heating controller. I was basically one large chip, LCD display and a small relay providing a set of change over contacts to the outside world. The whole thing was powered from the mains via a capacitor/resistor potential divider, rectifier and possibly a zener diode. I didn't investigate further as it was dead, so it went for electrical goods recycling. I experienced the same or similar fault in a Honeywell heating controller, the circuit has 2 relays, 1 for heating and 1 for water, both independently switched as programmed. Replacing the capacitor in the circuit restored correct functioning of the controller, cost was around £3 as against £80 for a new controller. Emgee |
Thread: Insert tool cutting angles |
11/01/2021 23:33:40 |
You won't get into tight corners using a Straight (Neutral) holder, you will need either or perhaps both RH and LH to reach all corners. Emgee |
Thread: Sherline motor died |
11/01/2021 11:55:59 |
Posted by Michael Gilligan on 11/01/2021 11:46:22:
Posted by Emgee on 11/01/2021 10:55:08:
Posted by larry phelan 1 on 11/01/2021 10:39:38:
Seems a lot-of-lolly to pay for a throw-away-motor ?? Michael Those links didn't answer my question about getting more power with motor enclosed brushes !!!! Emgee
. No they didn’t ... I was leaving it to you to deduce that the statement* is badly [or perhaps cleverly] written, and that we are actually looking at coincidental events that are not ‘cause and effect’. MichaelG. . * May I repeat .... I’m not sure what they are comparing with what, in that claim Edited By Michael Gilligan on 11/01/2021 11:48:50 Seems to me they are comparing the old motor with external brush holders to the new motor with enclosed brush holders. I have searched without success for evidence to support the claim of more power so the word I find for the description may not be within the site rules. Emgee |
11/01/2021 10:55:08 |
Seems a lot-of-lolly to pay for a throw-away-motor ?? Michael Those links didn't answer my question about getting more power with motor enclosed brushes !!!! Emgee Edited By Emgee on 11/01/2021 10:55:50 |
11/01/2021 10:48:29 |
Seems a lot-of-lolly to pay for a throw-away-motor ?? Agreed especially if you add £30-£50 carriage cost to Europe, and it is only 60W output working at maximum 5mins on 15mins off. There must be a better alternative available if you look hard enough. Emgee |
10/01/2021 19:50:58 |
Following the link above to see the explanation for the move to internal brushes that have to be replaced at the factory, could someone please explain how more torque is obtained with internal brushes fitted in the same orientation as external brush holders. I can see the motor costing less to manufacture with fixed internal brushes but it doesn't help the European user when it comes to checking or replacing brushes. Emgee
Thread: The Repair Shop is getting to me... |
09/01/2021 19:57:51 |
I would have thought the Repair Shop program would appeal to all members on this forum, after all we do practice a craft of some kind whether it be using hand tools, programming and pressing buttons or setting up and turning handles. As said it is amazing the skills of those doing the repair/restoration work. Emgee |
Thread: Total cost + import for Tormach PCNC 440, and alternatives? |
09/01/2021 14:41:45 |
Posted by Steve Dunthorne 1 on 09/01/2021 14:12:58:
Check your Message box Steve, top menu bar envelope flashing. Emgee |
Thread: Oil Blackening and other Oil Issues |
09/01/2021 11:39:10 |
Many years ago I bought a 1100C Kiln and included with it some whale oil to quench parts which also gives a durable black finish. The other evening there was a part quenched in linseed oil on the Restoration TV program, looked like a good result. tools below quenched in whale oil. Emgee |
09/01/2021 09:57:53 |
Posted by Peter Cook 6 on 08/01/2021 15:36:20:
Just my pennyworth. The Denford range is based on Sherline machines. Have you considered a Sherline - or are they too small? Not true Peter although Denford did do a small lathe and mill using Sherline machines within Denford enclosures operating with Denford software. The other cnc mills and lathes in Denford's range are much larger machines than Sherline products. Emgee |
Thread: DTI Stand - Single Lock Type? |
08/01/2021 11:43:31 |
Ron's indicator and mag base now £13-79 delivered, such a good buy. Emgee |
07/01/2021 20:37:26 |
I see you have decided on a good quality tool but my experience using an £11 single operating point 2 armed mag base has been favourable for the cost and adequate for a quick check on concentricity of parts fitted in the chuck, only a small unit so easy to fit on the toolblock, Emgee |
Thread: Mill base? |
07/01/2021 12:16:35 |
Moderator note: whilst I don't disagree with NDIY's views on over-optimistic advertising, I've removed the name of a company, who might be libelled. Terms and Conditions say members shouldn't: Upload, post or otherwise transmit any Content that is unlawful, harmful, threatening, abusive, harassing, defamatory, vulgar, obscene, libellous, or invasive of another's privacy. Please don't inadvertently defame or libel anyone whilst making a point! In this case my understanding of what's meant by a 'Universal Mill' is in accord with the advertisers. I suggest the meaning has shifted over time and isn't an attempt to hoodwink naive buyers. Another example is the Gut Buster drill; previously a particular type of manual drill, now apparently any unusually big and powerful electric drill.. Dave I agree entirely with the first 2 paragraphs of your note but being old school I think it is wrong to offer a mill/drill for sale calling it a universal milling machine, dual purpose yes. Emgee |
Thread: Yet another scam lathe sale on ebay to be aware of |
06/01/2021 12:36:42 |
Most likely a good idea to all be aware and report on this thread any listing for sale on any media that has all the signs of being a scam, if the item offered is genuine the seller can provide details to support his/her claim if made aware of the reported scam. Emgee |
