Member postings for Alan Vos
Here is a list of all the postings Alan Vos has made in our forums. Click on a thread name to jump to the thread.
Thread: For the latest in PC fashion! (Anyone here with a Master's Degree?)
28/10/2020 18:09:31
This is not a new thing. Best part of 20 years ago we were told at work to stop referring to computer hard disks as master and slave. Some of my then colleagues in North Carolina would have been descendents of slaves. They didn't believe it would make any difference to race relations.
Thread: Parcelforce or DPD
28/10/2020 17:56:19
DPD, with Parcelforce a very close second. Royail Mail are fine as well, when the package size suits.
Thread: Putting the clocks back
26/10/2020 17:48:47
Posted by Michael Gilligan on 25/10/2020 09:55:40:
Yes ... but I don’t currently have a ‘convenient reference’ for DCF77
Do you ?
How about this: **LINK**
25/10/2020 09:49:29
Posted by Michael Gilligan on 25/10/2020 08:52:57:
Just for convenient reference: **LINK**
https://www.npl.co.uk/msf-signal
Some clocks and watches sold in the UK use DCF77 from Mainflingen,Germany.
Thread: Engineering Sights on Google Streetview
14/10/2020 19:47:19
A larger steam hammer (Telford Services) **LINK**
14/10/2020 17:39:29
This turbine near Lynmouth **LINK**
Thread: cateracts.
07/09/2020 19:39:38
Posted by Bandersnatch on 07/09/2020 18:26:23:
Do they give any such sedative for the cataract surgery?
Local anaesthetic only for me.
The only thing I would criticise the surgeon for is his choice of music. One piece was a requiem.
Thread: Electronics for the Cognoscenti
01/09/2020 18:19:42
Posted by Andrew Johnston on 30/08/2020 11:30:33:One caveat, it's printed on tissue paper so thin you can see what's printed on the other side of the page. That's a real disappointment, CUP must be going down the pan.
CUP = Cambridge University Press
There are reports of poor quality counterfeit versions of the main book.
Thread: My wife broke the internet
20/08/2020 17:33:16
Did enybody ever actually manage to exceed the REN limit and experience an adverse effect ? From what I recall, the stated limit was 4. The daftness was that no device was allowed to state less than 1, even if, as mentioned above, it was seperately powered and put very little load on the line.
Thread: cateracts.
12/07/2020 18:09:30
Hopefully you will be given the option of whether you want the implant suitable for reading, long vision, or something in-between. I opted for long vision. Stereo vision was restored as soon as I took the dressing off.
Thread: Buying first lathe
22/06/2020 17:27:57
Posted by Durhambuilder on 22/06/2020 08:31:04:
The dulux paint colour match swatch under the left foot would ring some alarm bells ! Has it been hastily repainted?
There again, it could be a good sign. Some people include a reference colour sample for the same reason others include a ruler.
Thread: Can summer car tyres be used in winter?
17/06/2020 17:27:48
Posted by Peter G. Shaw on 17/06/2020 09:18:37:
I then moved onto Michelin Energy+, and now am on Michelin Cross Climates. My suspicion is that the Cross Climates are noisier than the Energy+s, and possibly slightly less good on mileage. On the one occasion we did get some snow recently (two years ago?) I deliberately tried to provoke a sideways slip with harsh braking at a low speed. No-one else was around so it was quite safe. The car pulled up in a dead straight line when I expected at least a gentle sideslip. So was that the Cross Climates? Don't know, but on that very unscientific test, I'm staying with them.
A few years ago, when the original Hankook tyres on a car wore out, following an icy winter, I replaced them with Michelin CrossClimate. My thinking being that as those are certified for winter use, they ought to cope better with the worst British weather. I never found out. It failed to snow the next two winters. Then I sold the car. They did behave very well through standing water. The tendency to pull to one side was greatly reduced.
Thread: Arduino /C++ Questions...
04/06/2020 17:54:15
Something I found. The URL to the code does still work.
Arbitrary precision (big number) library port for Arduino
All theory to me. I don't have an Arduino.
04/06/2020 17:23:49
I would be considering an arbitrary precision integer maths library.
Thread: Look what I Found
21/05/2020 17:52:13
Rawlplastic, and slivers of wood, have an advantage over plastic plugs when the hole is in slightly the wrong place. Enlarge the hole and insert the packing offset so that the 'hole' is where you want it.
The star drills that started this are also great for starting holes in glazed ceramic tiles. Tap away gently until you are through the glaze. You can tap at angle to steer the hole. Then get out the power tools.
Thread: Aircraft General Discussion
20/05/2020 19:06:38
Posted by Buffer on 20/05/2020 10:59:51:
I knew it was proposed to make syy writing legal again in the UK (since 1960). Now with added computer control.
Thread: Arc Euro Trade - Quality?
14/05/2020 18:50:04
I am a happy repeat customer of Arc. The only dud was a set of thread gauges. The smallest pitches were all poor.
So I bought another set elsewhere. Exactly the same. Conclusion, there was factory somewhere in China in need of new tooling. In practice, the gauges have always been good enough for what I actually need.
Thread: SX2P Mill - Birds Nest?
14/05/2020 17:50:09
On mine, the key for the R8 taper fell out, to the outside of the spindle. This led to worrying noises. Try taking off the cover around the bottom of spindle and see what you find. Those are parts 100 and 102 here: **LINK**.
Thread: How to store boiled linseed oil so that you can re-open the bottle at a later date
07/05/2020 17:55:51
I have a bottle of boiled linseed oil. It is a typical DIY store thin clear plastic bottle, with a safety cap. After the first use, this is, being polite, somewhat difficult to open.
I am thinking I should decant into a more sturdy bottle, Then remember to wipe the cap and the neck of the bottle before closing.
Does anybody have any tips to prevent the bottle cap becoming glued on by polymerised oil ?
Thread: Internet crash
19/03/2020 18:56:56
I am the IT department for my employer, I have spent most of the week scurrying around to arrange working-from-home for people who were not expecting to need it. There are some hardware shortages. Internet bandwidth is not proving to be a problem. To paraphrase the Openreach representative interviewed on Radio 4 a few days ago, leisure time use of Netfiix etc is what creates the heavy load, home working is easy to handle.
Instead of the usual 5 or so VPN clients, today I had aounrd 30.. No performance issues reported. The 100Mbps internet connection remained mostly close to idle, just the usual brief peaks when somebody or something moves a large lump of data.
Earlier in the week there were signs of stress on business services such as Microsoft Teams. These will not affect domestic internet connections.
Rapid RC
Dreweatts
