Member postings for Roderick Jenkins
Here is a list of all the postings Roderick Jenkins has made in our forums. Click on a thread name to jump to the thread.
Thread: Advice on Choosing A Mini Lathe
30/03/2019 22:43:38
Perhaps we need to define our terms. Suppliers in both the UK and USA describe 7x12 and 7x14 lathes as mini lathes. I suggest that Sherline and Taig lathes (and Pultra, Flexispeed and Adept) could be referred to as micro lathes.
Cheers,
Rod
Thread: DraftSight no longer free
28/03/2019 12:52:25
Just to go back to the original comment for a moment. My copy of Draftsight is copyrighted 2012 and, as far as I know, has no connectivity to Dassault Systems. It is a 2D only version. I don't expect this to disappear. Time. of course, will tell.
Rod
Thread: 4" chuck backplate
24/03/2019 14:18:36
Posted by Martin Shaw 1 on 23/03/2019 20:58:03:
...It was also the first time using carbide insert tooling ...
Perhaps not too fast.
Rod
23/03/2019 09:57:25
Finished the pallet. I don't think my dodgy shoulder would have let me tap the holes by hand.
One half of the disc has holes on a rectangular array and the other half is radial. Not sure if this was a good idea or not. I've got a pallet on the CNC mill that's also waiting for an array of holes.
Rod
21/03/2019 21:22:24
I'm making a pallet for my rotary table. Lots of M6 tapped holes. With this in mind I bought an Archer auto reverse tapper from ebay.
Rod
Edited By Roderick Jenkins on 21/03/2019 21:25:18
Thread: Watchmaker's vertical slide
21/03/2019 20:25:23
My obsession with milling spindles continues: I've made one for the Lorch slide -
Cheers,
Rod
Thread: Tool Post Milling/Drilling Attachment
19/03/2019 16:25:11
Guys,
I have successfully used a 120 Watt sewing machine motor with an Arrand spindle. 6mm drills are a bit of a struggle but it will drill 4mm with ease and drives a 6mm endmill OK providing the depth of cut is not too big. I was guided in my choice for the new system by the capacity of the ER11 collet chuck.
I couldn't really comment on use for a woodturning lathe, it depends on so much. For guidance, the top speed of the treadmill motor is 4000rpm so I would probably at least halve that speed with the pulleys for wood turning but, again, it depends...
HTH,
Rod
16/03/2019 23:23:21
Posted by Robert Atkinson 2 on 16/03/2019 22:53:26:
Posted by Roderick Jenkins on 14/03/2019 23:01:52:
Good question. This looks like the speed controller **LINK** It seems to run equally well in either direction by swapping the motor leads.
... As you probably kinow to reverse a universal you have to swap just the field or armature.
That's a very bold assumption frown Thanks for the information yes
Rod
Thread: Why do both power hacksaws and bandsaws exist?
16/03/2019 23:17:49
My guess is that new technology made flexible blades with HSS teeth a reality and thus suitable for cutting steel at high speed. The reciprocrating saw becomes old and slow technology.
Rod
16/03/2019 19:47:55
I'd considered a spindle like the one Nicholas used. My concern was that there might be insufficient torque to drive a 6mm drill through steel at 1000 or so rpm which is at the bottom end of the speed range for a 12000rpm spindle. I, too, had doubts about the robustness of the bearings. Hence my clumsy looking but workable solution. Happy to be proven wrong smiley
Rod
14/03/2019 23:01:52
14/03/2019 14:36:01
Being the impatient soul that I am, I have conceived the need for an easily mountable tool that can be used for milling and drilling items held in the lathe headstock. I do this quite a lot with a vertical slide and 95% of the work is done at centre height. This is my attempt at a tool post mounted attachment:
The spindle is based around a pair of angular contact bearings and an ER11 straight shank spindle, both from ARC. The motor is a 200W 230V treadmill unit with speed control from ebay **LINK**
I'm waiting for a pulley cover to print at the moment.
Cheers,
Rod
Edit:  I paid £44 for the motor  -  looks like he might be out of stock with speed controllers for the moment.
Edited By Roderick Jenkins on 14/03/2019 14:40:30
10/03/2019 16:35:19
It's all becoming clear now. The original designer of the vertical slide was a maker of watches that showed the relevant astrological phase as well as the solar time. Since then Lorch slides are like they are because "We've always made them like that". Mind you, being a Gemini I'm in two minds about this.
Michael: thanks for the link - very useful.
Cheers,
Rod
08/03/2019 08:01:12
The most likely rotation for me is from horizontal to vertical which is 22 1/2 divisions which seems "just wrong" but then I'm not a watchmaker 😐
Whatever, I'm trying to design a spindle for it to go on my 1750 Pu!tra.
Rod
07/03/2019 21:58:59
HI,
I have one of these Lorch type vertical slides, without the milling spindle.
Can anyone hazard a guess as to why (or even actually knows!) the circular scale is engraved 0-90 rather than 0-360 (or 0-36)?
Cheers,
Rod
Thread: lathe to cut 26tpi
20/02/2019 22:19:43
Posted by John Duncker 1 on 20/02/2019 21:40:48:
Why was I gobsmacked well it turns out that the leadscrew is imperial but the cross slide and compound are metric
You are in good company - all metric series 7 Myford lathes had 8 tpi leadscrews.
Rod
Thread: Myford Dickson toolholder and 10mm tooling
19/02/2019 09:53:49
I've milled the bottom off 10mm tip holders but I don't think this is a fault of the tool holder manufacturers. I imagine that the holder was designed to hold a maximum 3/8" (9.5mm) HSS tool. There is quite a lot of variation with tipped tools, depending on how deep the tip sits in the tool and the thickness of the tip itself, making 10mm tip holders marginal even in original Dickson tool holders. I think 8mm tipped tools are probably a better choice for Dickson equipped 7 series lathes.
Cheers,
Rod
Edited By Roderick Jenkins on 19/02/2019 10:04:12
Thread: New coffee maker - disgusting taste!
17/02/2019 16:35:04
Posted by Mike Poole on 17/02/2019 15:57:12:
Absolutely! And the cream goes on first then the jam.
No dogma here please. A proper engineer will determine whether the cream or jam is the more viscous and then apply the thicker of the 2 first, thus enabling consistent layering of the 2 components.
smiley
Rod
Thread: Potting Adhesives : for Glass Fiber/Fibre Optic Bundles
14/02/2019 08:45:33
Michael,
When I was scouting around looking for a metallurgical potting compound for home use I plumped for this stuff via Amazon **LINK** It sets hard and doesn't interfere with the grinding and polishing of the specimens. Actually it polishes up very nicely itself and seems very similar to the professional (expensive!) products I used to use in a former life.
Hope this helps,
Rod
Thread: print-offable and laminatable chart
03/02/2019 13:01:07
Guy,
These are from Bradley's Series 7 Manual:
HTH,
Rod
Edit:  Forgot to add the setups
Edited By Roderick Jenkins on 03/02/2019 13:08:04
Edited By Roderick Jenkins on 03/02/2019 13:08:55
Ausee.com.au
