Here is a list of all the postings Enough! has made in our forums. Click on a thread name to jump to the thread.
Thread: Buying a new Lathe....Asian? |
05/10/2020 18:57:50 |
Posted by Jeff Dayman on 05/10/2020 16:43:43: The whole "brokerage" lark is a gold mine. Two minutes of forms work on a computer or on paper by a "customs broker" - $50 to $75 Canadian please. A disgusting no value added ripoff at the border.
Moreover, if you bring in goods in person, or have them sent via Canada Post, they will rarely be assessed duty/taxes on values under $150 and almost never under $100 since it's uneconomic to do so. Courier services and shipping companies on the other hand always assess and charge duty and taxes no matter what the value and charge you for them along with the brokerage charges as you point out. I have to take it on faith that these duty/taxes actually are passed along to Canada-Customs. Edited By Bandersnatch on 05/10/2020 18:58:53 |
04/10/2020 16:54:00 |
Posted by Jeff Dayman on 04/10/2020 12:28:41:
FYI when I last tried to order a few small parts from Grizzly a couple of years ago they refused to ship to Canada. May have changed since then, but I would recommend asking first before placing any order.
I ordered a number of smaller items (lathe chucks, power feed for mill etc) from Grizzly a few years ago without problem - simply by placing the order online. In fact, BB will get stuff in from Grizzly for you, including shipping, customs clearance etc - for a price. Saves the import hassle but it's cheaper to do it yourself. .... Unless, of course, it's changed again. I've no reason to think so but it's some years since I went that route. Edit: I think this explains it
Edited By Bandersnatch on 04/10/2020 17:00:39 |
Thread: Please Avoid Political and Partisan Issues |
02/10/2020 15:57:47 |
Posted by Michael Gilligan on 02/10/2020 13:37:02:
It’s a web forum, with rules dictated by the hosts.
.... and their advertisers. |
Thread: Chatter |
24/09/2020 01:51:47 |
Posted by Martin W on 24/09/2020 01:17:32:
The tool post looks to have chamfered edges which could explain the apparent gap
Enlarging and zooming in, it looks to me more like radiused edges and not nearly enought to give that much illusion of gap. If I had to guess, it would be that there's a shim (washer or washers?) under the toolpost to get the tool height right.
Edited By Bandersnatch on 24/09/2020 01:52:32 |
Thread: Problems reading from a 3.5" floppy disc |
23/09/2020 01:50:34 |
Posted by Colin Whittaker on 22/09/2020 01:57:21:
1) Instead of transferring files with a floppy disc why not use a usb memory stick instead?
- do the machines actually have any USB ports (USB-1? USB-2?) (or an add-on card for them)? - are the versions of Windows capable of driving those ports (or are drivers available)? - Are the Windows/hardware/driver combinations capable of driving modern USB (2) devices? |
Thread: Interference |
22/09/2020 17:16:47 |
Posted by Peter G. Shaw on 22/09/2020 15:35:00:
I seem to think that it is axiomatic that a device built and working correctly to the regulations pertaining at that time does not have to be updated.
I also think that the person concerned was pretty dumb. I'd have said (to the cable/internet people) "until you can show me that it's illegal I'll continue to use it ...... of course you could always buy me a new, modern TV (and dispose of the old one)" Which would be by far their cheapest option (not to mention good publicity). |
Thread: iPadOS 14 |
19/09/2020 17:36:40 |
Posted by Michael Gilligan on 19/09/2020 10:46:56:
Second ... I have now tried, twice, to reply to Daniel’s post on another thread [quoting some of his text] ... On both attempts, the post has not appeared !!
FWIW, Michael, the exact same thing happened to me responding to Daniel in (probably) the same thread. I was using Firefox in a Windows desktop though so your problem may not be related to the iOS upgrade. I thought it might be another thread in process of being locked but I don't know. |
Thread: How to Delete your account and Delete Profile |
19/09/2020 17:28:23 |
Posted by Daniel on 19/09/2020 08:11:05:
While you continue to create new threads, and participate in them, you are keeping yourself
Even "Pence" .... fairly obviously a disposable name? |
Thread: Orion (asterism) |
19/09/2020 15:35:03 |
This perspective view of Orion could have been modelled in a 3D CAD program (with multiple scales). Wish I'd thought of that. |
Thread: close account |
17/09/2020 22:42:06 |
Can't you just change your user name to something like "gone away" (which should keep threads intact)? Delete pics if you must (it would be nicer to leave them). Then delete your login credentials? On the side-topic of posting "I'm leaving" messages rather than just dropping out of sight, I for one prefer the former .... at least for long-term users: - Given the average age of the people here, there are other reasons for people suddenly stopping posting than "going off in a huff". Posting can give some reassurance on that score. - In my experience, anyone who just disappears is usually accused, in absentia, of going off in a huff anyway. |
Thread: Tachometers sensor magnet |
17/09/2020 01:29:22 |
... which probably makes Brian's admonition even more important |
Thread: Ideal Guillotine |
17/09/2020 01:24:27 |
Posted by ega on 17/09/2020 00:15:22:
Thank you. The movement you describe would seem to give a progressive, slicing cut - clever stuff!
So would an angled straight edge .... as on a metal-cutting guillotine. |
Thread: WHY THE TANG? |
16/09/2020 01:15:57 |
Posted by Nigel Graham 2 on 15/09/2020 22:06:16:
Sorry but I don't buy the idea that the tang is purely for ejecting the tool.
But if the tang is (or was) intended for driving .... Edited By Bandersnatch on 16/09/2020 01:17:45 |
15/09/2020 17:30:49 |
Posted by Howard Lewis on 15/09/2020 14:29:15:
Tangs are not intended to provide a drive. The taper does that. Tangs are needed to eject the tool from the quill of a vertical mill. A tapered drift is inserted through a slot in the quill, and a mallet drives the tapered drift through, pushing the tool, to break the taper.
That doesn't really explain it for me, Howard. If that's all the tang does, why not leave off the tang, extend the taper (or relocate the drift slot) and use the drift against the end of the tapered section? |
Thread: A new [to me ] style of scam eMail |
15/09/2020 17:19:45 |
Doesn't your virus scanner handle email attachments? |
Thread: Rotating Photos |
14/09/2020 17:38:57 |
Posted by JasonB on 14/09/2020 16:53:50:
It can depend on how the phone or ipad were being held when the photo was taken, if button on the left then the forum can think it's upside down.
Just to point out that Mike is talking about 90-deg rotation (which is a common problem on this site) and you seem to be talking about 180-deg. I'm confused for one. |
Thread: Mystery Object ... This one has me beat |
14/09/2020 01:21:57 |
Posted by Michael Gilligan on 13/09/2020 20:07:49:
Posted by Bandersnatch on 13/09/2020 17:33:12:
Michael, I presume you tried a Google image search? It didn't give me any results but you're better at that stuff than I am.. The results were pitiful ...
I have to say that my first take on it was of a simple location bracket for a couple of pipes running along a wall (bracket bolted to wall). Guess that's too simple eh? |
13/09/2020 17:33:12 |
Michael, I presume you tried a Google image search? It didn't give me any results but you're better at that stuff than I am. |
Thread: cateracts. |
08/09/2020 00:56:59 |
Posted by herbert punter on 07/09/2020 22:00:10:
Bandersnatch, there’s no sedative, to be honest I don’t think one is necessary.
Do they insert an IV ? |
07/09/2020 18:26:23 |
Posted by herbert punter on 07/09/2020 11:23:26:
While they were working on the lens I could see the most amazing things, bright lights and most impressive, a sort of ‘fluffy white lace parachute’ which came down over me again and again. They tell me that these sights don’t always occur so other people’s mileage may vary.
That sounds like the kind of thing I've experienced under the "sedative" (they deny it's an anaesthetic) they give for an angiogram or when having a stent fitted or colonoscopy. Very pretty actually. Do they give any such sedative for the cataract surgery? |
