Here is a list of all the postings colin hawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Commercial boilers |
05/01/2019 16:18:40 |
Commercial miniature boilers have to be CE marked or they can't be tested by clubs. They have to have a test certificate to be used in a public accessible place. |
Thread: Practice facing |
04/01/2019 14:41:33 |
Keep HSS tools very sharp and with plenty of clearance rake at all cutting edges. I find that industrial recommended rake is too little for the sort of work we usually do. Colin |
Thread: Planned Obsolescence |
04/01/2019 14:32:06 |
My HP printer will happily print my Word documents but when I try to print from the internet it now comes up with " unexpected configuration problem 0x80004005 ". I have little knowledge of these things and wonder if this has been caused by a windows update or some other cause? Colin |
Thread: Small part holding |
01/01/2019 10:59:52 |
Double sided sticky tape. Colin |
Thread: Easy way to centre rectangular shape in 4-jaw |
21/12/2018 10:06:59 |
Place in 4 jaw with packing plates to cover the open sides. Set one face of the job to vertical. Wind in the cross slide to touch the job preferably with a DTI, but can be done with the tool tip, and set dial to zero then rotate chuck through 180 degrees and touch the job again. Note the difference and adjust the chuck jaws to move half of the difference. Repeat for other sides. Colin |
Thread: Modern efficiency !!!!!!!!! |
19/12/2018 10:02:33 |
It seems that an EV may be said to reduce on-the -road emissions and running costs but I am wondering what the true cost is for things like battery lifetime and the replacement of batteries. I haven't seen much printed about that.Colin |
Thread: Year of Engineering |
17/12/2018 12:38:57 |
Duncan, I agree with your assessments, I was about to write the same points myself. Colin |
Thread: What material is it |
16/12/2018 09:56:47 |
Aluminium bronze, horrible stuff to drill. Colin |
Thread: 2.05mm or #45? |
16/12/2018 09:53:36 |
Normally a 2.1 drill would be used for M2.5 thread as there is likely to be slight deformation of most materials as well as the cutting action and that extra 0.05 mm allows for that. Colin |
15/12/2018 17:34:51 |
Qualified engineers are a highly intelligent but too reserved species which is why they are not rated as highly as doctors or lawyers by society. Everybody uses engineered equipment The misuse of the title "Engineer" is another reason for lack of appreciation by the average person. We need to greatly promote knowledge of the skills and mathematical abilities of people entitled to call themselves "engineer". Colin
Thread: Pro’s and cons of owning an horizontal milling machine |
11/12/2018 19:12:42 |
Over many years my ex- scrapheap horizontal flat belt Clarke mill has often been very useful for cutting thick (3/8 to 2) inch steel plate that is too big to fit into my bandsaw. It has been used many times to turn 24 inch and bigger wheels. It's not a massive machine, with 18" traverse, but it is amazingly rigid. I also use the larger end mills and face mills with the job on its side. Very useful machine. Colin |
Thread: Using wood on a metal lathe |
15/09/2018 12:08:06 |
I have often turned wood on my metal lathe ,it needs a very sharp high rake tool preferably a high speed and works best on hard woods. Colin |
Thread: Workshop working tolerances |
04/09/2018 15:38:57 |
Tolerances are for making spare parts interchangeable or special fits such as force fits where a critical difference between parts is necessary so actual precise dimensions are unlikely to be essential on models. Colin |
Thread: Lathe tools |
28/08/2018 11:37:31 |
HSS tools are the most economical way to go for a beginner and will machine all the metals you are likely to use in model making but carbide tips are very useful to machine cast iron at a higher speed. Colin |
Thread: Sealy horizontal bansaw |
24/08/2018 10:19:13 |
A small built up layer of debris can cause your problem if it is the type with plain metal wheels (no rubber tyres). It can sometimes be cured by cleaning the wheels with emery cloth. Colin |
Thread: Engine plans |
07/08/2018 12:29:35 |
When I was working as a toolmaker fractional dimensions were only used for an unimportant dimension such as the base of a drill jig and had a tolerance of +/- 1/64 th of an inch. Apart from standard threads, everything else was dimensioned decimally anyway, normally in "thous", e.g. 1.002, often in "tenths", e,g, 1.0002, so it was very similar to metric dimensioning apart from the basic unit of one inch as opposed to one millimetre. |
07/08/2018 11:05:31 |
Having many imperial tools and old but excellent imperial machines I naturally welcome imperial drawing dimensions but I have had to work professionaly with both systems so I really am not bothered by mixing them when making things. A lot of what I do now is restoring parts of vintage motorbikes which are generally measured in inches anyway. I do have a metric micrometer, digital calliper and a DRO so conversion is easy anyway. Incidentally , what's imperial weight got to do with machining things? Colin |
Thread: Magneto windings |
30/07/2018 21:23:04 |
Neil, thank you for your references, they are what I was really looking for and it has shown me that it would take too much of my model making time to attempt a rewind with uncertain results so I shall now consider whether to get a rewind done or convert to electronic ignition in the interests of reliability. Colin |
29/07/2018 18:34:01 |
Thank you for your advice ,Clogs and Martin, I guessed it might be a bit of a problem so I am more likely to avoid this one; reluctantly as I have always been one to have a go at anything. Colin |
29/07/2018 16:56:34 |
Has anybody tried to rewind a lucas motorcycle magneto and what is the wire spec, gauge, number of turns and length of wire used for primary and secondary windings? I am thinking about attempting this and any information would be of interest. Colin |
