Here is a list of all the postings colin hawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Knurling Help Needed |
15/10/2011 16:53:02 |
I agree with Kwil knurls work best on soft steels.
Colin |
Thread: Screw cutting gears |
15/10/2011 16:47:08 |
I don't have a Myford lathe but I would like to advise that on most imperial lathes you need to keep the leadscrew engaged and reverse the motor to return to your thread start when cutting metric threads as it won't pick up the thread again if you try to use the thread indicator. |
Thread: Scriber |
14/10/2011 17:41:42 |
My scribers are made of 6ins of 1/8 silver steel,ofhand sharpened,1in bent to 30 deg. and hardened at both ends. I have never found a need for a truly central point. |
Thread: How to create a circular scribe |
14/10/2011 14:34:39 |
I very rarely mark anything out but use the lathe or mill to locate holes.This eliminates human error due to eyesight but needs care with sums.I have made 24 equally spaced vee slots on the lathechuck backplate and can index from this,using a small milling spindle to centre drill the holes. |
Thread: Did you make one of these at school or as an apprentice? |
14/10/2011 14:19:36 |
When I was doing metalwork at school and later at a technical college we had to do things like file a square hole to a gauge size and make a square plug to fit it, all in thick steel sheet.We never made anything as interesting as an engine, although we did do beaten copper work which gave me some confidence in boiler making. |
Thread: PeterE - C3 accessories - Tool Tray |
14/10/2011 14:04:46 |
Safety first.Just make sure you get into the habit of taking tools from the side and not across the chuck,one day you may leave the machine running and drop the drill chuck key.I have a tray on the front of the headstock and sometimes let my old flat belt lathe warm up while setting tools.This may be a bad habit but time is precious. |
Thread: thread indicator |
12/10/2011 12:52:46 |
I have made one for my old 7 inch drummond lathe and used it on very many occasions over many years. |
Thread: Making wheels by casting in the spokes |
08/04/2011 21:14:52 |
Excellent video set Jason. Thanks, I enjoyed watching.
Colin |
Thread: Material for smoke boxes |
22/02/2011 16:44:37 |
Hi Michael, Note that if you roll a tube the job will probably have a flat at the start so roll an overlap so you can saw the starting flat off.
Colin |
Thread: Varibale Speed for Drill Press (Induction motor?) |
17/01/2011 17:48:45 |
Hi Steve, I consider it unnecessary to use a hss reamer at such a low speed provided you use lubricating oil on it, the lowest belt speed should be ok. To run an AC motor at a different speed requires a frequency change and this would damage it due to the change in reactance. |
Thread: Case Hardening |
17/01/2011 17:06:49 |
Hi Anthony, the method you use largely determines the depth of case. I have successfully done a case deep enough for heavily loaded ball bearing races, about 2" diameter that had to be ground ,using a tobacco tin & lid with the job packed in charcoal (ex bonfire) and a piece of an old leather belt .It was the second attempt because I had not properly sealed the lid with clay (from the garden) the first time.I cant remember how long it was kept at red heat but I think it should be an hour for every 10 thou of case depth required. |
Thread: Spindle for Raglan lathe |
20/11/2010 16:44:17 |
Hello Ian, I would be very surprised if the spindle is bent only 2 thou.It seems more likely to be the bearing fit. Are both bearings tight? or is one slack allowing the spindle to move as you rotate it? You should test the spindle for accuracy by removing it and laying its bearing surfaces on vee blocks and testing both its nose and bearing surfaces by rotating it under a dti. |
Thread: steel for cylinders? |
20/11/2010 16:01:55 |
Hi Peter, you don't say what the cylinder is for nor the piston material! steam would cause severe rust problems unless stainless is used. I/C engines need a cast iron liner to keep adequate lubrication film although chrome plating has been used.The problem is that soft steel gets picked up causing seizure. Hydraulic cylinders OK.
colin |
Thread: Veteran car models |
02/10/2010 10:22:41 |
Good idea dave, you are right The Engineers Emporium do have a De-dion engine listed in another scale.
Thanks, Colin |
01/10/2010 17:50:28 |
Thanks guys, you have pointed me in the right direction.The"old crocks", I mean veteran cars, London to Brighton run is not too far off and I'm sure to get some more info there.
Colin |
Thread: advice on purchasing a small mill |
13/09/2010 15:10:05 |
Hi James,
Forget about cu.ins/minute, that's for production work in factories.The machine you need for small models is one that is easy to use for the work you expect to do. I have a mini mill from Warco which does most of my work .I have fitted a cheap digital readout to it and am therefore not worried about things like screw accuracy for measuring out hole pitches and distances.The right machine for you is one that will cover the area you need to machine and should have a dovetail slide on the vertical axis.I have access to a heavier machine at my local club.
Regards ,
Colin Edited By colin hawes on 13/09/2010 15:12:54 |
11/09/2010 16:08:17 |
Lots of tech info wanted to facilitate construction of a1903 De-Dion working model car.Please can anyone provide engine cam & follower details? Any other info on all parts of this car would also be appreciated. |
