Member postings for colin hawes
Here is a list of all the postings colin hawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Veteran car models
02/10/2010 10:22:41
Good idea dave, you are right The Engineers Emporium do have a De-dion engine listed in another scale.
                          Thanks, Colin
01/10/2010 17:50:28
Thanks guys, you have pointed me in the right direction.The"old crocks", I mean veteran cars, London to Brighton run is not too far off and I'm sure to get some more info there.
        Colin
Thread: advice on purchasing a small mill
13/09/2010 15:10:05
Hi James,
Forget about cu.ins/minute, that's for production work in factories.The machine you need for small models is one that is easy to use for the work you expect to do. I have a mini mill from Warco which does most of my work .I have fitted a cheap digital readout to it and am therefore not worried about things like screw accuracy for measuring out  hole pitches  and distances.The right machine for you is one that will cover the area you need to machine and should have a dovetail slide on the vertical axis.I have access to a heavier machine at my local club.
                                  Regards ,
                                                  Colin
Edited By colin hawes on 13/09/2010 15:12:54
11/09/2010 16:08:17
Lots of tech info wanted to facilitate construction of a1903 De-Dion working model car.Please can anyone provide engine cam & follower details? Any other info on all parts of this car would also be appreciated.
