Here is a list of all the postings colin hawes has made in our forums. Click on a thread name to jump to the thread.
Thread: How to make a spring |
30/03/2021 10:47:03 |
I would definitely bend that spring at red heat to avoid it cracking .Colin |
Thread: Welding and Pacemakers |
11/03/2021 12:58:56 |
Michael G, many thanks for your references there seem to be an awful lot of precautions to remember when fitted with a pacemaker. I have been recommended for one and it seems likely to make a huge impact on my restoration and workshop activities. Thank you for inviting me to P.M. you, I may well do that at some time. Thanks also to everyone contributing to this discussion. Colin |
Thread: What’s this tap? Thread form? |
10/03/2021 17:24:29 |
Stubby taps always make me think.... Pipe thread. Colin |
10/03/2021 17:18:16 |
Having recently been threatened with the prospect of having a pacemaker I am interested in the implications for arc welding; Has anyone had experience of this as I use mine very frequently without a second thought? Will I have to give it up or wear special protection? Colin |
Thread: A Certain Age |
10/03/2021 16:58:54 |
I was taught the following: "there is a number of items" is correct , "There are a number of items" is not correct because there is only one number. But I see the second incorrect statement all the time. Was my teacher wrong or has the language changed? Colin |
Thread: Choosing a mini mill |
09/03/2021 18:57:54 |
Posted by Pete. on 08/03/2021 22:35:12:
Listed as a drill, so might not get much attention £300 mill I'd buy that for around £400, bit of a refurb and it'd be an OK machine. I don't think a drill with compound table would be suitable for milling as it is designed for vertical stress only and usually has no drawbar to retain a suitable chuck. Colin |
Thread: Dremel type cutting discs |
09/03/2021 18:36:02 |
You need to use the highest speed and a light cut so the motor doesn't slow down too much. I have used various makes to cut nuts and exhaust U bolts under cars where there is no room for an angle grinder. Colin |
09/03/2021 17:55:19 |
Went to my workshop this morning to repair the toaster which I had unplugged and placed near the door so I couldn't forget it then, full of self congratulation, I remembered to also take a data sheet from my desk that I had previously forgotten several times for another project. Almost got to the workshop then realised I didn't have the toaster and went back for it. Reached the workshop again and had forgotten the keys. So I went back indoors to have a coffee break and write down what I had to take with me. Toaster, data sheet and keys. Third time lucky. As a matter of interest the toaster fault was a solidified build up of breadcrumbs preventing an electro magnet from holding the toast down. Senior excuse..... Colin |
Thread: Clarkson, Osborn and ER |
13/02/2021 12:56:18 |
I favour the ER collets for a light machine they can hold any tool with a parallel shank. Colin |
Thread: Chuck runout at different distances from jaws |
13/02/2021 12:48:47 |
For screw on chucks It is vital that the end locating faces of chuck, backplate and lathe spindle are accurate, clean and free from any tiny embedded particles before thinking about test bars. Colin |
Thread: Self Centering Vice |
13/02/2021 12:40:09 |
I always prefer measuring and working from one known datum edge in x and y axes. A vice with both jaws moving would not satisfy this condition. Colin |
Thread: Hey you! What lathe? Why? |
07/02/2021 19:16:24 |
A 1927 7"centre height Drummond because it was going for £20 with accessories, line shaft and ancient motor and I was a hard up apprentice. For about sixty years this flat belt machine, which can easily swing 18" in the removable section gap bed, has been able to accurately machine everything I wanted to do for models and car, motorbike and old machinery restoration. I have recently been given a very rusty old 3 1/2" flat belt Drummond which I have resurrected and now use for small parts; this is a nice machine too. Colin ps I would rather not be known as "hey you" |
Thread: Cutting on return traverse? |
07/02/2021 15:25:04 |
The leading cutting edge of the tool, having done the hard work, may be less sharp than the trailing edge which is cutting on the carriage return. Colin |
Thread: spindle thread |
04/02/2021 16:47:44 |
DC31k is correct; the thread will be 1 3/8 x 8 and it's job is to push the chuck onto the register which IS a close fit. Colin |
Thread: Have You considered getting a 3D printer |
01/02/2021 15:16:39 |
I have considered buying a 3d printer but can't see it being used much so I've postponed the idea. Colin |
Thread: Roller Bearings |
28/12/2020 15:06:55 |
It seems to me that missing rollers could twist sideways and cause some cross locking which could result in the hard rollers skidding and cracking . Colin |
Thread: Micro Milling/Drilling Machine CMD10 |
03/12/2020 19:03:30 |
I absolutely agree with JasonB. Colin |
Thread: Workshop Setup Help |
29/11/2020 17:16:25 |
It is sometimes possible to mount a mini mill, a bench drill and a grinder on a rotatable locking bench top so that the required machine can be brought to the front whilst the other two are behind to save space. Colin |
Thread: Workshop temperature - cold |
29/11/2020 17:08:59 |
If I'm in my shed for more than 5 minutes I need the temperature to be 20 degrees C. I cant do precision work when it's cold so I have got my small lathe in an insulated 8x6 ft shed and only use my bigger workshop if I have to as it takes too long to get warm.. This arrangement works well for me. Colin |
Thread: Level of qualifications in the UK |
25/11/2020 17:20:06 |
I have actually been refused two jobs when I presented the qualifications required because I was considered overqualified. I was about 55 at that time. |
