Member postings for peter ravenscroft
Here is a list of all the postings peter ravenscroft has made in our forums. Click on a thread name to jump to the thread.
Thread: Mystery boiler
12/06/2020 18:10:52
hi alexander
that is a caribou/buffalo boil i have the construction book
regards
peter
Thread: missing magazine?
29/05/2020 17:58:53
mine arrived yesterday
but still unable to contact anyone about the missing me 4638 when i ring all i get is the disconect tone
and still no answer to my e-mail
regards
peter
Thread: non delivery of magazine
22/05/2020 18:34:42
hi can anyone help me
as of yet i still have not got my copy of me no 4638
i have rung the help line and when i press 2 it disconects so i am unable to talk to anyone i have rung at 3 pm
i have also sent an e-mail
regards
peter
Thread: 3.5" Darjeeling Boiler
28/05/2019 15:02:06
hi
just a note to warn any would be builders of the published boiler design in issue 4399 page 312 it shows the back head drawing
it shows a radius of 2 1/4 inches from the centre to the out side it should be to the inside of the flange
otherwise it will be 1/4 of an inch to small don't ask me how i know
regards
peter
Thread: suffolk dredging tractor
26/05/2019 13:47:55
hi
just had a troll on the net an found that western boilers list a Suffolk boiler in there traction engine boiler section
do not know of the cost or delivery
regards
peter
24/05/2019 18:10:00
would love know the outcome of your research into copper versus steel as i have always liked the Suffolk tractor and havee
thought of building on many times i must of missed the copper boiler issue looks as if i'm going to have to delve into my collection
regards
peter
Thread: 45mm Narrow gauge locomotive drawings
21/03/2019 18:09:48
hi mike
get hold of a copy of steam trains in your garden available from camden books not cheap but the best book on building 16mm engines
laser cuts are available from model engineers laser
peter
Thread: z axis arduino
02/12/2018 16:14:59
thanks to all who replied
the reason it would not load was the timerone was not installed i have installed it and loaded it ok
thanks again Dave for comming to my rescue
02/12/2018 14:02:17
hello
the error i get is
exit status 1
error compiling for board arduino/ genino uno
it will load the the script with hello- world so know it is comunicating with the board and loading i think there is an error in the program
regards
pter
02/12/2018 13:38:16
hi has anyone tried to up load the program (sketch ) for the z drive in mew no 275 as i can not get it to load keeps coming up with error all the time
regards
peter
Thread: manual to cnc
15/05/2018 18:55:55
hello all
many thanks for your advice i should have taken silly old duffer's advice you have to read it very carefully i got there eventualy
it is very arkward to say the least will let you know how i got on
regards
peter
14/05/2018 17:46:56
i already have the driver i do not think it is the driver as it will load other programs i have used several arduino units the last on being a dividing head which works ok
thanks for your help
regards
peter
14/05/2018 14:55:45
hi can anyone help me i have bought an aduino and i am trying to load the program grbl as recomended by the article but all i get is copy error message
the ardiino will load other programs no problem i am wondering if anyone else has had a problem trying to load grbl
regards
peter
Thread: John wildings great wheel skeleton clock
17/11/2017 18:09:32
have you seen the series on you tube about building the great wheel clock it is in about 24 parts good viewing
search for clickspring it may help you as it is very detailed
regrads
peter
Thread: Arduino Rotary Table MEW 249
11/02/2017 12:38:33
hi
i thought you might like to see my offering of my dividing head based on the chuck felllows deign with the software from the one in model engineer workshop
regards
peter
Thread: Miniature pressure gauges
13/01/2017 18:25:14
you will find a whole chapter on making pressure gauges in one of kozo's books i think it is the heisler but i am not sure
regards
peter
12/01/2017 18:03:32
thanks carl
regards
peter
11/01/2017 18:11:19
hi john
is that the way you connect remote switches as i am about to wire up a control box when the switches arrive
hopefully i'll have a unit working shortly
regards
peter
10/01/2017 18:27:16
hi john
if daves dont work try
50 btn right
195 up
380 down
555 left
799 select
i had the same problem but is now ok
regards
peter
Thread: swiss molly by don young
18/10/2016 18:06:02
hi
has anyone built or seen a Swiss molly designed by don young
or have a photo of one as i am thinking of building one
regards
peter
