Member postings for D Squire
Here is a list of all the postings D Squire has made in our forums. Click on a thread name to jump to the thread.
Thread: Meccano Model?
02/06/2012 02:17:37
Ramon
Please pass along my congratulations to Lee and Sali. Their attention to planing and detail is amazing. Will you be able to post any more photos showing some of the details? Thanks Ramon.
Cheers
Don
Thread: New technology in Model Engineers Workshop
30/07/2011 02:53:00
To someone that cares
What is the reason for not being able to see the last several words in every line in most of the posts? If I have to guess at what is being said then I probably won't be coming back too often as I like the whole story, not 3/4's of it.
Cheers
Don
Thread: Notification of New Posts to a Thread
14/07/2010 02:39:54
Martin
On Most other forums that I am on I can go back a day, week, month later and edit my own post. I don't have to remain logged into the site to retain that privilege.
I notice that others are commenting about editing as well so maybe there is a problem with the board.
Cheers
Don
13/07/2010 05:04:26
OK, Stop the presses. Backtrack. I found my answer. It was hiding way down at the bottom of the page way below the reply box hidden behind the plastic frame that goes around my monitor. This is what it looked like.
Bookmark this thread (you will receive email notifications whenever someone adds a reply)
So I clicked on it and now everything is OK for the present.
Next question? Why could I not edit my post above instead of starting a new post?
Cheers
Don
13/07/2010 04:40:09
When reading a post sometimes I would like to mark it so that I am notified if any new replies are made to the post. I have figured it out on other forums but this one seems to be a bit tricky
I also searched through this forum using "notify" "notification" and "reply" and got 2 hits, neither of which answered the question.
I see that there is a check box at the bottom of this post that I can check that will get me a notification if someone replies to this thread. It also says,  (This will add the thread to your Bookmarks list).
Since each thread is different does this mean that if I subscribe to 50 different threads over a period of time that I am going to have 50 occurrences of Model Engineer in my list of bookmarks?
Cheers
Don
Thread: Copyright issues
29/05/2010 03:03:12
Posted by David Clark 1 on 28/05/2010 21:22:32:
Hi There
As far as I know the article is genuine.
I knew it was taken from the posts but believe the original author is aware of it being published. As far as I know, nothing wrong has been done or I would not have published it.
regards David
PS This thread will self destruct (or delete itself) on the stroke of midnight.
 I hope that you are joking about this thread self destructing at midnight. because if that is the way the board is run I want no further part of it..
 Cheers
Don
rapid Direct
Dreweatts
walker midge
JD Metals
