Here is a list of all the postings Jim Guthrie has made in our forums. Click on a thread name to jump to the thread.
Thread: ML10 apron issue with half nuts |
04/08/2020 11:39:38 |
Posted by Graham Meek on 04/08/2020 10:47:13:He also fitted the Super 7 Cross-slide to the ML 10 lathe,
something I think was later fitted by Myford's to one variant of the ML 10 as standard.
It was actually an official upgrade kit. I remember trying to order the indiviual bits from Myford and the nice lady taking orders advised me of the kit, and it was significanlty cheaper than the sum of the prices of the individual parts. The longer crosslide is an absolute necessity on the ML10 if you use a rear toolpost. Jim. Edited By Jim Guthrie on 04/08/2020 11:40:15 |
Thread: Complicated post |
06/03/2020 10:32:32 |
One important measurement that I almost forgot was clearance to extract a collet drawbar. I've got a low ceiling in my workshop and it was fortunate that I have just enough room to extract the drawbar from my Centec 2A. It is the reason that I have never got a raising block for the machine.
Jim. Edited By Jim Guthrie on 06/03/2020 10:33:08 |
Thread: Are there any left? |
13/09/2019 09:16:30 |
I do remember the Government Surplus shop in Stockwell Street in Glasgow. When we did shopping trips to Argyll Street in Glasgow, my mother would often go to the china bazaar on Stockwell Street under the St. Enoch station arches and my father and I would go a few yards further down the street to visit the surplus shop. It was a treasure trove of bits for a young boy and my first transistors were bought there - red spot, green spot and yellow spot as far as I can remember. The transistors worked - soldered with a large copper bolt heated on the gas hob.
Jim. Edited By Jim Guthrie on 13/09/2019 09:17:18 |
Thread: What started your interest? |
23/07/2019 13:03:21 |
One day in the mid-1950s, my mother returned from her shopping trip with a copy of the New Model Engineer for me. I think it was the first issue of the re-release of the magazine in a larger and more glossy size after the smaller wartime issues. If you had known my late mother you would have realised how far out of character this was. She had absolutely no interest in things mechanical and she probably thought that it was similar to the Meccano Magazine which I already got. So an eleven or twelve year old was introduced to model engineering with absolutely no knowledge of machine tools. But I did start to pick things up as further issues appeared since Mother had gone as far as putting a firm order from day one. I think I remember that it was the LBSC articles that I understood best. I eventually got my hands on a lathe at school in my later teens but it was a few years more before I got my first lathe. Jim. |
Thread: What lathes have you had? |
21/07/2019 18:24:29 |
Quite a short list compared to some so far. Started with a very old ML2 bought for £10 which taught me what to look out for. Super Adept - which taught me how to centre quickly in a four jaw. ML10 bought in Ted Heath's year of the three day week Cowells ME90 The ML10 is still my favourite although the Cowells gets preferred since it is inside. Jim. |
Thread: Sieg KX1 next step |
04/07/2019 23:30:02 |
When working with the KX1 toiday, I just remembered another thing from my experiences at the start. I suspected that my spindle speeds were not as requested by the GCode. So I got a cheap tachometer which I checked against my Cowells and found it pretty accurate. I then checked the KX1 spindle speed and it was running much slower than reported by the Mach software. It wasn't too difficult to adjust to get the correct speed and the life of my small cutters improved no end.
Jim. |
03/07/2019 09:06:38 |
I found the same problem initially with my KX1 where I wanted to use small diameter mills and the recommended spindle speeds were much higher than the KX1's 7000rpm. But I found a feed and speed calculator which allowed for wide spindle speed ranges and I used it to calculated feeds and speeds for the typical mills I would be using - 0.5mm - 2mm carbide slotting cutters. I can't now remember which piece of software it was since it was quite expensive and I used it on its 30 day trial period. I still had to do a bit of experimentation and it got a bit expensive for a while with the ends of small carbide bits pinging off during cuts.
Jim. Edited By Jim Guthrie on 03/07/2019 09:08:54 |
Thread: Myford ML10 motor drive parts and belt guard |
03/05/2019 17:06:15 |
Roger,
My ML10 is about the same vintage as your father's machine - 1973. Here's a picture of the belt tensioning arrangement on the machine which is as original. The central nut acts on left and right hand threads on the threaded arms. The operating arm is still there on your machine and the original linkage might be hiding away in a tin in the workshop somewhere. The setup could act as a clutch of a sort but would not lock in the slackened position so you would have to have used one hand to hold it which would limit what you could do. Perhaps you father's modification was to give a locked open position. Jim. Edited By Jim Guthrie on 03/05/2019 17:07:48 |
Thread: Its nearly there ! |
24/03/2019 17:58:42 |
Posted by Bazyle on 24/03/2019 15:51:34:
Looking good. I can still remember looking enviously at one at the ME show in about 1981 when they cost £600 without tray, motor, or chuck and were the cheapest lathe at the show apart from a tiny flexispeed.
Mine cost just over £100 in 1973 (Ted Heath's three day week year) and I remember that the price doubled when I added in the three jaw, four jaw and Jacobs tailstock chuck. So that's a fair bit of inflation given that my lathe was the original plain bearing version and your 1981 version probably was a Speed 10.
Jim. |
Thread: KX1 CNC Mill Clearance Offer |
01/03/2019 08:31:30 |
Jason,
I used a feed and speed calculator some years ago to get the optimum feed speeds for my small diameter cutters. I can't remember which actual program it was but it certainly cut down my cutter breakage - before that it had been an expensive exercise finding out the hard way. I've just had a look at another feed and speed calculator available online and for a 3mm diameter cutter with a max spindle speed of 5000, which were your settings, the feed rates are well down into the low hundreds. It doesn't cover plastics but I usually double the feed speed for brass or aluminium. The problem with plastics is that a calculated high feed speed is useless since the material will melt, or just distort in front of the cutter. I do a lot of machining of thin styrene sheet and that can happen. The plastic sheet can also lift with the spiral action of the cutter, overcoming your method of holding down. https://littlemachineshop.com/mobile/speeds_feeds.php For my small size mills I am way out of the manufacturers' specs since they expect me to have a spindle speed well into five figures.
Jim. Edited By Jim Guthrie on 01/03/2019 08:33:23 |
28/02/2019 22:40:52 |
That's some feed rate. The highest G0 rate on my KX1 is 1000mm/min and my G1 rate rarely gets above the low hundreds. I work mostly with small cutter sizes of 0.5mm to 2mm and with a max spindle speed of 7000, feed rates tend to be in that low region. I'm just trying to visualise my KX1 working at 2500mm.min.
Jim. Edited By Jim Guthrie on 28/02/2019 22:42:33 Edited By Jim Guthrie on 28/02/2019 22:43:01 |
24/02/2019 00:37:59 |
Jason,
If this was the problem machine which might have been messed around with to some extent, then one thing to check would be the taper gib in the head. If the gib has got end play then it can lock the head up when travelling fast in the up direction with the wide end of the taper to the top of the column. That's the way it is in the KX1. That gib is the one thing I curse in the KX1 and it gave me a lot of trouble getting it right when I decided to try and adjust it some years ago. You're fighting the weight of the head, the nod of the head and the gas strut to get it right and I found it very easy to get it wrong, causing the head to be either too loose or too tight. I often wondered why I couldn't have a nice parallel gib strip with multiple adjusting screws.
Jim. |
22/02/2019 11:06:15 |
Posted by JasonB on 22/02/2019 10:37:20:
My understanding is that this is an OEM version of Mach3 not just a generic version that anyone will buy which comes with all the settings for the specific Sieg machines pre set up,
I would agree. I think that was the way John set up the original Mach versions, basically to avoid a new (to CNC) user getting embroiled in some of the finer points of Mach3 setup. I know that I found myself in deep doo-doo when I downloaded another version of Mach and I have always kept the original Seig DVD installion disk with the setup files handy. John's son Adam also did a set of screens for Mach 3 which were an improvement and I'm not sure if these are readily available today. IIRC you purchased the screens from Adam and he set them up to show your name in the profile box in the bottom right corner.
Jim. |
18/02/2019 20:30:14 |
Neil,
The nearest I get to hand operation is to use the MDI interface in Mach3. I use that quite often to do simple cuts and facing. Once I get into the swing of it, it's almost as quick as using handwheels. I've got a Centec 2A in the outside workshop that's hardly turned a wheel since the KX1 arrived.
Jim. |
08/02/2019 21:20:56 |
Ketan,
What about spares for the existing machines? I have had occasion to get a replacement drive belt for my KX1 a couple of years ago and I would be interested to know where spares might be obtained in future. I note that John's support forum stopped working a few months ago and I suspected that someone had turned it off. Over the last nine years I have found the KX1 very reliable and from the traffic on John's forum, it would appear that there weren't all that many problems from other users. The KX1 and KX3 must have been unusual in the UK in having, effectively, a supplier supported user forum. I think most people purchasing hobbyist machinery depend on more general forums on the internet for any ongoing support they may require.
Jim. |
Thread: Further thoughts on Fusion 360 |
02/02/2019 11:27:25 |
I got a 3D printer last November so I had to learn a 3D CAD program to make any decent use of it. So I chose to go with Fusion 360 after looking at a few others and the learning process has been close to head banging. The video tutorials on Youtube have been a help and certainly give a good overview of what is achievable with the program. But when I actually got down to drawing up my own designs I found the videos of quite limited use since if I wanted an answer to a specific problem, trawling through hundreds of videos to find an answer was impractical. So I found that typing the problem into Google and looking through the answers became my main method of learning - the Autodesk Fusion 360 support blog usually came up with an answer. Or I just thrashed around in the program itself to see if I could hit on a solution. I now feel I'm getting somewhere but it took several weeks of banging my head against a wall until I started getting results. One thing I am finding out is that its parametric rules can provide some peculiarites in 2D sketching which I've never found in 2D CAD programs so I'm having to find ways around them. But I'm getting there.
Jim. Edited By Jim Guthrie on 02/02/2019 11:28:37 Edited By Jim Guthrie on 02/02/2019 11:29:02 |
Thread: ML10 |
14/10/2018 11:00:38 |
James,
I've got an ML10 and I keep an eye on the prices of them just to make sure that my daughter knows what price she might get after I've moved on.
Jim. |
Thread: Myford ML10 pulley diameter |
06/08/2018 12:58:22 |
Mine is the original ML10 bought in 1973. The motor pulley is 2 1/2" overall diameter and the countershaft pulley is 7" overall diameter. The depth of the V belt groove is 7/16".
Jim. Edited By Jim Guthrie on 06/08/2018 12:58:59 |
Thread: Microsoft Windows 10S - One to Avoid? |
17/07/2018 08:37:43 |
Posted by Vic on 16/07/2018 22:48:39:stop you provided you have administrator access.
If Microsoft were really copying Apple they would give their OS and productivity software away for free as Apple has done for several years.
But Microsoft don't have the advantage of charging over-inflated prices for hardware. Jim. |
Thread: Eccentric's "Turnado" |
17/07/2018 08:32:07 |
Posted by Neil Wyatt on 16/07/2018 21:45:22:
Posted by Jim Guthrie on 12/07/2018 17:56:11:
The 2mm Society got there over twenty years ago.
Jim. Edited By Jim Guthrie on 12/07/2018 17:56:41 Peter Clark's 'fonly was great fun but was simply a feehand turning block without all the jigs. Neil, My point was that his tools for use on the lathe - at the bottom of the PDF pointed to - were the same design as the Eccentric tool-holder. I remember seeing the Fonly and its tools being demonstrated at the London model railway exhibition in the 1980s and I always meant to make some of the toolholders to use on my lathes, but never got round to it.
Jim. |
