Member postings for MICHAEL Moore 1
Here is a list of all the postings MICHAEL Moore 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Mini bench saw
22/03/2020 21:36:38
Thanks for your advice.
Looking for a set of plans to build a 3 in 1 metal worker and purchasing a band saw.
22/03/2020 14:40:31
Hi all,
I hope you are keeping well.
Can anyone advice on purchasing a small bench saw that can cut brass and aluminium for model making.
The blade capacity should be 4 inch or thereabouts.
Also is there tooling for small high speed milling and cutting below a 2mm cutter , manual and small cnc units.
I have a Myford Super 7 with gearbox and I fittedr an Allendale DRO and I also have a manual Quantum Mill.
Any help would be greatly appreciated.
Thanks in advance
Michael
Thread: Steam Boiler
08/04/2019 15:32:49
Hi
Can anyone tell me if inconel 740 steel can be used to build a boiler for a 5ich gauge loco
Thread: Carbide tip holders
18/12/2017 10:29:21
Hi,
Can anyone recommend a set of carbide tipped holders plus inserts for a Myford Super 7 and an ideal Quick Change Toolpost to hold said tip holders.
Thanks in advance
Michael
Edited By JasonB on 18/12/2017 10:38:16
Thread: getting a mill over to Ireland
09/07/2017 19:52:07
Michael from Kildare here.
I bought a Optimum bf 20l mill from Millenium machinery in Athlone , €2000 , and it is a great little mill , I also purchased the Allendale Dro kit for a mill although €500 + it is worth it
I also have a Myford Super 7 with the Allendale Dro and a drive converter which is ideal for the hobby
I buy in all types of machinery from the UK and a pallet from inside Manchester/Birmingham/Bristol is about €200
The other side of that line is twice that
Thread: Boiler Welding
29/06/2017 18:07:47
Looks likes Tig walking the cup....
Nice work
Thread: Emco compact 5 cnc lathe with Welturn
26/02/2017 20:56:30
All the electrics at the back are torn out and damaged and the front buttons panel is in a bad way.
I was hoping to fit new steppers through an appropriate motherboard and power supply through a suitable pc / laptop
I hope this is possible
26/02/2017 17:00:01
Thanks for the reply. Unfortunately due to a lot of damage and missing parts for the Emco I need a lot of new bits so I want to do it as a cnc. Any help sourcing the parts is greatly appreciated.
Thanks
24/02/2017 12:05:22
Hi all,
Michael Moore from Ireland here.
I have an x school Emco Compact 5 that I am looking to upgrade to a cnc jobby.
I just started following an American site who have done this
http://www.cnczone.com/forums/emco-cnc-machines/108826-cnc-machinist-posts.html
https://en.industryarena.com/forum/build-thread-upgrading-emco-compact-5-cnc-current-technology--108826-2.html
Has anyone attempted this sucessfully and can you give me any advice please.
Thanks in advance
Michael
Thread: Locomotive Modelling in Ireland
29/12/2016 13:08:58
Hi all,
Michael from Ireland here
I need to sharpen end mills and drill bits as I work a lot in stainless
Whats my best option.
I have about £500 to spend
walker midge
JD Metals
rapid Direct
