Member postings for Kenneth Lindeman
Here is a list of all the postings Kenneth Lindeman has made in our forums. Click on a thread name to jump to the thread.
Thread: Springbok articles
15/04/2019 11:41:00
Try this website there is a lot info available or mail me
Thread: Pratt Burnerd PC-15 Collet chuck
03/05/2016 09:46:07
I have acquired a PC 15 collet chuck but it needs some TLC. Does anybody have a catologue or spare manual for one
Thread: Craftsman 15f drawings
29/10/2015 13:53:12
I have the SAR drawings as I did purchase the complete CD's with all the SAR drawings. I picked up a part build project form a deceased estate, which was build using the Craftman drawings. The drawings were also part of the lot but page 1 & 2 had been laying in his workshop for a while and have be eaten up by rats by the look of it.
I wanted to use the drawings to see what had been done and what is the standard of work done. The lot also included a lot of castings which I am presuming also came from Craftman.
29/10/2015 08:48:19
Did anybody find a copy of the Craftman drawings for the 15F. I have a set but the first 2 pages are in such a bad condition that its falling apart and cannot read anything
Thread: New ideas for tool grinding in the workshop
04/06/2015 14:28:09
Hi Paul
I like your concept drawing. I have been looking at the Quorn design for a while and there is just to must work. Your design with the linear rails will be quicker and easier. What cad package do you use. I work in Solidworks and i am willing to work on the design with you
Kenn
Thread: Copper pipe bending
10/03/2015 07:20:49
Give this company a try They have a product called Polybend which is healthy to use http://www.bendalloy.co.uk/ and are will the sell small quantities.
Thread: Missing ME And MEW
05/03/2015 06:20:07
I am the vice chairman of the Cape Town Society of Model and Experimental Engineers. We were formed in 1907 and have a amazing library which has a original copy of both ME and MEW from there first edition. Every year we take our magazines for the year and have them bound. But somewhere along the road we have lost/not received some issues
We are missing ME no 4466 and 4498 as well as MEW 204, 205 and 210
If there is anybody who could help us get copies to complete our sets, this would be greatly appreciated
Thanks
Kenn
Thread: Split axle boxes
04/03/2015 06:25:15
Hi Guys
I am busy building a LNER B1. I am also making split axle boxes and have used Sellock (spring pins) which seem to to working. They are quite easily fitted and taken out using a dowel punch
Ken
Thread: blackgates engineering
10/02/2015 08:00:00
I presume you are talking about the Southern L1 (Maid of Kent) I am busy building one in 5inch I have redraw about 70% of the drawings. Mine is a inside cylinder version
Thread: schools loco
13/06/2014 12:45:30
Hi Very good drawings. What program did you use. I am busy drawing a Maid of Kent and LNER B1 using Solidworks
Thread: Collets help
04/06/2014 08:54:22
I finally bit the bullet and have brought myself a ER40 milling holder but without the collets. So now I need to get some collets which I will get as needed. But I have a question, the collets are available in 1 mm increments, So it your milling cutter shank is 12 mm, do you get a 11-12 mm collets or the 12-13 mm collet.
Thread: Adept No.2 Shaper
21/02/2014 11:09:45
Thanks Ian You have given me a lot to think about. I am going to put on a pulley with at least 3 steps so that I can have a selection of speed. The Adept seems to have the same speed for both the forward and back stoke, which is not the same as the bigger machines which do have a quicker back stoke. Yes the length of stoke will affect the speed so I will also have to remember this.
Regards Ken
21/02/2014 06:46:25
Well this is my latest idea. I have a 8-1 reduction gearbox which I am thinking of connecting between the motor and the shaper. This would reduce a motor with a speed of 1450 rpm to about 180 rpm. It taken 4 turns of the feed shaft to complete 1 stroke on the shaper. This would then give me a speed of 45 strokes per min. Would this be acceptable for mild steel
20/02/2014 06:37:37
Hi Guys Was a my model club which is based is Cape Town last night and was given a Adept no2 powered shaper. Its pulleys are missing. Could somebody give me the pulley sizes. It will save a lot of trial and error on my side
Thread: Mercer Dial Indicator
14/02/2014 06:10:53
Here is a very interesting piece I found on how to make your own extension for your dial indicator
http://www.homemadetools.net/dial-indicator-holder-5
Thread: Is it time to give up?
11/02/2014 07:03:23
Does anybody have copies of series in vol 97 - 101
07/02/2014 10:40:56
Thanks for all the feedback. I will be trying it out this weekend. I also have a normal clock on magnetic base. I am sure I will be able to align anything now. O I forgot My favorite the edge finder.
06/02/2014 07:01:31
06/02/2014 06:59:40
I pick up this at a sale and was wondering if anybody knew how it worked
It's a Mercer model 107A dial indictor set
Thread: Maid of kent
05/02/2014 08:07:07
So were are all the Maid of Kent owners/builders out there. I am busy building a MOK and would like to chat to other owners /builder
Rapid RC
Dreweatts
