Here is a list of all the postings Saxalby has made in our forums. Click on a thread name to jump to the thread.
Thread: WHERE ARE THE SHAPER USERS ? |
26/09/2016 11:37:10 |
I wouldn't be without my Boxford 8inch shaper. Will have to be prised from my cold dead hands. I have used it a lot for cutting dovetails, and cutting internal keyway slots in gears etc, and the finish on flat surfaces is can look almost as if it has been ground. |
Thread: Who sells horizontal arbor milling cutters? |
17/08/2016 18:02:31 |
Try gandmtools - bought lots of various sizes from them for my Senior horizontal mill. |
Thread: Drain Cock with handles needed - any ideas? |
19/07/2016 08:44:11 |
Made the drain cocks and water gauge cocks for my Atkinson lorry using JasonB's method and was well pleased with how well they works - go for it. |
Thread: Boxford Shaper Motor |
26/05/2016 08:56:02 |
Regards BarryHi Alan, Heres the setup I used on my oxford to cut some gear keyways. Not shown, but made a plug to fit the gear bore to align the cutter bar Regards Barry
Thread: Boxford Little Giant Toolpost Grinder Drive Belt Source? |
15/03/2016 15:35:13 |
If other sources fail. then Tony at Lathes.co.uk can make them to order. |
Thread: Cutting Internal threads |
18/12/2015 11:35:03 |
Are these the sort of thing the OP had seen. Bought a load years ago (£5) at a motorcycle auto jumble. Various Whitworth form threads. |
Thread: 13A Plug / Socket |
11/08/2015 10:40:09 |
Still used a lot in computer rooms. Earthed down to a separate clean earth for computer equipment use only - stops unautherised equipment being plugged in. |
Thread: Orphaned steady |
22/07/2015 16:15:38 |
Same orientation of the flat and "V" as my Boxford although to bib. Possibly and old pre war Southbend ?? |
Thread: Tail alignment and gear handle play |
03/07/2015 20:15:15 |
John, Yes,the £15k was for the TS version. When I bought my ME10 it cost I think £1300 or so, but the add on even more. Got all the receipts somewhere for the Cabinet base, Vertical slide, taper turning attachment, metric change wheels, collets etc etc. nearly £3000. Barry Just found the price list from 2011 330TR (Toolroom Lathe) £14,750 + Vat Edited By Saxalby on 03/07/2015 20:19:41 |
03/07/2015 18:03:58 |
Last I enquired of prices from Boxford the 330 lathes started at about £15000. |
Thread: Project engine |
30/06/2015 15:35:25 |
Suffolk Dredging Tractor for sale at "stationroadsteam.com" |
Thread: Line Boring (demo) |
27/06/2015 09:17:42 |
I agree with Paul - far to longwinded video's. I have used multicore solder coiled round the boring bar. One or two layers depending on space available - works just fine. |
Thread: 6 BA hexagon headed screws |
23/06/2015 16:16:08 |
Geoff, Hope you get what you need from the supplier you mentioned. If not, another possibility is Clerkenwell Screws. They used to stock lots of BA bolts.
Thread: Recommended collet chuck |
01/06/2015 11:52:21 |
CTC Tools do ER11,ER16,ER20 and ER25 with a MT1 Shank. http://www.ctctools.biz/er-collet-chucks/?sort=featured&page=1 Oops beaten to it by BOB Edited By Saxalby on 01/06/2015 11:53:09 |
Thread: Stuart V10 Cylinder Casting |
30/05/2015 18:56:32 |
One method I have used with success is a hollow drill. Take a piece of silver steel of suitable size drill it out to the thread clearance size and file / machine a couple of cutting edges. (Like a hollow end mill really) Harden and temper the end. Then carefully and slowly drill out around the broken tap. Then plug hole as above. Cant remember if I read about the method here or some other forum
Thread: 3c collet chuck |
21/05/2015 20:50:41 |
Pic showing the spindle nose piece: Also sizes if you want to make an adapter:
20/05/2015 20:09:07 |
Hi Naughtyboy, I have 3C collets for my Boxford, and as Jason has said, the Southbend and the Boxford use a 3MT to 3C adaptor which goes in the spindle. There are some US companys that still make these adaptors. But easy enough to make. If you want i can give the dimensions etc of mine. Regards Barry |
Thread: How many is too many? |
20/05/2015 19:23:54 |
Yes the 14 coupled Russian Andreev loco. Maybe do one in 7 1/4 gauge. Anyone know of a club with a long straight track? |
Thread: What change gears are these |
17/05/2015 11:13:58 |
Hi Bazyle, My Boxford gears (supplied by Boxford) are plain as per Alans picture. Only the large 100/127 pair have cast in thinning. Regards |
16/05/2015 14:47:46 |
Hi Alan, My Boxford gears are 18DP with a 9/16 inch bore. My 40T gear is 2.337 inch dia. Regards |
