Member postings for Peter Etherington 2
Here is a list of all the postings Peter Etherington 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: PM research #3a steam engine
31/03/2021 17:52:13
I think I will go down the route of the Stuart Models S50. Many thanks, Peter
30/03/2021 18:23:12
Hi, I`m thinking of building a PM research #3 steam engine. This will be my "first blood" into machining. I have a lathe and mill. Would anyone recommend this as a first engine? Peter
Thread: what size vice for mill
29/10/2020 15:05:33
The reason im going for the er32 collet chuck is that I want one for my lathe, so two for the price of one.
26/10/2020 09:29:04
All part of the excitement
25/10/2020 19:07:16
Already on list with ER32 collet chuck, 123 blocks, angle block etc, also thinking of adding DRO. Peter
25/10/2020 17:49:39
The 3 inch radial from Arc, it is not as big as the 3 inch Versatile from the same supplier
25/10/2020 09:33:09
Thanks Jason, I will go for the 3" with it only being a small mill and i`m only building small scale steam loco`s (16mm) It`s man thing I think, always wanting something bigger smiley Peter
23/10/2020 18:25:42
Ta
Thread: riveting
23/10/2020 12:42:20
thanks john
23/10/2020 10:38:40
Thanks guys, Peter
Thread: riveting
23/10/2020 10:37:58
Thanks very much. Peter
22/10/2020 19:41:51
1/16 brass rivets to sandwich very thin stainless and thin aluminium
Edited By Peter Etherington 2 on 22/10/2020 19:44:10
22/10/2020 19:34:04
Just bought a mini mill XJ12-300 and the table size is 460 x 112mm, what would be the biggest vice I could reasonable put on it. Many thanks, Peter
Thread: riveting
22/10/2020 18:42:25
Just wondering if I could use one of those cheap 1/2 ton arbor presses to set rivets in some thin plate. Peter
Thread: interest renewed
19/10/2020 18:28:31
Just a quick update, I have taken the bull by the horns and bought a Amadeal XJ12-300 mill, just the right size for me and to get it in my workshop had a major sort out. Happy days. Peter
Thread: joining metals
30/09/2020 17:06:14
Thanks very much for all the interesting information, Peter
29/09/2020 18:32:22
Thanks John
29/09/2020 18:28:11
hi, can anyone tell me what would be the best way to join two pieces of 0.50mm stainless steel together other than riveting. I am making a 1/24th scale fairground ride called a Skid and have used stainless for the bodies of the cars (two pieces) probably should have used brass, but all I had was the stainless. Peter
21/09/2020 19:29:05
Thanks, I was considering a set of collets. Peter
20/09/2020 17:48:09
Decided to go for the ER 32 lathe chuck and vertical slide. Like "old mart" said when I can afford a mill I can sell these bits on. By the way Doug, no theres no canoe in the rafters of my shed, only model aircraft and boats mate (no where else to put them) Peter
JD Metals
