Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Any idea what these are for? |
21/05/2022 13:02:58 |
Possibly screw cutting tools |
Thread: T-slot cutter |
20/05/2022 19:49:09 |
Must be lucky then, haven't broken one in 30 years too b----dy expensive!! |
Thread: What Did you do Today 2022 |
20/05/2022 19:46:23 |
That's a nice bit of toolmaking Craig |
20/05/2022 13:57:39 |
How do you manage to break a commercially made T slot cutter??? |
Thread: This trolley/cart could be useful |
20/05/2022 13:50:00 |
I suspect that if you put 100kg on it you would have a hard job to move it over a rough surface and as for having deeply treaded tyres ,what makes the difference none of the wheels are drivers. Instead of a rubbish sales pitch it would have been better to attend English lessons. |
Thread: All things Beaver Mill |
16/05/2022 21:57:26 |
That gauge looks unfinished, I have the brown & Sharpe version that must be about 60 years old and it is a joy to use all the sizes are beautifully ground. Is it possible its hooky? |
Thread: Hylomar Hylotite Red 100 |
16/05/2022 11:27:37 |
On the boat we just leave it for 20 mins and put together, no leaks so far!!! |
Thread: A question about reamers and hole tolerances. |
16/05/2022 10:15:17 |
Floating Reamer holder as well!!! |
Thread: Cowells Milling/ Z axis design |
15/05/2022 21:35:40 |
Suggest you trawl the sherline website |
Thread: Myford ML4 cross slide |
14/05/2022 17:59:13 |
Is it possible to open up the original threaded hole and fit a top hat bush with two screws (a la ML7) and fit it with 2 ba screws. |
Thread: Wyvern crankshaft question |
14/05/2022 17:52:46 |
Modern single motorcycle cranks are a press fit but also the shafts are taken from liquid nitrogen in a controlled atmosphere, we can't do that plus our engines do not put out massive amounts of hp per cc |
Thread: Re-boring Grind Wheels |
14/05/2022 17:44:25 |
Yes with you Martin they are moulded with the centre bush in the mould. |
14/05/2022 17:42:23 |
Its the same design on my shoreline maybe a look at their site might. There is also Taig or Peatol |
Thread: Almost 4BA but not quite |
13/05/2022 21:40:58 |
good idea Bazyle a bit like spill reaming only with threads. |
Thread: Drone advice needed, please |
13/05/2022 12:52:23 |
plus you need a licence to take photos with it! |
Thread: Barograph 'stiction' |
13/05/2022 12:49:32 |
Its Russell scientific in east dereham norfolk that is closing, so if you want any bits get in now. |
Thread: Self extracting drawbar for mill |
12/05/2022 21:18:04 |
Chris mate, is it possible to have a vet shaped washer above the nut? |
Thread: Info required Stuart Turner 600 i/c gas/petrol engine |
12/05/2022 21:14:25 |
Usually for wet liners the cal block has grooves machined in to take 2/3 the depth of the O ring, the ring and liner are then liberally coated with blue Hylomar and GENTLY pressed in by HAND. You can bolt a strap across the liners until the cyl head is fitted but these must not be very tight. Wouldn't mind a pound for everyone of those I've fitted. |
12/05/2022 21:06:49 |
And the countries last Barograph and Barometer maker is closing for good next month after something like 175years!!! |
Thread: making a Square |
12/05/2022 21:03:33 |
Made mine as well, you won't make anything if you don't try! |
