Here is a list of all the postings Raymond Anderson has made in our forums. Click on a thread name to jump to the thread.
Thread: solid edge 2D |
05/12/2020 13:31:50 |
It matters not one hoot to Solid edge if Office is installed or no. So go for it. |
Thread: New Lathe at Lidl |
01/12/2020 18:51:28 |
Obviously built down to a price [ rather than up to a standard ] so using that mantra its no different to the hobby machines many members on this forum have. so if it does a good enough job within its capabilities then good. |
Thread: Evolution of a Boring and Facing Head |
16/11/2020 17:09:13 |
As usual Gray, superb workmanship. and so well designed. Simply stunning pieces of kit. |
Thread: Stellite 98M2 tools |
25/10/2020 16:01:17 |
Certain grades of Stellite are still used today, on heavily interrupted cuts on Nickel or Cobalt based Super alloys. I actually had a blank approx 40mm square x 200 long, never needed it and has now gone "Walkabout " |
Thread: Changes to Fusion 360 Terms |
24/10/2020 18:59:41 |
The newest commercial version of Solid Edge is now 2021 [ which now includes sub division modelling ] will be a few months until the 2021 community edition / Student edition appears. |
24/10/2020 15:10:35 |
Bazyle, Just type in Solid Edge community edition and that should take you to the official site. I would have created a link but not sure the procedure for this site. |
Thread: Bench block for small parts - ice hockey puck |
11/09/2020 17:20:34 |
Sacrilege.... Hockey pucks are for HOCKEY. only joking, fine to see they have a few other uses in addition to their main purpose. Another area at which the little buggers really excel at is... demolishing parts of the human body. [ been there ] |
Thread: Scaling back forum activity |
10/09/2020 17:54:39 |
Sad to see Barrie cutting back, I liked seeing his input. All the best on your other forums. Hope you are getting on well with Solid Edge |
Thread: Who trains these ideots? |
20/08/2020 18:02:47 |
s am longley, IF the job only demands easy brickwork , what IF the job demands something other than the easy stretcher bond ? or even Granite ? 350 Facers per day thats only 5 barrows worth. Now try taking that up 7 storeys and see how PLUMB you can get it. Maybe you should try a corbelled arch or 2 No on second thoughts... just stick to stretcher bond. |
18/08/2020 17:45:54 |
I feel every trade is "Dumbing " down these days. When I served me time [ Bricklayer ] I did 5 years. Stone masons were 6 Years Joiners were 4, now it is 5 for Masons 4 for Bricklayers and 3 for Joiners . and it's not just the Structural trades even the services trades are dumbed down. You just need to look at the quality of tradesmen now compared to even 20 years ago . I see it every day. |
Thread: HSS/Tungsten Tool Honing Machine |
04/08/2020 17:38:55 |
Superb. |
Thread: Quality small metric spanners |
30/07/2020 18:00:36 |
Stahlwille. and, NO... they are not just for the avation industry [ as some folks think ] Pricey though but superb gear. |
Thread: resumption of delivery of ME to Canada |
17/07/2020 17:17:36 |
Got out the wrong side o the bed this morning David ? Jason answered your queries exactly as a mod should. so keep cool. |
Thread: 3D CAD software - what do you use? |
23/05/2020 00:15:16 |
Blowlamp, Those are lovely renders. 👍 |
19/05/2020 17:59:19 |
Ian P, Looking at those specs, I would be tempted to start afresh. SSD drive is good, but the rest.. hmmm. FYI Solid Edge is a single threaded app which means it wont take advantage of a Cpu with lots of cores. Clock speed is the name of the game with SE. 8 Gb ram should be your minimum [ DDR 4 ] all depends on the size of your data sets. Will work fine with onboard graphics but a dedicated Gpu is best... again its tied into the data set size. Data set size is not just related to the number of individual parts in an assembly but also to the complexity of the geometry ie fillets, chamfers ect. Good luck, |
19/05/2020 14:38:19 |
Barrie, no problem.. I never thought that for a minute |
19/05/2020 12:58:39 |
The three pics I put up in an earlier thread on Solid Edge, were merely to show just a part of what it is capable of. I usually build what I draw [ not models.. gave up on them after the aborted attempt at the Renk gearbox ] although I had no intention of trying to build the Liebherr 600tonne crane block, Siemens motor or the Forkhardt chuck. They were from earlier projects for a third party.... non model related. And merely to show the level of programme it is [ and even they don't amount to a hill of beans compared to what it is capable of doing when required. |
18/05/2020 20:56:44 |
Tony Solid Edge all the way. The community edition will do all ( and more) that you ask of it. I use the licenced version and... the community edition is loosing very little on the cad side to the commercial edition. Cam module is locked, and Piping and wiring harness and Standard parts library are not installed in the free version. That's about the only difference. Solid Edge is actually more powerful than Solidworks. I have put a few pics of some Solid Edge models in an earlier thread and there are more in one of my albums. |
Thread: Thread to discuss Solid Edge 2D and 3D |
15/05/2020 07:03:21 |
Hans, Yes the customise options are very extensive far too much for me to write up here. If you go to the areas marked on my screenshot you will find all the help you need there. You can customise the GUI to suit your workflow. Not sure what the GUI is by default in the Community edition [ is that the default shown in your pic ? ] either way you will be able to get it to suit your way of working. Solid Edge is far , far removed from any of the programmes you have mentioned. It is a full blown commercial Mcad programme extremely powerful, Robust, Stable and flexible. [ don't let the extremely powerful bit put you off ] The User forum that I mentioned in another thread is a gold mine of info from Pro users of the software. also Siemens Solid Edge official forum is another first class site. Also, if you press the area at the top where the arrow is pointing that will take you directly to the GUI customise options Hover over it and press F1 will take you to a extensive help area. |
Thread: Siemens does not like me...! |
14/05/2020 08:10:27 |
Danny, Go for it, you will be fine. Because it's full blown Professional Mcad software it is expected that it will be used in a Pro environment, Hence Quadro / Fire Pro Gpu's and Win 10 pro. when the reality is Win home/ Geforce or Radeon [ or wharever AMD 's latest ones are called ] SE operates on them just dandy. |
