Here is a list of all the postings Durhambuilder has made in our forums. Click on a thread name to jump to the thread.
Thread: Boiler making torch |
10/03/2022 11:28:39 |
Posted by Bob Unitt 1 on 10/03/2022 09:55:28:
Posted by Durhambuilder on 10/03/2022 09:49:29
once you have the cylinder you just swap it with the size you prefer at your local calor dealer.
Check first - my local Calor dealer will only replace with the same size cylinder. Edited By Bob Unitt 1 on 10/03/2022 09:56:24 You can swap within the same group eg a 4.5kg butane can be swapped for a 6kg propane. https://www.calor.co.uk/gas-bottles/refills-and-returns/refills |
10/03/2022 09:49:29 |
Sievert every time, get a starter kit and add burners as required. https://www.gasproducts.co.uk/blow-torches/sievert-gas-blow-torch-kits/sievert-general-purpose-gas-blow-torch-kit.html Calor gas cylinders can be found quite cheaply at car boot sales and the like, don’t worry about size or condition once you have the cylinder you just swap it with the size you prefer at your local calor dealer. |
Thread: Summer 1990 Rotary Table |
06/01/2022 20:44:54 |
Appears to screw in to item four the bottom collar, I wonder if it should be 5/8 or 7/8 and not just 8? |
Thread: Silver soldering heat blanket |
11/10/2021 15:35:40 |
Kaolin wool blanket (CUP Alloys) is probably the stuff you’re after; for my boilers however I used a pumice chimney liner, see my album. |
Thread: Vertical boiler design |
03/10/2021 21:25:26 |
There is the 3” Ray Prime Atkinson waggon as supplied by Reeves which would be a fair bit larger than the 2” Clayton, don’t think it top fired though. |
Thread: Brass cleading |
22/09/2021 12:27:04 |
26swg brass will dent very easily, For my locos I’ve used stainless steel cut from a ‘pound shop’ bathroom pedal bin. |
Thread: Colchester Chipmaster 5x20. Hoping to buy. |
19/09/2021 17:47:57 |
I bought my chipmaster about 5yrs ago and love it, variator is still smooth as silk through the entire speed range. One of the easier lathes to move as well albeit a bit weighty, there are a pair of holes in the bed designed to push a bar through and you lift from there, the wide base also makes it a lot less top heavy and more stable when moving. I moved mine about 60 miles with a 1 tonne plant trailer and an engine crane to lift off and on. |
Thread: Cladding material |
02/09/2021 15:25:11 |
I’ve clad my previous two boilers with thin stainless steel having bought a couple of cheap pedal bins for the purpose. |
Thread: Hello from the west country |
26/08/2021 11:26:11 |
Welcome aboard, I have a Chipmaster in Frome so not too far away. Unfortunately I can’t help with your wiring, mine is run off of a phase converter. |
Thread: Dore Westbury x slide motorising |
18/08/2021 15:03:59 |
My Dore Westbury is the one in the photos on Tony Griffiths site, **LINK**, this has the original power feed option but I can truthfully say I’ve never used it whilst milling! |
Thread: Boxford BUD Tool Post |
27/07/2021 13:36:03 |
That doesn’t look like a Boxford top slide to me, probably off of a bigger lathe. |
Thread: Which lathe to purchase |
26/03/2021 11:54:46 |
Sell whatever scrap you can, beg borrow or steal to raise your budget to £2000 and buy the myford 254 in the classifieds, no connection with the seller but looks a cracking buy and fully tooled up. Edited By Durhambuilder on 26/03/2021 11:56:38 |
Thread: Car identity |
05/02/2021 10:02:21 |
Jensen healey 1972-1976 |
Thread: Safety Valve |
01/02/2021 17:09:51 |
https://www.scmes.co.uk/images/Technical%20Information/SafetyValves/Small/Safety%20Valve%20Details%20All%20Doc%20&%20Valves%20off%20web.pdf try this
Thread: Walco GH610 info |
28/12/2020 13:06:40 |
Looks a good deal but just be careful, that lathe has ‘sold’ twice on eBay in the last couple of months. Photo has been cropped but definitely the same photo, bisley drawers alongside and metal strip on floor. |
Thread: copper tube |
27/09/2020 15:52:36 |
M machine list it.
Thread: How to move a Colchester Student ? |
04/09/2020 20:11:56 |
And definitely an example of how not to do it https://youtu.be/dHpCJKXB0YI
Thread: Buying first lathe |
01/07/2020 15:36:37 |
Jacob, I have absolutely no connection with the seller but if I were you I’d have a good look at the Boxford currently on the Home Workshop site for £750. |
22/06/2020 08:31:04 |
The dulux paint colour match swatch under the left foot would ring some alarm bells ! Has it been hastily repainted? |
Thread: New storage space |
31/03/2020 11:58:16 |
I did my 35m2 garage floor on my own over about 5 morning sessions using a normal mixer. I used kform profiles set to level and concreted in bays between them. Highly recommended, I found they made the whole job very manageable. www.kform.co.uk/product-k135.php.
