Member postings for oldvelo
Here is a list of all the postings oldvelo has made in our forums. Click on a thread name to jump to the thread.
Thread: Tightening jacobs chucks
23/01/2017 17:54:59
Hi
Thanks Nick Farr for explaining in a clear and concise way what happens in workings of a three jaw chuck read and learn
Eric
22/01/2017 19:06:04
Hi
An old mentor of mine insisted that we tighten a three jaw chuck using all four holes.
Try it!
Eric
Thread: ME 4538 Auckland Model & Experimental Engineers
29/07/2016 06:18:14
Hi
There are photos in my albums of a draw bar release for an X2 mill that may be of some use.
Eric
Thread: Hemingway Compact Powered Hacksaw
23/07/2016 21:44:13
Hi
Hate them or love them with power hacksaws. Being the latter then I can give a monocled view on power hacksaws and the use of.
A couple of Hacksaws I have worked on can be seen on Youtube search for "Wobbly Hacksaw" and
"Power Hacksaw Rebuilt and Testing"
Sure they are not as quick as a Bandsaw but will perform well if set up properly and up to 5 kgs weight on the blade.
Old "Wobbly" has now a DC motor with variable speed from 0 to 90 strokes a minute and copes with anything thrown at it.
A standard hacksaw blade is used with a mix of 50% kerosene dripped on the cut and gives many hours use on one blade.
Number Two tool is a Vertical Band Saw converted to cut steel Pics in my Albums.
Eric
Thread: three phase motor current
13/07/2016 22:30:27
Hi
Sorry to answer with more question so what is the reading on the mains to inverter leads.
Would this not be more accurate.
Eric
Thread: Flying Scotsman's schedule to be kept secret
10/05/2016 23:17:23
Hi
How can the police help when most of them are off duty having spent the previous night keeping the the stupid revelers from harming themselves and others.
Being a Railways Nut Case I ask why you would clamber on the tracks for few seconds of useless video or blurred and distorted image of the Flying Scotsman.
When a carefully selected vantage point some distance from the tracks you can enjoy the full symphony not a few distorted notes.
The intelligence is built into a modern camera so that lot's of users think that is transfered to them.
This will render them invincible to any threat or danger.
You can educate ignorance but you can not fix stupid.
Eric
Thread: Warco WM14 mill, jammed drawbar
09/04/2016 20:59:06
Hi David
A block of wood on the table and and and slap the boring bar head down on to it to wedge the morse taper into the socket and the undo the bolt.
I suspect that the thread may be damaged.
You Can remove the head of the bolt by drilling a small hole in the centre of the bolt head and keep increasing the drill size until the head falls free
A ring spanner on the head may be needed Wired or duct taped in place or a second pair of hands to stop it spinning.
Or as suggested hold the boring head in the vice this will not unscrew the boring head from the arbor and drill it off.
Eric
Thread: Oils seals, which way to install?
03/04/2016 22:58:53
Posted by John Reese on 03/04/2016 02:34:22:
Beautiful work.
A quick rule for seals: Lip facing in to keep lubricant in, lip facing out to keep dirt out.
You probably want to keep dirt out.
Hi Ed
John is spot on can I add a little more. the bearings are rubber sealed so no lubricant on the seal so a dab of grease on the shaft before fitting the seal.
There are "Double Lipped" Seals available with smaller secondary lip to keep dirt out and lubricant in.
Or a felt grommet soaked in oil instead of a modern seal will keep the swarf out.
Eric
Thread: Slit Saw for small mill
16/03/2016 23:06:50
Hi Ian
It is possible to fit an abrasive blade to to ferrous metals on your chop saw.
Down side is lots of sparks with a fire risk with lots mess and with burned edges on the workpiece.
Eric
16/03/2016 20:50:20
Hi
A use a 1.5 mm thick blade with flood coolant and a slow and smooth feed rate.
Take 3 to 6 MM depth of cut with about 30 metres a minute tip speed.
On a vertical spindle mill you are very restricted in the size of the work piece you can handle.
Depending on how much you will use it a bandsaw is fine if if you can afford the cost and the space.
A small power hacksaw will be cheaper with a smaller foot print.
Eric
Thread: Bandsaw blade speed - how far can you push it?
06/03/2016 20:03:02
Hi
A vertical bandsaw can be converted to cut metal very successfully with the proper gearing down.
A link to the last conversion of mine
http://www.homemodelenginemachinist.com/showthread.php?t=24940
A Bi-Metal blade is well worth the extra cost for cutting steel
Eric
Thread: Hydrogen embrittlement in steel?
02/03/2016 23:02:22
Hi
Why would you want to a Zinc or Galvanised coating to a steam pressure vessel and run the risk of severe corrosion of any attached fittings.
Part working life was boiler overhauls and fitting and maintaining a factory steam supply Where the use of any Zinc or Galvanised fittings was prohibited because of the risk of failure from electrolosys.
Any exposed steel can be painted with a heat resistant paint.
Eric
Thread: Faulty switch?
25/02/2016 20:10:22
hi
It appears that the relay does not hold the contacts in check that the stop button contacts are Normal Closed first.
The coil on the relay may have a fault.
Murphys Law may apply Inter changeable parts will exhibit basic fundamental differences.
Has the motor and the line leads been transposed.
Eric
Thread: speed control needed
21/02/2016 21:46:24
Hi
IF this is a Universal Motor I.E Brushes and Commutator the it will run on a AC to DC speed Controller.
Expensive yes and needs to setup to match the motor.
Eric
Thread: How to gently increasing pulley bore size
11/02/2016 02:36:09
Hi
A 50 plus years old pulley bore may no longer be in good condition with burrs and other damage.
If there is no keyway in the pulley you may be able to use a "Brake Cylinder Hone" on the bore.
Or a light linishing on the spindle would be my preference.
Eric
Thread: Sieg X2 belt drive
09/02/2016 07:01:38
Hi
I can go along with the suggestion for using "Poly Vee Belts" on an X2 Mill Drill.
Having done a few iterations on my mill and settled for 1.25 hp motor with two speed"Poly Drive".
4 Rib Pulleys are easy to fabricate from aluminium or cast iron.
Eric
Thread: NIGEL GRESLEY DIMENSIONS
06/02/2016 18:02:13
Hi
The full size specifications can be found at
http://www.lner.info/locos/A/a4.php
Scroll down for all Technical Details.
Eric
Thread: Black Ice
18/01/2016 21:09:54
Hi
Yes have seen "Black Ice" on on instance it was in Durham City around 1960 or before when steam locos where still in use and the "Flying Scotsman" came through the cutting at Nevilles Cross yes complete with discordant whistle screaming and sliding on tracks covered with "Black Ice" slid through the station and came to stand still on the embankment above Sidegate.
Was eventually assisted back to the platform by a Banker Engine.
Eric
Thread: Neat cutting oil. (recommendation)
07/01/2016 20:04:47
Hi
Off Topic but happy to run alongside
To apply cutting oil I use an oil can with a wide base and and very short in height and stick a "Pipe Cleaner" like thing from the local craft shop pushed down the spout with just a few bristles sticking out.
Gentle pressure on the lever and you have constantly rechargeable brush.
Push too hard and a big oily worm and a mess everywhere if you do not restrain it in the detachable spout by a small loop in the end.
No prizes for guessing how I learned this.
Eric
Thread: Blackgates Power hacksaw Rebuild
16/12/2015 19:50:58
Hi Graeme
An idler or a slipper pad on the non drive side of the chain will take care of a slack chain.
It is quite possible that the original chain had a half or cranked link fitted
Post a photo or two please for another power hacksa w nut
Eric
walker midge
rapid Direct
JD Metals
