Here is a list of all the postings oldvelo has made in our forums. Click on a thread name to jump to the thread.
Thread: FREE PLAN: A Clutch for the ML7 Lathe |
21/01/2021 06:01:44 |
Hi Oldiron's video is on the right track for a clutch. An Idler wheel on the back of the belt with an over centre eccentric to engage the drive. A peg or an idler on the front of the belt that just clears the belt when the clutch engages. This will stop the belt from flapping and jerking. This method has been used on various engine and electric driven machines I have built over over a number of years. Get rid of the linked belt and use Poly Vee Belt and Pulleys or regular Vee Belt in its place. Eric |
Thread: The demise of UK fossil fuel Power Stations |
19/01/2021 18:19:08 |
Dave you have just shot yourself in the foot Can someone explain How 7,000,000 tonnes of wood pellets get to Drax power station and not using fossil fuels. ... "" They don't at the moment because most ships and land transport systems are diesel"" Do you realy know about what you post. Eric |
19/01/2021 09:45:53 |
Read this article on BBC News a few months ago and found it hard to understand the reason for it. Can someone explain How 7,000,000 tonnes of wood pellets get to Drax power station and not using fossil fuels. The trees cut down in America and to be pelletised no doubt they used products from the Oil Industry which suprise suprise is a Fossil Fuel. The transport accross America then the Atlantic. Put on rail to Sheffield all Fossil Free?? All paid for by the consumers. All done with No damage to the environment where the trees are harvested from complete with a regeneration program in place maybe??? Eric
Thread: I wonder what the Aviation Authority thinks of this : |
17/01/2021 16:19:18 |
Old Iron """Karen""" finds your comment Offensive |
Thread: Taper-Lock Bushes - tolerances |
29/12/2020 17:18:41 |
Hi Simon One method used when assembling 'Taper Lock Bushes' is insert a 'Fox Wedge' or a flat blade screwdriver in the slot of the bush to open up the diameter slightly. Then fit it into the pulley-flywheel with the retaining screws done up finger tight only to keep it secured the it will slide easily on the lightly greased shaft. NO grease on the tapers or retaining screws. Eric
Thread: Velocette MAC |
29/12/2020 00:12:28 |
Hi Robert please sit down first Always alifelong intrest in Velocette I googled for KSS the bike in the photo First 'Road Legal' bike I owned was a 1933 KSS anoldvelo Eric
Edited By oldvelo on 29/12/2020 00:14:26 |
28/12/2020 20:13:48 |
Hi A Velocette fan from way back I spotted this hybrid one parked. The owner had fitted an overbored to 499cc KSS motor into a MSS frame. |
Thread: Calor gas butane workshop radiant heater |
23/12/2020 18:34:52 |
Sam Running a gas flame heater in a small workshop producing carbon monoxide is not good for your health or for that matter your survival. New Zealand Ministry Of Health Bulletin Gas Heater Warning Stay Safe Take Care Kia Kaha Eric
Thread: Message from ARC to our customers in the E.U. |
10/12/2020 19:03:23 |
It was not broke I did not need to fix it. Now I wanted to break it so now we all need to work to fix it. |
Thread: Whitworth v UNC |
18/11/2020 00:00:35 |
Good luck trying to put 1/2 inch U.N.C. nut on whitworth and vice versa |
Thread: Rubber mat. |
03/11/2020 03:52:16 |
Concrete floor covered with sponge rubber matting with 12 mm painted chip board on top has a slight spring when walking on it. quick clean up with a brush any spills mop up off the painted surface. Eric
Thread: Gib Screw Locking Methods |
02/11/2020 06:39:25 |
I guess the point I made was not explained properly that I use good old fashioned "L" shape Allen Keys to adjust gibs and the Ring end of a ring open end spanner on the lock nut. No excess torsion spring forces required.
01/11/2020 21:23:12 |
Simple solution to the play of an allen key in a socket head screw is to exert pressure toward the screw at a right angle to the rotatation then do up the lock nut. |
01/11/2020 05:59:56 |
Cup point set screws with a ball bearing <o>
Edited By oldvelo on 01/11/2020 06:00:37 Edited By oldvelo on 01/11/2020 06:01:50 |
Thread: Which ball turner? |
29/10/2020 19:52:45 |
Hi Clive I can now see how a smaller lathe with a boring head fo a ball turner is a bit of shoe horn job. A round piece of tool steel does a good job and cuts left and right This is the MEW Boring Bar set up as a Ball Turner. Has turned out a lot of stainless knobs to replace plastic ones. Eric |
29/10/2020 09:32:46 |
Hi Jim Boring Bar head on a bushed shaft mounted horizontaly on the toolpost with a round nose high speed tool steel with the cutting edge on the vertical centre line will work fine and will cut on the right or left swing. Use the tool upside down with the flat side facing downwards. A 400 mm lever on the piviot shaft will give good control and finish with minimum effort. Eric |
Thread: Putting some grip (stippling) on an aluminium drive pulley. |
17/10/2020 08:32:26 |
Poly Vee Belt 2 Ribs "j" 4.64 mm wide will do the job. Pulleys in aluminium are easy to fabricate with a high speed steel tool ground to 40 degrees. Eric |
Thread: Moore & Wright Automatic Centre Punch |
16/10/2020 01:23:29 |
Hi If you overtighten the adjustment the punch will not cock it properly and will not work. Eric |
Thread: Axminster SX2 |
12/10/2020 04:59:51 |
Disconnect the leads from the motor and connect a 230 volt Light bulb to the control box motor leads. Turn the speed control to the lowest speed then power up the control and turn up the speed control the light should get brighter. The control is O.K. if the light gets bright. A 12 volt car battery will test the motor to run it allbeit slowly. If their is a short circuit in the motor the leads will get very hot super quick. Best done outside and away from flamables. Eric
Thread: Grumpy old men |
11/10/2020 18:15:14 |
When someone posts a question on MEW and I answer with how something actualy works and go into some details to explain it. Then they repost my explanation in full then tell me it does not work like that at all. That they have a Theory of the way that they Assume it works is correct and is the only way to solve the problem. The ones who drift off to post on something that maybe remote and possibly connected the subject being discussed on the forum |
