Member postings for Nigel McBurney 1
Here is a list of all the postings Nigel McBurney 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Super 7 spanner sizes
10/04/2021 09:18:06
Myford used the cheap end of the market black as forged UK made spanners as they knew that their lathes were good and did not need frequent adjustment so these spanners would not see much use.
Thread: Anti seize grease on Myford spindle nose?
07/04/2021 15:42:00
Ady your statement that with back gear you never get a stuck chuck,there is also a very good chance that it will result in back gears with a few teeth missing. use a rag with a drop of 3 in 1 oil to wipe the nose thread,should a lathe be left left idle for a long time then loosen or remove the chuck. Especially on machines that have a pumped cooling supply of soluble oil.
Thread: Recommended suppliers and services
07/04/2021 09:24:33
I use Arceurotrade excellent service, for ER collets and 3mt tooling for my mill, Rotagrip for chucks ,soft jaws,,Dickson toolholders, backplates,etc Screwfix for known branded power tools at good prices,, GM tools Ashington Sussex,bought lots of new/used tooling ie taps dies chasers lathe tools,lathe chucks,faceplates used machine tools.The last three I have used for over 30 years.
Thread: Archer tapping chuck clutch
06/04/2021 17:08:46
I have a no10 Archer friction drive tapping chuck,with no 1 morse drive,and the instructions this is really just a tap holder with a slipping mechanism and relies on the drilling machine to provide the reverse.it could also be used on a centre lathe or a capstan lathe.Though the machine would have to have the slurry pump turned off ,Its what Peter Ellis writes,its the bottom 1/3 of the tapping attachment, Now the tapping attachment shown in the above post is a true tapping attachment with a reversing gearbox,there was one of these at my first job,a very fierce bit of equipment particularly on Whitworth threads,get it wrong and it would lift quite heavy castings rather than go in reverse,I have the instructions in the box so will write what they say as I do not know how to copy the original on this system
The friction drive is located in the top of the chuck and consists of multiple fibre and steel washers,the compression of these washers is adjusted by means of a castellated tension ring operated by the c spanner provided.
the friction washers must NOT be lubricated.
The friction drive should be set sufficiently firm to drive the size of tap being used.When the tap is fitted ease back the driving tension until the tap just slips when driving the tap,then tighten up the friction drive sufficiently to drive the tap under normal cut.For smaller taps special care should be taken to finely adjust the friction drive so that it slips on the slightest overstrain on the tap . If the tap stops on hard spots or overfeeding and the friction drive slips,the drive should be immediately reversed or the spindle stopped to prevent too much slipping to occur and overheat the clutch the cause unnecessary wear.
on the other side of the instruction sheet there is an underlined note stating DO NOT LUBRICATE THE FRICTION BOX
Its a better non slip way of holding a tap in the lathe tailstock than in the Jacobs chuck which always slips,though I would still use the lathe clutch to stop the tapping op particularly on BA taps ,relying on the clutch to slip may result in tap breakage ,I just use mine as a tap holder and not rely on the slipping clutch.
As i stated previously I have worked with the full reversing attachment ,though I much preferred another make of tapping attachment made by Pawson this had a lot softer clutch and reverse mechanism and was a lot kinder to the smaller taps
Thread: Milling machines - western-made s/h recommendations up to £2k
06/04/2021 15:14:02
My choice would be Bridgeport,Elliott 00 omnimill,Harrison,Tom senior, All good machines that were used in UK industry and some still are, A friend had a Centec,I thought it was just too small never saw one in industrial use,would be ok for instrument making,or making a small loco. The standard Senior m1 with the knuckle head does have limited space under the spindle ,as I found when I had one ,i got mine from a friend who made plastic mould tools at home as a business,he replaced this m1 for a Senior m1 size machine with the small universal head which has a quill though only a 2mt spindle,This was in the 1970s during the 3 day weekand I went up to yorkshire to collect it new fromSeniors,that was an interesting visit and typical northern weather. He warned me that he found the capacity under the spindle to small,When got the new mill ,the small head mounted closer to the top of the machine gave more clearance ,he also bought at the same time a senior vice which was lower than an Abwood. I found that with the Senior I was forever changing my set ups as I was always running ot of space, though it was good for machining parts on an Allchin.I had no problems at all with Senior and it was a well built machine and no problems. A house move meant I had lots of room and some years later I sold the M1 and replaced it with the other extreme an Elliott Milmore at 1,75 tonnes and 50 inch table, this had capacity to cope with most jobs though it had a couple of faults, the spindle was only 30int a 40int would have been better,and the double swivel of the head would loose its tram,i used it comercially for 25 years, though it was backed up by an Adcock and Shipley universal mill , a impeding house move meant the mills had to go,this all fell through so I thought about getting a smaller English mill then a neighbour gave me an Elliott omnimill ,which had a slotting head and I aquired the universal head plus added electronic speed control on the vertical as my work meant I needed a lot lower spindle speed.this 1963 machine had come from a toolroom ,I made a stiffener for the vertical head which vastly improved the performance . the 00 has one big advantage ,it has real capacity,If anyone buys one ensure that it has the correct 3MT horizontal spndle ,they are rare nowadays, easier with later machines as they had 30int horizontal spindles. I did once have a mill drill (ex Taiwan) absolute rubbish for milling but was a very good drilling machine with 3 mt spindle. My friend who bought the Senior new, was a work colleague who always wanted to go out on his own as soon as he could afford one he had a Bridgeport ,he just loved them,he always said they are good ,accurate, and all the controls come easy to hand,enabling him to keep up a high work rate.wth a vice ,angle plate,rotary table set up on the table, along with a decent Colchester he could earn a good living.So there is my experience,go English,dont go after cheap rubbish,and by a machine that suits ones work.There are too many posts on here from modellers who have trouble with far eastern machines and always trying to get spares.
Thread: Canon printer
03/04/2021 14:17:18
After many years with two epson printers,the last Epson wanted some type of servicing and as it was at the start of this lockdown ,went in a hurry to Currys and bought a Cannon g4511 Pixma ,when it prints the quality of black type is very good but it will not work from my applemac unless connected with hard cable,instructions are useless ,helpline just gave a load of instructions to try to cure the non event wireless connection.but they were difficult to understand.I would never buy another cannon printer. Sometime I switch it on and it will print amother its a pig to get it to work,the screen is so tiny and the control buttons so small.
Thread: Loco wheel profile chatter
02/04/2021 20:09:48
Its the method thats the problem, for a start the holding method is wrong,any large diameter disc held on a relatively small mandrel will be very prone to chatter,there is also a tendency when using carbide tooling to use the high speeds in the charts,high speeds lead to chatter unless the work is well supported. the machining method described ie plunge cutting i assume is achieving the metal removal in one cut if so may cut ok but when the tool stops feeding along the tool starts to produce a a chattered finish,the old adage should be respected do not let your tool rub keep it cutting or clear it from the work . The slight dwell when changing tool feed direction will cause tool chattering. The writer also states his method is faster,its a hobby why is there a need for speed,select the best method not the fastest. Looking at the lathe tool,I may be wrong but it looks like its essentially a form tool with angled face to produce the tapered flange and I assume it fed along the bed via the saddle so why is the top slide set over ? I have machined a fair number of brake discs /drums ,stationary engine flywheels and they have to be held formly to avoid chattered finish, For example when machining brake drums if the drum is held by the centre hole ,a poor chattered finish will result . set up a large thick cast iron disk with four /or more tapped holes in a four jaw ,face the disc off to get the face true bolt the drum true onto the fixture and use a brazed carbide toolbit with minimum tip rad ,in a big boring bar,slow speed and fine feed and a good finish is the result,care has to be taken not to rush the job,in the vintage world there may be no spares for a 1950s lorry and customer satisfaction is essential.I have only done a couple of sets of loco flanged wheels and got very good results using four chucks and a thee jaw with soft jaws ,no skinny mandrels ,good finish ,happy customer.
Thread: Advice acquiring single phase motor for Elliott Pillar Drill
01/04/2021 10:46:57
I bought new in 1968 a Fobco 1/2 inch dril it was fitted with a simple on /off rotary switch and 1/3 hp single phase motor ,I fitted an MK 13 amp plug to the lead and its been like that ever since,In those days there were no labels stuck every where eg no volt release must be fitted,and in reallity a no volt release is not really required,if theres a power cut and I did forget to switch the drill off so what ,it may start up again when powers restored so what. My Myford runs with a 3/4 hp s/p motor and that is started with a 13 amp plug in an MK metal clad socket,never had a problem it says something for MK that the switch is still working after 52 years. I expect I will get a barage of replies about safety but just consider this aspect of safety ,I expect many home worshops have electric heaters up to 3 kilowat,phase convertors,electric welders,do these have no volt release switches ? Any of those left on after a power cut could cause a fire if a fault developed ,in my view far more dangerous than a drill left running particularly if the workshop is attached to the home. The one safety feature I do have is a safety light which comes on via an internal battery when the power fails,which is quite often in a very rural area,and then it is really dark in my workshop.So to remotor a drill just fit a single phase capacitor start motor as others have said advertise for a suitable motor as there must be more about now due to others converting to VFD.I have never had a requirement to for a reverse function,occasionally when there has been a need for power tapping say fifty holes I use a commercial tapping head in my larger Meddings drill which has its own internal reversing mechanism.
Thread: ML7 Hand Crank / Wheel?
28/03/2021 09:39:53
Ok a steering wheel is better /safer than a handle,a disc of aluminium with a round rim and recessed in the centre,with no holes or spokes would be safer.some larger lathes had 5c collet tubes with a round disc to tighten the collets and these could be safe when operating/rotating under power, I would have thought that care would have to be taken with a steering wheel as this could put a lot of torque on the tap,which can then put too much torque on the tailstock,the Myford tailstock barrel has only a small key to prevent rotation and the jacobs chuck relies on just the morse taper ,damage this taper and the machine is no longer an accurate centre lathe. Larger taps than BA or 1/4 whit can be held in place with a spring loaded centre and held on the flats with a spanner,Every time I use the S7 to tap a small hole I always curse and have to rotate the chuck by hand,a reversing motor would take just as long as the motor has to be switched off ,come to a standstill then started in reverse,The ideal situation would be a pair of clutches on the Myford to give near instant forward /reverse,in olden days when lathes with flat belts had the line shaft overhead,with power off the belt could be grabbed and pulled either up or down to give instant forward /or reverse.
Thread: Hi from Hampshire U.K
26/03/2021 11:24:12
Hi I am also from Hampshire,south of Alton,lots of households with lathes in these parts,owners are involved in various hobbies, models,classic m/cycles,stationary engines etc
Thread: Small Poppet Valves
26/03/2021 11:15:34
I have made lots of full size stationary engine valves,a lot of original valves have a material similar to siver steel for the stems and cast iron heads,Amancos and some ruston hornsbys for example,for very small engines the cast iron head would probably not work,though a silver steel stem would be round ,accurate and strong,so why not make the head from stainless steel and thread the component parts and screw them together and lightly rivet over the stem where it protudes through the head,then set the valve stem up in a lathe collet and very carefully skim the seating face of the valve with a very sharp HSS tool. Making a valve from solid rod is not a good idea as the inner core is not very strong when getting down to small diameters,automotive valves get over this problem by forming or forging the head on the valve. The Amanco open crank engine valves also have a valve seat angle of 45 degrees,they work and seal very well ,though often regarded as cheap and crude American engines ,for their time they were a very good engine which started easily ,would run in an absolutely worn out condition,and was an example of lots of capital poured into machines and tooling to produce a very cheap good product from day one of manufacture,the interchangeability of componens was very good,and having made lots of spares,never had a customer complaint about parts not fitting.
Thread: Is RSJ Steel machinable?
25/03/2021 19:18:01
Most bits of rsj I have come across,machines similar to common black iron,ok for brackets,and a good support under a lathe,my myford sits on a length of 7 x 3 channel. and welds ok. As others have said dont cut it up,at least keep a length as you might need a lifting beam in your garage some time in the future,give it a coat of red oxide, As i understand it ,if regulations are complied with steel used in buildings must be new for some time,more recently structural steel in buildings ,has now to comply to an ISO spec and its origins traceable. The thin light angle iron used years ago for bed frames is very strong,Back in the 60s I used some to make trailer,borrowed the works gas welder,the angle spit and spluttered and flakes came off it ,then I found it brazed ok, Hacksaw blades did not last long,no angle grinders in those days. I aquired a supply of more bed angle a while ago and used it to make security bars for shed windows, Going back to machinability of rsjs, i aquired some heavy angle and channel which was galvanised and used by the electricity board for supporting pole mounted tramsformers,now that machine a easily as bright mild steel,there are a nuber of long slots for bolts so perhaps a better steel was specified as they would need an awful lot of steel
Thread: A home-made gear - will it work?
24/03/2021 11:12:22
I have a 1973 Colchester master 2500, Just had a look at the thread indicator dial, the gear is white delryn or nylon,the teeth are at an angle of approx 4 to 5 degrees,the gear is 1/4 inch thick.the gear is fitted to the shaft by a fine spllne more like a coarse knurl, and so is the dial at the other end of the shaft. So anyone with this type of fitting the shaft could be pressed into a plain bore in the nylon gear .The shape of the teeth is not really important,the device is an indicator,so a disc with a number of say brass pins around the periphery would work.tilting the dividing head a few degrees would work I personally would use a gear cutter as I have a large collection of various types ,an alternative would be to make up a flycutter,which could be hand ground by using the broken gear as a guide,I would not bother to do an initial pass with a slitting saw. Now on the metric Colchester Triumph ,the thread indicator has a set of gears as single gear only works on some pitches.from memory these gears were made from brass and were about 2.5 mm thick and did not need the teeth to be set at an angle .
Thread: CVA LATHE
23/03/2021 19:42:14
I worked in a brand new toolroom set up in 1967,the lathe was a CVA an accurate well built machine ,being new all the controls and slides were a bit tight ,not a pleasant machine to operate,I did not really take to it,it was supplied as a metric machine ,though among the paperwork was a lead screw test /accuracy chart thats when we found out that the leadscrew was imperial,it looked like metric super accurate leadscrews were not available at that time. so may be worth checking on an old machine,of this era Back in the 1990s recession when there were a number of machine tool and factory auctions i saw a few of these CVAs and they all had received some hard use ,never saw a good one.
Thread: Endmill smear of metal
22/03/2021 18:22:01
why spend cash on new end mills and carbide bits,when a simple home made flycutter with a hss toolbit or broken centre drill ground up to shape costs next to nothing and will produce a better finish as the tool tip rad,cutting clearances,rake etc can be chosen to suit the job by using a bench grinder.The burr is manly caused by blunt tooling.
Thread: Boxford max useable Chuck size
15/03/2021 10:07:14
I have a 5 inch Burnerd 3 jaw for occasional use on my myford,and I have a european Bison brand 6 inch 3 jaw chuck on my Colchester,this chuck is heavy far too heavy for a Boxford,. I last worked seriously on a Boxford many years ago. Now although I can see no problem with occasional use with the Myford,I would not like to run a six inch chuck on the Boxford especially as you only have one set of jaws for your current 3 jaw and you will be tempted to use a larger chuck all of the time,I would get a good 5 inch chuck,with both sets of jaws and if that runs out of capacity then use the four jaw.
Thread: Identifying brass?
15/03/2021 09:32:49
An friend who worked for a company that did a lot of work machining bronze and got me a lot of off cuts,once told me that one way of identifying bronze/brass was that brass can be annealed ,bronze cannot be annealed, I did try annealing a piece of bronze and it would not anneal like brass or copper does,though I do not know if this applies to all type of bronze. Aluminium bronze is slightly magnetic,our local scrap merchant keeps a magnet handy for testing.
Thread: Bandsaw overhang
11/03/2021 10:12:50
Garys holding method goes way back,the Rapidor power hacksaw in the factory where I first worked, had an accessory for holding short lengths of material ,it consisted of two malleable iron cast plates each one having two V s of differing size, plus a long threaded bolt, the two vees allowed various diameters of short stock to be held securely without tilting ,plus short lengths of flat stock could also be held,the bolt took up the gap at the other end.The Rapidor came new to the factoy so the accessories were looked after,I have seen many of these saws in dealers and at auctions ,none had the special grippers for short material.I made some of these plates for my saw using 4 x 1/2 in flat bar with angle iron welded to them to form the vees. I have often thought of making a similar vee jawed gripper for my DO ALL band saw but like a lot of things it does not get done until there is an urgent need.
Thread: Undoing a castellated nut!
11/03/2021 09:49:30
a simple pin spanner will work in round holes as well a square cut outs,the advantage of square cut outs is the pins do not have to be very accurate regarding pitch. For the butcherand bodgers a square cut out is a lot easier to hit with a punch than trying to punch a round hole.
Thread: Ball Races and 'Brinelling' (whatever that is).
10/03/2021 12:29:27
Hard drive bearings,disc spindle and actuator arm, in my day spindle bearing ball races had more than standard clearance and had preload via a spring,the lubricant and the quantity was to a special spec as a min 5 yr life was specified,I would not bother to re use these bearings in another application. I have seen severe brinelling on motor cycle head races particularly on competition bikes, I had a new Greeves trials bike back in 1961,which one of the first bikes to have timpken taper roller, after a couple of years use I removed the forks to check the bearing condition and lubrication as there was no greasing nipple,the bearing outer race surface had bright spaces,separated by black line of corrosion as the steering lock limits the travel of the rollers,very slight wear could be detected on the bright areas,in those days Timkens were expensive,so the old bearing continued in use and still being an apprentice with limited funds,replacement of chains and wheel bearings was deemed more important,after the overhaul when riding the bike on the road there was a very slight shimmy felt through the handlebars. Back then a lot of trials competitors rode their bike in competions at the weekend and it used it for road use during the week, summer holidays would be spent giving the bike an annual overhaul,,One thing I read about recently was that some road racers still prefer the cycle cup and ball bearing assembly compared to taper bearings as they reckon the bikes steer better.
Dreweatts
Rapid RC
