Member postings for Eric Cox
Here is a list of all the postings Eric Cox has made in our forums. Click on a thread name to jump to the thread.
Thread: No refund
10/06/2022 10:34:54
I recently contacted the ME magazine publishers to cancel my subscription as I no longer wished to receive the magazine. They responded by telling me they had cancelled my subscription and that I would receive 14 more issues. I told them that didn't want the magazine and would they please refund me for the cost of the remaining 14 issues. They told me they didn't do refunds so I'm now out of pocket and will be receiving a magazine I no longer want.
Thread: aluminium sticking to end mill
24/05/2022 09:59:44
I dropped the speed down to 1000 rpm.and it worked fine,
23/05/2022 11:09:02
I have been cutting some slots in aluminium using a 1/4" end mill running at 2800 rpm and hand fed with a depth of 30 thou. The aluminium is sticking to the end mill and closing up the flutes. How do I over come this
Thread: Create a "transfer"
28/04/2022 11:24:12
If you don't have any transfer paper you can create "transfer" in the following way
select design reduce to correct size and print out on ordinary printer paper
when ink is dried apply two coats of clear nail varnish allow drying between coats
cut out and soak in water
rub off paper and you'll be left with a "transfer" ready to be applied.
Thread: A Remarkable Model Engineer
25/04/2022 10:08:50
Love the term " manually fabricated "
Thread: Can you identify these hand tools?
23/12/2021 10:09:47
Not forgetting striped or tartan paint.
Thread: 2021 Christmas Cracker-ish humour
20/12/2021 10:16:59
What do you call a man who has a bird of prey on each shoulder and vacuums the house at night.
Hawk kestrel man hoovers in the dark
(say it fast)
Thread: Bench top band saw
01/10/2021 10:02:09
I.m looking for a bench top band saw. The only one I could find is shown.
Does any one know of an alternative or have comments on this one.
Thread: Abrasive paste
28/08/2021 11:31:00
What's the best abrasive paste to use when honing a cylinder
Thread: setting up boring head
27/08/2021 11:48:59
had a few questions about setting up a boring head then I found this
Thread: self catering v independent
03/08/2021 09:42:19
I've been turning (conquest super) some 1/2" square MS. down to 7/16" Dia. Each cut was 0.010 over a length of 2", supported by a centre in the tail stock and held in a 4 jaw self entering chuck. The intermittent cutting caused the chuck to open slightly and the job to come loose. Would I have been better using a 4 jaw independent chuck.
Thread: Which tap
09/07/2021 15:16:12
Which tap gives better performance. Carbon steel or HSS
Thread: Stuart Beam Engine
02/06/2021 10:33:19
An alternative mounting instead of the heavy casting made from 1/2" aluminium plate
Thread: SQUIRM ALERT! SQUIRM ALERT!
29/05/2021 10:15:50
That's the Vas Deferens between men and women
Thread: Boring head graduations
22/05/2021 09:59:13
I have a boring head from Arc Euro. The graduated dial to increase the radius of the tool only has graduations and no indication of how much each graduation represents. Any idea ?
Thread: Boring head or fly cutter
12/02/2021 10:34:18
The machine is a Warco WM14 cutting mild steel 2" wide by 4" long
11/02/2021 10:10:56
I have a small amount of machining to do that requires fly cutting. Would you use a boring head which I have or get a fly cutter.
Thread: What machine tools are these?
28/01/2021 10:25:44
The hammer in the background is a planishing hammer. I can remember using one in the school metal work class to decorate a copper serviette ring.
Thread: How do these work
17/01/2021 10:34:04
In the village near where I live (Ticknall, Derbyshire) there are a number dotted about the village.
Their history can be seen here
Edited By Eric Cox on 17/01/2021 10:44:29
Edited By Eric Cox on 17/01/2021 10:45:47
Edited By Eric Cox on 17/01/2021 10:46:42
Thread: Metric to imperial
06/01/2021 10:34:28
Am I missing something here. Everyone is giving a load of calculations. Why not just divide 0.365 by 0.025. simples.
Dreweatts
Rapid RC
