Member postings for Antony Price
Here is a list of all the postings Antony Price has made in our forums. Click on a thread name to jump to the thread.
Thread: Building the Stent Tool and Cutter Grinder
25/06/2019 16:42:15
Hi
My thanks to IanT, Thor and JohnF for their offers of help. I now have all the articles I was looking for. I’ve spent this afternoon, reading through the articles in preparation for the build. The castings etc I have are part machined, and it look like the work already done is to a high standard. I now need to understand the modifications that have been done to the original design and if I should/could incorporate them
I think my next job is to document the tooling that came with a Clarkson T+C grinder, I purchased 6 years ago with the intention of getting it up and running. It’s stayed in the corner since, and now I have this project, I think it is time to release both the money and the space.
Thank you to all the offers of help
Tony
24/06/2019 20:49:24
Hi IanT
PM sent
Tony
24/06/2019 20:41:27
Hi Rod
I'm in Leeds West Yorkshire
Tony
24/06/2019 18:40:56
Hi
Is anybody able to help me with getting copies of the Model engineer article series on “Building the Stent Tool and Cutter Grinder” ? The Online archive doesn’t go back far enough. The table below confirms which year and volume the articles appeared in.
If you are able to help please private message me. I’d be happy to pay any reasonable costs for copying and posting.
Thanks
Tony
Year   Volume   Issue    Page
1991  167            3910     624
Blackgates Engineering. Getting started, construction: the main castings
1992   168           3912      44
The trickier operations. The dovetails
1992  168             3914     165
The smaller assemblies. The main feed assembly, picture on page 123
1992   168           3916      264
Cutting of the rack and pinion. The table traverse
1992   168           3918      393
Motor slide assembly, grinding spindle.
1992   168           3920      508
Drive arrangements. The motor and pulley assembly, the tool holders and guides
1992   168            3922     654
Tailstocks and final details. Conclusion
Edited By Antony Price on 24/06/2019 18:46:16
Thread: First Project
17/06/2019 09:45:38
Re: machining experience (zero)... some thoughts
The SMEE run courses on “Basic Training for Model Engineers” , “Lathe Tool Grinding” and “Milling”. I’ve done the lathe tool grinding and milling courses both of which I found useful in raising my knowledge base
The SMEE run a Building a Simple Steam Engine (“The Polly Course). I haven’t done this one, but those that have give it a ”thumbs up” .
The bad news is that the Polly Course only runs one a year and has already started
Tony
Edited By Antony Price on 17/06/2019 09:46:17
Thread: Precision Level or Precision Frame Level
03/05/2019 15:09:52
Hi JB
I’ve just spent the last week sorting out my Harrison T300 lathe...I tried using the Rollie Dads method but found the accumulation of errors (taper adaptor, test bar etc) difficult to resolve, so went for levelling the lathe. Having levelled the lathe, I did a test piece and had an error of 1/1000” over about 6”. Tweaking the relevant lathe foot, now gives me no error over 6”
If you would like a recommendation: the level I used was a Moore And Wright Machinists Spirit Level. 12”/300mm. I found it perfect for the job required. My level was second hand, from the well known auction site. I’ve just checked and there is one currently available (buy it now £79.99)
Hope this helps
Tony
Thread: #10 stock?
23/04/2019 11:00:40
Hi BugBear
Googling brings up
24mm long “Metal Shelf Support PEGS Stud PIN PEG Kitchen Cabinet 5MM Hole” (Amazon)
https://images-na.ssl-images-amazon.com/images/I/81a9LxOPsbL._SL1500_.jpg
At £2.63 including delivery would it e worth a punt to see if they are what you are looking for?
Tony
Thread: My ford quick change gearbox
16/01/2019 11:58:49
Hi David
I would another reference book along side “Screw cutting in the lathe” . For Christmas, I was given “The Gearing of lathes for Screwcutting “ (Crowood Metalworking Guides). It has two chapters “The Myford ML7 and Variants” and “The Myford ML7 with the David Machin Gearbox”. It has lots of detail and, in my opinion well worth the purchase price
Tony
Thread: New member
30/11/2018 08:26:26
Hi Bob!
Gods own Country... surely is Yorkshire?
Welcome from another GOC resident
Tony
Thread: Abwood machine vise screw
27/10/2018 20:45:54
Try http://www.kingston-engineering.co.uk/
Tony
Thread: Pinkgrip
27/10/2018 15:23:51
Hi Rod and John
The problem might be the different expansion rates of the metal to the insulation. Try SikaFlex 512, which is the product used for mounting solar panels on campers/mobile homes...to quote the manufacturer "Sikaflex 512 is a flexible adhesive to allow different materials to expand and contract at different rates"
Most importantly make sure that both surfaces are abraded and cleaned. Sikaflex instructions say 3mm bed minimum.
Just one note of caution! Its good stuff, once its set you will need to chisel it off to remove it
Tony
Thread: What depth concrete base for a workshop extension?
16/07/2018 14:48:09
My thoughts!
Install a damp proof membrane under the slab
Minimum of 100mm/4”
Check out and agree the mix ratios prior to work being done. In my case what went in was a bit weak on the cement, which resulted in a dusty top layer
Tony
Thread: Help with silver soldering (Yorkshire area)
18/03/2018 21:04:52
Hi Keith
Thanks for the prompt, I'll look into it next week. I'm hoping to attend the CuP Alloys on the Road 2018 Club night at Grimsby, on the 17th April. Hopefully I'll be able to say hello there?
Hi Fizzy
Thanks for the offer, I've sent you a private message
Tony
17/03/2018 17:19:13
Hi
I’m hoping that somebody with brazing equipment is willing to help me! The door handle (see photos) is from a 1920’s building and suffered some metal fatigue. I’ve made a repair, which just needs silver soldering into the door handle boss. I’ve tried today with my “plumbers” blow torch, but I can’t get it hot enough to melt the silver solder. Is there somebody in the Yorkshire area (I live in Leeds) who has the correct kit and is willing to help me? The silver solder I’m using (CuP Alloys 455), has a melting point of 630C - 660C
Thanking in anticipation  Tony
Edited By Antony Price on 17/03/2018 17:20:12
Edited By Antony Price on 17/03/2018 17:40:51
Thread: TV tonight
02/01/2018 22:36:09
For those of you that can access PBS America, tonight (2nd Jan) at 23:35 is Ultimate Restorations. The restoration tonight is on The Sierra #3 >> “The Sierra #3 steam locomotive was built in 1891, by Rogers Locomotive Works in Paterson, New Jersey, and is one of the few locomotives from this era, still in operation”. Think "Back to the Future III . The programme is repeated tomorrow (3rd Jan at 12:55 and 17:30)
Also check out **LINK**
Future programmes include a WW2 Lysander (Wed 3rd 19:55)
Tony
Thread: Removing mt0 centre?
05/10/2017 14:14:56
Hi Bugbear
Is it possible to take the tail stock off, and upend it to allow a “drip –drip” of easing oil down the barrel, leaving it overnight, perhaps longer?
Warming the whole thing in an oven before starting may also help by expanding the metal sufficiently to allow the easing oil to track down
Don’t be impatient and apply force too early! If para 1 and para 2 fail, go back to para 1 and try again
Tony
Thread: Reference bar ?
10/07/2017 12:21:34
Hi Nige
Do a search in Youtube on
"lathe headstock alignment"
"lathe tailstock alignment"
for some visual demonstrations on the techniques for checking alignment
Tony
Thread: Harold Hall's Advanced Grinding Rest
26/06/2017 17:24:34
Hi John
I've posted this before, but, also check out:
Link: **LINK**
Tony
Thread: Armoured cable - what size would you reccomend
20/03/2017 18:19:36
its likely that volt drop will be the deciding factor, rather than current rating. There are a number of volt drop calculators on the www. I’ve found this one.
Assuming 10 kW load, and 30 metres, assuming 240 volts incoming at the meter position, it recommends 6 mm cable, for a 10Volt drop . For 6 kW the cable size can be reduced to 4mm.
To check your typical load, look at the rating of the motors on your lathe and milling machine, and pick the largest . Just a note of caution, the larger the volt drop, the bigger the “dip on the lights” when the motor starts, which can be annoying.
My recommendation would be to go for a minimum of 6mm, especially if you are digging a trench to bury it underground
Tony
Thread: Tom senior bellows/way cover
12/02/2017 11:33:37
Hi Ronan
I suffered the same problem! I had some rubber gasket material which I cut oversize and fixed using some aluminium angle. The fixing holes in the Tom Senior were already there. I've always intended cutting most of the angle off, just leaving enough to stiffen the fixing, but have never got round to it.
Tony
Protective Cover1
Protective Cover2
Advertise With Us
TRANSWAVE Converters
Meridienne Sept 2019
