Member postings for Svarven
Here is a list of all the postings Svarven has made in our forums. Click on a thread name to jump to the thread.
Thread: Stuart D10 Metric Plans
29/07/2014 14:44:01
Stuart have a building guide book, with metric dimensions for no 10.
TEE Publishing ISBN 1 85761 096 2 revised 1995
Thread: Drill press KTF-13
04/01/2014 16:10:08
Thanks
Now i have to test that.
Bertil
01/01/2014 17:38:56
I have to disassemble the spindle then this unfortunately was a little crooked. So it can be when buying used items.
This machine is available under a variety of names.
So if anyone can help me with instructions to mount the spindle down without ruining anything, I would be happy.
Thread: What did you do today? (2014)
01/01/2014 17:02:13
imag0376.jpgimag0375.jpgimag0374.jpgimag0373.jpgimag0372.jpgHi
I assemble my DRO, which became the Christmas present to myself.
Works perfect. Both accuracy and repeatability, and hysteresis is so good you could wish for.
And it's bought from China for £ 200. But no Rubbish, it was in all cases not.
And the same functions as those of the 850 pounds that I worked with before
Offensive word removed by JasonB
Edited By JasonB on 01/01/2014 17:18:14
29/12/2013 13:34:45
Hi
Is there anybody who have a manual or drawing for the
KTF-13 Drill press
(King Feng Fu Machinery works co Ltd)
Bertil
Thread: workshop floor - ? epoxy
23/04/2013 21:10:14
Oxan floor oil is the outstanding for concrete floor.
We hav used that since 1980 for our machine shot at school.
Easy to repar and strog. Stands for welding too.
Thread: What thread? Stuart V-10
04/04/2013 19:43:45
Thanks
Looks good.
Bertil
03/04/2013 19:07:38
Tank you Jens.
If you would do that work i should be happy.
Bertil
02/04/2013 16:51:00
Thanks
Jens Eirik do you have any drawings for yor draincocks?
Bertil
31/03/2013 10:42:20
What thread should you choose for the steam in and out connection to Stuart V-10, to fit common accesories.
And what thread for the drain taps?
Growing up with millimeter so I need advice.
Bertil
Thread: Planet CNCUSB software
03/03/2013 12:07:04
Yes you have many intelligent questions and lots of experience.
If I have put it quite that there controler bords even for USB for Mach3 or?
Feels a little crazy to buy the controller with parallel port, as soon as there is on any computer anymore
03/03/2013 08:17:11
OK John
Dont you think that pocket fult is solved now, thereis a lot of updates made.
A thing i liked very mych is the automatic toll hight calibration in the home point. (http://www.youtube.com/watch?v=ToeWsqf7Dhs)
I hav not find that in Mach3.
I have not used Mach3 so much, but I and my students have converted a smal mill to cnc as a project.
There we used mach3 and tha thougt it was difficult to set up. But it can be that we dont have read the big manual carely enough.
I want a software which is simple to use, cheep, but can do all things you need for a mill, lathe and a router.
Im not interested in making anny programing into the software, so for me it isent a need for open source.
But it must be safe, no broken tools.
Bertil
Thread: Cutter and lathe tool grinder advice need
02/03/2013 21:23:52
Hi
I think i start with Harolds rest first, as it is easy to make and cheep too. Then i vill make an havier one.
Witch one, im not sure.
Would be interesting to se the drawings of the BSMME grinder.
Im glad to be here at this forum, you are all so helpful.
excuse for my bad english.
But im much better at swedish
Bertil
02/03/2013 20:51:32
Hi
Is there anybody who use this program.
If so, im interested if its good or not.
www.planet-cnc.com
Bertil
Thread: Schedule of the TB6560-V2 stepper control card
27/02/2013 20:27:46
Yes John i have , but have not get any answer from the seller.
Bertil
27/02/2013 20:24:25
Thak you Les.
What programmer dis you use to program the PIC.
Bertil
27/02/2013 18:23:13
Thanks
Les J, i looked at you album and found an interesting tacho, do you have the drowing and what kind of sensor are you using to it.
Bertil
27/02/2013 18:07:18
John S have you looked at you cd?
Bertil
27/02/2013 18:03:39
Hi
Harold I think about the one in the book "Milling a complete course".
Im not a member of the bristol modellenginners so I could not open the drawing page.
So howe to by the Colyer/Caseley cutter grinder drawing then.
Bertil
26/02/2013 19:49:04
Thanks
Harold
I have looked at your sanding block many many times in the grinding book. but thought it looked a bit too weak out.
But now understand that it is not so.
So I am considering making it along with the accessories.
Maybe I enhances the foot with a micrometer adjustment.
Bertil
JD Metals
