Member postings for Mark P.
Here is a list of all the postings Mark P. has made in our forums. Click on a thread name to jump to the thread.
Thread: Broadband woes
11/08/2022 14:59:35
I changed from BT to Vodafone for my broadband and home phone mainly because there was no line rental with Vodafone, my monthly phone bill is around £36 I get unlimited download too. My mobile has been PAYG with Vodafone for 25+ years.
Regards Mark P.
Thread: Chinese lathe vee belt
02/07/2022 16:10:41
When I did the same to my WM250 I used SPZ taperlock pulleys which gave me a good choice of belts at reasonable prices.
Mark P.
Thread: Imperial v Metric Measures
11/04/2022 14:57:23
I tend to use whatever system of measurement is appropriate at the time.
Mark P.
Thread: Material for wheels
08/04/2022 16:35:44
How about some large bore steel tube / pipe.
Mark P.
Thread: Paint question
20/11/2021 14:44:42
Maybe you could go over it with satin lacquer if compatible?
Mark P
Thread: Chuck Guard
03/11/2021 11:30:08
My WM 250 lathe and my Warco VMC both came with chuck guards, I removed them as they were in the way. I couldn't see what I was doing close to the chuck on the lathe, and the one on the VMC fouled the vice.
Mark P.
Thread: Chain Protection Sleeve
06/10/2021 12:37:12
How about a bit of polythene tube or a bit of hose pipe?
Mark P
Thread: Hello Chuck
05/09/2021 14:11:50
I use a 1 - 10mm keyless chuck on my lathe, probably a far eastern one,
not had any problems with it.
I
Thread: Cutting holes in copper
10/05/2021 18:20:36
How about clamping it between two pieces of plywood and using a hole saw?
Mark P.
Thread: There may be a delay in some deliveries ...
24/03/2021 18:29:32
Mr Philips must have been the navigation officer.
Mark P.
Thread: WM16B Draw Bar
03/01/2021 13:56:09
I used to use an Austin mini brake adjusting spanner when I had my WM16.
Mark P.
Thread: Basic Maths: A Lost Art
21/11/2020 16:37:23
Spare a thought for those of us who suffer with dyscalcula, not everyone is a mathematical genius.
Mark P.
Thread: I’m struggling!
25/10/2020 09:20:23
Hi John, mine is about 6 years old, I don't think that they would change
the spec but a call to Warco would confirm it.
Regards Mark P.
24/10/2020 17:41:08
Hi John, the belts are A750 and A900, that's what fit my Warco VMC.
Regards Mark P.
Thread: Circuit board repair
15/08/2020 15:15:08
Hi Dave, you could probably get a new board from Arc Euro trade.
Regards Mark P.
Thread: The cost of cheap (Free) materials
22/06/2020 17:03:10
Being time rich and monetary poor, I tend to use scrap bin materials.
Mark P.
Thread: Mag Base
28/02/2020 18:25:48
Would it be the same for magnetic chucks?
Mark P.
Thread: Cleaning an old lathe
15/02/2020 12:18:59
If it was mine I would steam clean it.
Mark P.
Thread: Clarke cl 500
04/02/2020 19:02:57
John, have a look on ebay, loads there and I think
that Machine Mart sell motors cheaper than £400.
Mark P.
Thread: Honda Brake Cable
18/01/2020 18:42:10
How about buying a longer similar one and cutting it down? Worked for m
Mark P.
Rapid RC
Dreweatts
