Member postings for Keith Long
Here is a list of all the postings Keith Long has made in our forums. Click on a thread name to jump to the thread.
Thread: Help with ultrasonic cleaner
13/03/2017 17:26:12
Even worse - that type of european plug doesn't have provision for a fuse. The cleaner will be relying on a unit mounted mains input fuse if it's got one, but being of German manufacture I'd be very surprised if it didn't have one.
13/03/2017 16:58:01
Hi Todd, welcome to the forum.
I can't help with any info on the cleaner but the mains plug (the round one) is a standard 230 volt single phase ac plug as used in continental Europe - well certainly in Spain anyway. The live and neutral go to the round pins and the earth to the side contact. In Spain the plug will go into the wall socket either way up so it's pot luck as to whether the on/off switch on the unit winds up switching the live or neutral. If you are changing the plug try and find out which of the wires from the plug goes to the switch and make that the live connection. You may find that both wires go to the switch which would then be a double pole device switching both live and neutral, and then you'd have no worries which side you connected to live.
Thread: Drummond Shaper
12/03/2017 20:28:36
Hi Chris, I can't help with details of how to do it but you should try asking on the Drummond lathes Yahoo group, there are quite a few folk on there who either have, have had or have got knowledge about the shapers and can give you the info that you need.
Keith
Thread: Drummond 4" roundbed changewheel pins.
02/03/2017 16:47:22
Andrew, I've just checked one of my round bed gear wheels taken at random with the following results.
One hole is tapered and the other plain. The plain hole in my case comes out at 4.9mm which probably means a number 10 drill, but it won't cause any problems if you use a 5mm drill - the pins are a very loose fit in the plain hole. The tapered hole is for a 3/16 in. taper pin which being imperial will have a 1 in 48 taper, metric pins have a 1 in 50 taper. Again in reality I don't think it will affect their use if you opt for metric pins of an appropriate size - probably 4mm as metric pins are sized on the smaller end whereas imperial pins are sized at the the larger end. I gather imperial pins are difficult to obtain now so you might have to go the metric route anyway - unless you fancy making your own!
The length of the pin overall came out at 1.11 in, probably would be specified as 1 in. as the domed ends are NOT included in catalogue lengths, but that is likely to be variable as tapping the pins in and out of the gears tends to flatten the ends anyway. You really only need the pin to be a bit less than twice the thickness of the gear as if it's any longer there's a danger of it catching on the banjo when you're trying to drive a compounded pair if it sticks too far through the second gear.
If you stick to those sizes then there shouldn't be a problem with using your gears with any other "original" Drummond gears - at the age of the machines many of the gears around could well be "modified" as well as worn anyway.
Thread: Need To Help Four Stroke Combustion Engine on 3D model
11/02/2017 18:32:58
Tim in Jon's 3D model the starter is labelled item 20 with the starter solenoid as 19.
Muzzer and Michael, I think while there are some superficial similarities to the Merc power unit, from following the link that Neil found to the origin of the model and looking at some of the internal details I'd be very surprised if Mercedes had any input to the model at all. As I said earlier - a 24 valve engine with only 12 push-rods, and each of those operating 2 valves by pushing on a bridge piece attached to the stem each of the valves. That would put an appreciable side load on the valve stems, which in turn would give quicker guide/stem wear, so considering that Mercs are known for reliability it would seem a very odd design decision.
The cylindrical item the OP asked about is not only belt driven but the crank pulley seems to be spaced off from the crank by a vibration damper or similar, so another level of disconnect to what appears to be some sort of oil pump - surely not a satisfactory solution for a real engine as opposed to a design concept.
11/02/2017 12:49:35
Jon - some of the other points of that engine look a bit odd as well - 4 valves but only 2 push rods per cylinder with the vales actuated in pairs by a bridge piece that the rocker arm bears on. As you said, if the cylindrical part is the oil pump then external drive seems very odd (what happen if the belt breaks or comes off - it's been known?) and unless the engine is very low revving would be going a a heck of a speed with subsequent high power consumption just to push the oil round, as well as the possibility of inducing foaming in the oil - which you don't want.
You could be in danger of showing your would be learners some dodgy engineering I think.
Thread: Salt shaker
10/02/2017 18:59:26
Posted by Neil Wyatt on 10/02/2017 18:51:45:
You need free-running table salt with 1% sodium ferrocyanide in it.
What was the brand with a blue label and boy pouring salt on the tail of a chicken?
Cerebos
Thread: Changewheel ID sought please
31/01/2017 23:45:06
I don't think that they're Drummond gears, the spec. for those is 14dp and have 2 holes - at least all of the ones I have (a LOT) , might be early Myford ML1-4 possibly?
Thread: Vertical Mill
31/01/2017 15:55:08
Curtis there is a plan on this website for the conversion of a cross vice to a vertical slide. If you do an internet search for "vertical slide plans" you'll come up with a load of suggestions for the job.
Thread: Coupled Wheel Geometry (Fusion 360)
31/01/2017 15:40:41
Looks like a perfectly permissible action - what you're missing is the set of coupled wheels on t'other side of the loco chassis with the quartering across the axle.
Thread: Drummond Round bed lathe
29/01/2017 17:12:36
Hi Andrew - your easiest option is to keep a look out on E-Bay for Drummond change wheels they come up regularly. They are fairy distinctive - the two pin holes being a bit of a give away, OK I know other lathes used a similar system but Drummond wheels out number those. Drummond gears are the same fitting for the early flat-bed lathes, round-bed, type B and the M type so plenty to look out for.
There were 2 different sets designated for the round beds depending on the age of the lathe. Pre 1925 lathes the full set was 20T (2 off), 24T, 28T, 32T, 36T, 40T,44T and 64T, with 25T, 35T, 45T, 50T and 63T as "extras" for metric threads. The post 1925 lathes had a different set of wheels, being 20T (2off), 25T, 26T, 30T 35T, 40T (2 off) 45T, 50T and 66T - this set will do both imperial and metric threads. It doesn't matter which set you build up really as both sets will work happily on round beds of any age.
If you haven't already done so it would be a good idea for you to join the Yahoo Drummond lathe group. Plenty of keen owners there willing to share advice, a host of photos of members lathes and a very useful set of files with information on the various Drummond lathes.
My experience in buying Drummond wheels is that generally they cost no more than those for a Myford or a Boxford - often less as they tend to be less popular and sought after, and you avoid the hassle of having to make them fit. Beware that some sellers seem to think that they are gold plated at least if not solid gold with the prices that they ask, but it's a bit like missing the bus, there'll be another one along soon so you don't have to jump in and pay silly prices if you don't want to.
Thread: Newby asking question.
14/01/2017 17:13:19
Richard - you should find this lathe (link) in the Axminster catalogue, looks to be very similar to the Grizzly one mentioned above.
Keith
Thread: missing lathe parts on a drummond lathe? ID please
06/01/2017 18:36:15
Phil - the following link might help (http://www.lathes.co.uk/latheparts/page3.html) also worth looking on the same website for details of the Drummond lathes as well as the other pages that explain all the various bits of a lathe.
Keith
Thread: cutting slots in Perspex ?
25/12/2016 16:07:50
Hi Tim, I can back up what Murray says about solvents causing cracking, the last time I tried cutting perspex both meths and white spirits caused small cracks running from the cut edge. If I was doing it again I think I'd try ordinary water with some washing up liquid in it to ensure wetting. I think aged perspex is even worse for cutting than new, as it tends to be more brittle. Don't use too fine a blade though as the material can (will) tend to melt back into the cut and the blade.
Really it's probably a case of trying it and modifying your technique as you go. Best wishes and good luck!
Keith
Thread: Pratt Burnerd 6 inch 4 jaw independant lathe chuck
23/12/2016 22:52:39
Sean - I've made a few nose adaptors and backplates for my lathe and I have always threaded the item right through and then cut the register into the end of the thread, all at one set up, so you're working into what will be the "back" of the backplate / adaptor. That way you can see what is happening with the thread at the start without having to peer into a recess - although with the diameter of the one you're doing that shouldn't be too awkward. It also mean that you can clean up the start of the thread as you cut the register, and I tend to make the register recess deliberately slightly longer than needed to ensure that the register actually seats on the abutment face rather than get the backplate (or whatever) thread running into theleading edge of the register before the register is properly seated. So far for me that's worked out OK and I'm happy with the run-outs that I've got on the various items that I've machined.
Thread: lever or cam operated parting off tool
23/12/2016 21:22:28
Neil - try "lever operated cut-off slide" as an internet  search term and then have a look at the pictures that should come up. Plenty of food for thought.
Edited By Keith Long on 23/12/2016 21:22:56
Thread: What Did You Do Today (2016)
26/11/2016 15:10:06
Neil - sounds as if your about to embark on an exercise of "re-inventing the wheel" All the stuff you need is already available, go on to the Model Boats website and send a pm to Dave Milbourn. Tell him what your trying to do, he'll probably be able to quote you the module numbers that you need off the top of his head - he developed them.
So called tank steering using multiple motors is quite common in multi screw model boats with separate motors, either used alone or in conjunction with a rudder or rudders.
Thread: Electric steel
03/11/2016 21:51:31
Rainbows - stick "motor laminations, uk" into Google as a search term. Several possibilities come up including at least one that says they work on prototype to low volume orders, and photo-etch them which avoids press tooling costs.
Thread: Tools I would like to have
24/10/2016 15:11:27
Posted by roy entwistle on 24/10/2016 14:33:52:
Tim I recently bought 12 in Hacksaw blades for wood Similar teeth to a bow saw Sorry I can't remember where but they are out there
Possibly Aldi? They were recently selling a hacksaw frame with 3 blades, 18 & 24 tpi for metal plus a 4 tpi that was very like a small bow saw blade. Haven't seen the blades separately yet, but out there somewhere.
Thread: Screwcutting Acme threads
16/10/2016 21:47:57
Robin - Michael G has just beaten me to it - my thoughts exactly - careful checking is certainly called for.
Ausee.com.au
TRANSWAVE Converters
