Here is a list of all the postings Baz has made in our forums. Click on a thread name to jump to the thread.
Thread: Cowells Milling/ Z axis design |
16/05/2022 16:51:17 |
What are compression bearings? I will take a wild guess that you mean thrust race, and that would go under the assembly that rotates. |
Thread: Looking for a Sharpening Service for End Mills & Slot Drills please |
15/05/2022 15:46:27 |
Surely it’s better to regrind the cutters than throw them away |
Thread: Re-boring Grind Wheels |
14/05/2022 19:32:38 |
Martin is correct, some were, maybe still are made with a lead or lead like material in the centre, others are 1 1/4 diameter with reducing bushes, the only part of the wheel that you fiddle about with is the outside diameter, and that is with a dresser. I have seen wheels let go and the damage caused, only a moron would fiddle about with the bore, just my two cents worth, from someone who worked for a company making grinding wheels. |
Thread: J & S surface grinder - refurbishment |
11/05/2022 16:39:44 |
Think I would be inclined to fibreglass it, now it’s been blasted you have a good surface for it to bond to, if you can do it on both sides so much the better, unless you absolutely love mig welding plates on. |
Thread: Super 7 adjustments question |
09/05/2022 08:04:13 |
Can anybody please tell me how warm a correctly adjusted super 7 headstock should run and also how much oil it should use. Mine stays cold even at top speed and I suspect the bearings are slightly loose. |
Thread: Total cost + import for Tormach PCNC 440, and alternatives? |
08/05/2022 13:31:09 |
This seems to be a common problem, the forum gives advice and very few ever say thank you or tell us how it all worked out. I certainly won’t be buying his book either. |
Thread: Very disappointed Alan Bramson |
07/05/2022 11:22:42 |
Oldiron I am sure Mr Branson is entitled to complain any way he wants, creepy crawly way or straight for the jugular. |
Thread: Which beginners lathe is best |
05/05/2022 08:59:36 |
I am sure that if you search the forum you will find plenty of posts about which lathe is best as the subject has been done to death many, many times in the past. As Chris says you must decide what you want to do with it and how much you can afford to spend etc etc. |
Thread: Suggest a repair method for broken aluminium alloy casting |
02/05/2022 11:01:32 |
I bought some of the rods that were being demonstrated at the Harrogate exhibition quite a few years ago, I used them to build up a couple of Sweet Pea loco smokebox saddles that had been fettled way too much and there was nothing to machine. This stuff built the edge up beautifully and stayed put through subsequent machining operations |
Thread: making spindle bearings |
02/05/2022 10:54:12 |
Why don’t you bore the bronze, that way you will get a nice round hole and you can make it whatever size you wish. |
Thread: What type of Collet are these please? |
30/04/2022 17:37:27 |
Posted by B Tulley on 30/04/2022 16:17:02:
There's about half a dozen, ranging from 3/16" up to 1"; I can check actual sizes of all if that's useful. Which part of the collet refers to the 3/4" or 1.1/4" size? It is usually the largest diameter of bar that the collet can accommodate. |
29/04/2022 17:19:27 |
They look remarkably like Britan collets, Andrew beat me to it ! Edited By Baz on 29/04/2022 17:20:51 |
Thread: Looking for a non-magnetic, strong, easily glued material |
29/04/2022 13:43:49 |
The relevant question is that you claim to have a PhD, Andrew told us about his and stated it can be read in Cambridge University library and asked where yours was, it is not a war of words it is a simple question, please let us all know about it and where we can read it. |
29/04/2022 11:36:10 |
PS: A copy of my Ph.D. is available for reading in the Cambridge University library, where is yours? Edited By Andrew Johnston on 28/04/2022 21:06:35 Mr McDonald seems to have forgotten to answer Andrews question, just a gentle reminder for him. |
Thread: Workshop warming |
28/04/2022 16:48:41 |
Totally agree Jim I am the same, dehumidifier runs all year round and as much heat as is needed during winter, I would rather spend the money on enabling me to enjoy my hobby, if I keep it no doubt the care home will get their grubby fingers on it and having first hand knowledge of how the mother in law was treated in a home they will get as little as possible from me. |
28/04/2022 09:39:22 |
Totally agree with Joseph, and if you want help have the decency to tell us all about what you are doing, also how about YOU try doing your own research, stop using the typical manager technique of delegating everything and doing nothing yourself. In short tell the complete story of what you are doing, why you are doing it etc. Nobody minds helping people achieve their goals but I suspect this a business venture and in MY opinion you are taking the p**s |
Thread: Supplier of 7/32" Dowel Pins Please? |
22/04/2022 20:23:47 |
Buy a length of 7/32 silver steel, you will be able to make a couple of spare sets out of a length. Don’t bother hardening them, if you wear them out put new ones in. |
Thread: Murad Cadet Restoration Project |
18/04/2022 17:57:56 |
Wow what an excellent range of threads 2.5 tpi to 96 tpi. |
Thread: Sigh, practicing a skill I would rather not need |
18/04/2022 11:35:01 |
Thor cannot understand a word in the link you posted but they look like stellite drills, great for drilling anything hard but have to be run hot, no coolant. Unfortunately stellite is now difficult to get hold of. |
Thread: cutting pyrex tube to length |
16/04/2022 16:49:24 |
Diamond wheel in a Dremel? |
