Here is a list of all the postings Robbo has made in our forums. Click on a thread name to jump to the thread.
Thread: Min lathe steady rest for up to 65mm diameter |
26/12/2018 23:52:55 |
Have a look at this page on Harold Hall's website homews.co.uk - **LINK** There are lots of designs about |
Thread: My ford lathe problem! |
24/12/2018 12:32:13 |
John Better but not fixed! Still have a job getting the screwdriver blade into the slot without using 2 hands. I am supposed to be getting rid of any stuff not actually needed, so the switch can go and start a useful life. Back in the day I used to repair Myfords, usually switched with the dreaded Dewhurst rotary, and owners were very keen to have those renovated rather than replaced with one of these vastly superior switches. I haven't seen one of these for a very long time. If you open the message I sent we can sort out the details by email rather than in public. It won't cost you a lot |
23/12/2018 16:45:17 |
John After a Doctor visit this morning can manage to do this myself without too many shakes, so have taken a pic of my switch which seems the same as yours. Pics below If you check out the items noted by Les Jones, who is a whizz at this electrics lark, and still need a replacement, then let me know. I will send you a message with my email address, pick up the message from your Inbox at the left hand of the green bar at top. |
22/12/2018 17:51:47 |
Sounds like John's switch is the one specifically used for Myfords, is in a substantial cast housing, and came with specific wiring instructions for Myford use. I have an unused one "on the shelf", but have never tested it. These are not like the smaller switches with a cam and spring lock to hold the switchgear in place, but have a built in NVR capability. If there is no voltage flowing then the knob will return to the off position. Seems like the NVR coil has called it a day, or become disconnected, so the contacts can only be kept closed by holding the knob in place. A picture of the switch will help identify it Edit - must acknowledge Mrs Robbo's help in typing this Edited By Robbo on 22/12/2018 17:54:26 |
Thread: Myford taper turning attachment |
15/12/2018 23:16:44 |
Posted by Brian Abbott on 14/12/2018 15:49:12:
Hello all. Would some kind person be able to post the basic dimensions of the gip strip, have misplaced mine. Thanks in advance. Brian Robbo himself is still incapacitated, but I asked him and he says the gib strip on the taper turning att. is the normal Myford 3/8" gib strip (with one bevelled edge) and you are best to get hold of an old ML7 topslide gib strip and shorten it to size. You will also need to drill new dimples for the adjusting screws. Mrs Robbo |
Thread: Drummond paperwork |
28/11/2018 23:34:25 |
Merlin will be sending the Drummond papers, so we will see when they arrive. In slow time probably as my "Dicky Ticker" is playing up just now. |
26/11/2018 23:13:30 |
Have sent you a PM |
Thread: Southbend 13" lathe. |
25/11/2018 23:07:51 |
You might also like to look at the ebay store (for South Bend) at **LINK** Bit eye-watering though |
Thread: Drummond round bed and VFD |
24/11/2018 17:00:14 |
The text shows that the 5 cyl radial engine was shown at the ME exhibition in 1924, so Bob has probably got it spot on. |
Thread: 3 PHASE 9 WIRE MOTOR |
23/11/2018 23:15:06 |
Posted by John Rudd on 23/11/2018 16:11:54:
So each phase has two coils in series for 440v or in parallel for 220....so for you running it from a vfd with a 240 output you must have it wired in lo voltage format? That's correct John. Wired as the right hand diagram. Works fine. |
Thread: Creating half a hole |
23/11/2018 15:03:03 |
Posted by Brian Wood on 23/11/2018 13:45:57:
Here's another suggestion. Use a holesaw bore a hole through a short section of bar, having run a pilot hole through ahead to support the plain part of the guide drill in the holesaw carrier. Then cut the hole across the diameter to make the two spacers Regards Brian That's what I was thinking Brian, except I would use a Rotabroach to cut the 25mm hole. |
23/11/2018 14:54:37 |
All I can offer on this is a pic of the data plate of an American 9-wire 3-phase dual voltage motor that I have. This seems to follow the wiring shown in Les's link. The actual wires are all the same colour and are numbered from 1 thru 9. I have it set up for low voltage Delta via a VFD, so no point in showing the actual wiring. At first I found it confusing that 3 wires (4, 5, 6) are connected together when in Delta when on our 6 wire configuration this would be for Star. The "Y CONN" refers to the connections to the left. Sorry this is all numbers and not number and letter combinations. |
Thread: Myford imperial vertical slide gib threads |
14/11/2018 10:20:12 |
hi John The cheese head screws that hold the feedscrew nut are 4 BA. Probably 3/8" long. Those are what you mean. When my brain saw "top of the slide" it stuck on the feedscrew bracket as that's on the bit that slides up and down. Any other words ignored . Funny things, brains. In Imperial sizes Myford went for 2 and 4 BA for screws and bolts less than ¼", then either BSW or BSF, but to be contrary you might find a 3/16" BSW somewhere. Caveat: on old Myford kit there is always the possibility that someone has changed things. Edited By Robbo on 14/11/2018 10:23:50 |
13/11/2018 21:45:03 |
John The Imperial gib adjusters screws and locknuts are 2 BA, same as the older ML7 lathe slides. The 2 screws holding the bracket to the body are also 2 BA, x ½" and are usually socket cap screws, not cheese head. If you have problems sourcing either, drop me a message, I've probably got some left over from my days as a Myford "fixer" Edited By Robbo on 13/11/2018 21:46:34 |
Thread: Do you clean up your rough end |
12/11/2018 17:18:57 |
Bill The 60 year old scar on my thumb reminds me to always clean up rough ends |
Thread: Mystery adaptor for MT4 shanks |
12/11/2018 12:08:05 |
Is this old thread about Triumph/Colchester spindle any help? - **LINK** There is something in my brain that tells me this has come up before, but the brain won't let me know what it is As the Doctor said, "Don't worry, you haven't got dementia, you're just a stupid old git" Edited By Robbo on 12/11/2018 12:11:41 |
Thread: Pulley/Belt choice - Drummond |
09/11/2018 18:54:17 |
poly v pulley.jpg = **LINK** |
Thread: Dore westbury |
08/11/2018 17:16:51 |
Further to previous post. The original bearing specification (for both Mk 1 & Mk 2 machine) item 423 in the drawing, are "angular contact ball bearings, 1" id x 2¼" od". Edited to insert t in the! Edited By Robbo on 08/11/2018 17:17:53 |
07/11/2018 23:38:03 |
John Also recommend you join the Yahoo group "dwmill". In the meantime, here is part of the drawing showing the head and spindle. This is the Mark 2 Dore-Westbury, you don't say if you have a Mk 1 or Mk2. Excuse the oil stains If you send me a message with your email address (click on "message member" at bottomleft of this box) I can send you pdf s of drawings. |
Thread: What an earth are they called...... |
01/11/2018 14:29:33 |
This type of spring clip and pin is widely used in the disability aid market, for securing adjustable legs on stools etc.by the pin going through corresponding holes in an internal and external tube They usually consist of a plastic horseshoe with a steel pin. In this context they are known as a "push-on pin clip" |
