Member postings for peter allen 1
Here is a list of all the postings peter allen 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: dro encoders
28/01/2014 21:20:54
I bought the Allendale kit for my Tom Senior some time ago but have not yet had the confidence to install it. I wanted to keep the functionality of stops and power feed trip and have not worked out how to do this.
Merry millers photos very encouraging to me although I cannot quite see from the photo if your stops and power feed lever are operational. Is that a special feed lever?
Is there anything that you would do differently?
Did you by any chance keep details of the dimensions of the brackets?
Thread: PV BAKER REPAIR
05/05/2011 23:46:57
I need to remove the pettycoat pipe to access and remove the blown superheater on PV Baker on a loco loaned to our club. The drawing shows it to be inserted into a brass casting but no means of fixing is shown. The pipe is copper the casting brass, there are no signs of solder or grub screws. I have made up a stepped drift to fit pipe but am reluctant to give more than a sharp tap with 1lb hammer this had no effect. The smoke stack casting is riveted to the smoke box but heads are not visible on inside. There is a copper reinforcing ring which appears to be integral with petticoat pipe covering up where rivet heads would be Any hints would be appreciated.
Thread: Logging on Problems
25/08/2009 09:19:42
A suggestion to web master .   Setting up account not clear which of the numbers is the subscribers number.  three sets of numbers appear on envelope of mag the last set works it took me two goes to get it! Suggest add " format MEMxxxx" next to subscriber no. on web page.
EngineDIY
