Member postings for Versaboss
Here is a list of all the postings Versaboss has made in our forums. Click on a thread name to jump to the thread.
Thread: Emco FB2 Quirks and Additions
30/07/2020 22:51:16
I have sold my Emco mill, but know the buyer. For an easy solution to the oil problem, would it be possible to drill a say 1 mm hole through the hex key opening, and then fill that opening with a piece of foam or plastic sponge. Air can escape, and dirt cannot go in.
Kind regards,
Hans
Thread: Overseas Distribution to restart
24/07/2020 12:53:32
Ok, I was away from home for a couple of days, and something has happened in between.
It must be clear now that the missing MEW issues had been edited and printed, they just did not make it to the post office. First hint was the post from Mr. Dias Costa, stating that he managed to byi these issues. So I started searching around and found - just to the left side from the Editor's bench! - a line in the imprint with a web address for 'Current and back issues'. : www.mags-uk.com. I don't know if this is part of MTM, at least it was never mentioned in this thread. So I went there and could place an order for the two issues I miss, and as the order was accepted I hope I will get them some day.
My thanks goes to Neil, he at least wrote that he could do something also. I suppose this is not necessary now. But this email story he mentioned: I never got an email from MTM - until last Tuesday, 21/7.,when the ball was already rolling here. It came from a Ms. Kate Parkes, email customer services, stating: " I'm sorry to read that you haven't been receiving your magazine. I have arranged for replacement copies to be dispatched, please allow up to 10-14 days for these to arrive within Europe and up to 28 days for the rest of the world."
So it seems that in a couple of days I will mot only have the missing issues, but TWO of them... I just hope there is not a subscriber getting nothing because of that. In case, he can write me...
Here we have a saying: where there is a will, there is a way. But sometimes the will is missing...or working very slowly at least.
Hans
20/07/2020 22:58:14
Posted by JasonB on 20/07/2020 18:22:30:
Tim, all subscribers who did not get the mags were given free access to the digital versions plus the whole of the rest of the digital archive.
Jason, it would be VERY nice of you if you could explain in detail how we all, which miss MEW 293 and 294, can get access to these digital versions. Does somebody over there REALLY know that we didn't get them? At least I, as a 'paper' subscriber, have heard nothing from MTM. That they are unable to supply the missing paper issues is a shame. To the left from the 'Editor's Bench' there is a tel. nr. and website for 'current and back numbers'. Is that futile?
A bit miffed greetings,
Hans
Thread: cateracts.
15/07/2020 14:53:27
Ok, don't think I want to spread panic among the prospective users of silicone replacement lenses - but it must be said. Well, seems that I wrote about this somewhere in 2016, but repetition does not hurt.
Fact is, the docs always tell you about a surgery with absolutely no problems, but that is not always true. And when something goes wrong, then it is too late.
In my case, somehow the retina was badly damaged, and now in my left eye I have a totally distorted view. What it makes even worse is that there are none of the so-called positive effects of the cataract surgery, e.g. diminished blending and reflections. The only difference is that the untreated (read undamaged) eye sees white as just a little bit yellow.
I had then a second eye surgery, removing of the glass body (Leo says vitreous body), but with no positive result.
Just about a month ago I had again a scan of my eyes (retinas, to be exact), here are the two pics, so you can judge for yourself. Sorry, I didn't manage to bring both in the correct orientation, I can rotate the pics on the screen, but found no way to store them afterwards.
right (normal):
left (damaged):
Hans
Edited By Versaboss on 15/07/2020 14:54:40
Thread: SuperGlue as a means of holding in lathe
14/07/2020 22:07:29
MichaelG, falling for a troll (again?)...
Hans
Thread: MEW295
08/07/2020 13:42:45
Do I read that correctly, you are speaking about something in MEW issue 295???
The last issue I received was 293, May 2020. Something lost in transit, how long should I wait before taking action?
Waiting too long, and the leftovers are on the recycling skip.
Hans
Thread: What filament material do you use on your 3D printer?
06/07/2020 14:32:18
While I don' want to detain someone using ABS filament, I gave up after just a few trials and gave my spools away,
What I use now is ASA, with a bet temp of 80-90°, and a nozzle temp. of 235-240°. According to my IR thermometer, the real bed temp. is somewhat less. The print surface is BuildTak, anything holds perfectly on that.
material #2 is PET-G, bed temp 70°, nozzle temp 225°. No problems with the prints.
My printer is an Ortur, quite happy, although the print surface as delivered was scrap, and the leveling sensor does not work correctly. But the guides are imho better than what is used on Creality and Anet and similar ones.
Hans
Thread: Free or inexpensive 2D cad for clock wheels
01/07/2020 22:10:11
Well, I was interested in some features in this (up to now unknown to me) CAD app 'Back to the Drawing Board'.
Tried the whole evening to download the trial version, but no success. Although I had a MS account, and I could login to it, the download window did not recognise it. I went then through the quite complicated route to reset my password and rejoined with a new one. But what happened with that: yes, just the same. I can login to my account, but the download site says sorry, your password is wrong.
As the app is available for different hardware, it seems that the PC (this PC) should be known to the MS account. But what to do to register it - I dunno. Maybe I'm really too old for stuff like that.
Kind regards
Hans
P.S: would Mr, TickToc kplease stop citing every line in every entry, and then answering with one line... ISTR that we had this before, many weeks ago.
Edited By Versaboss on 01/07/2020 22:15:53
Edited By Versaboss on 01/07/2020 22:16:21
Thread: How to glue plastics
07/06/2020 17:13:28
Posted by Dave Halford on 07/06/2020 09:43:13:
You can glue most hard plastics except ABS (which requires a specialist glue)
Ok, here I cannot have my mouth shut. I suppose in that sentence a 'not' is missing.
ABS is one of the easiest plastics to glue. It can be dissolved in Acetone (every 3D-printer knows that), and bonds also to Epoxies and Acrylics.
For 'most hard plastics', the secret lies in the preparation. I see that the flame treatment has already been mentioned, and with this method I glued two plates from (I suppose) Polypropylene, and it would be very hard to separate them again.
The method consists of 'brushing' the parts with a Propane torch or similar, without melting the plastic, but it becomes then hydrophilic (in contrary to the water-repellent or hydrophobe surface the plastic usually has).
It is best to try this before if you have an offcut , if water builds a film instead of dropping off, you got it right.
I think I saw this method in one of the well-known Dan Gelbart videos.
Hans
Thread: Macro-photography
24/05/2020 12:27:26
Raphael, could you please tell us how much you moved the camera between these 30 images?
It would also be interesting if the stacking software says something what is sensible/necessary and what not.
Can images be stacked say with 1/100 mm distance, or is that nonsense? I hope you see what I would like to know.
Thanks, and regards
Hans
Edited By Versaboss on 24/05/2020 12:31:34
18/05/2020 13:21:59
When I saw the phone accessory lenses in the message from Nicholas Farr, I remembered that I also bought something like that, but never used it in earnest, Who keeps a box of accessories always in the pocket - not me.
But now out for a test. What I just had nearby was my Decca London cartridge. Gave quite a good picture, but not nearly good enough to check the diamond.
SOD mentioned the focus stacking method. Don't we all have a means to change object distance in very small increments, in form of the cross slide on our lathes? Methink it would be interesting to do some experiments.
Kind regards
Hans
Thread: Thread to discuss Solid Edge 2D and 3D
17/05/2020 23:09:44
Hello all,
Sorry for the delay, other matters went in-between, and I'm also unsure about what I want to write.
To begin with the last contribution from Barrie, I don't understand the last sentence. I found the 'settings' button on the left side, I think it is the same as also in the top line with the triangle mark. When I choose the first 'theme' which is 'First steps' (sorry I have German names, but I think that's what I used), then I get that reduced toolbar. I checked the other 'themes' also, there are changes all over the place, but I can't say if these are functionally equivalent. Anyhow, I switched now to the 'balanced theme', which here is called S.E. standard.
Stand now is the following: I tried to re-create a 'thing' I did in Onshape and which I found quite difficult to do, in the way I did it. Inagine a L, lying on the long side, but the short side not vertical. Like that perhaps: ___/
I could draw the L and give it the dimensions I wanted (easy in S.E), and then I found a tool to rotate it, with two sub-tools. The first I don't remember (and can't find that tool atm.), and the second was '360°'. That's what I wanted anyway, but to my surprise it did not a 360° rotation, but I could sweep it around with the mouse. I stopped at about 270°, and then tre resulting body stood here on the screen, but all in deep read! From other programs I know that red usually means something is wrong, but I couldn't see any error message. That's where I am at the moment.
Experimenting with the themes, I hit on another problem. In Onshape there is also a build tree on the left side, and in any moment it is possible to go back in this tree and make changes, if something looks not right. How it is possible to do that in the S.E. tree I did not find out. I would like to go back to the 2D sketch (have to use this Onshape name) and redo it from there, but how? Naturally it would be simple to draw it again, only 6 lines, but sometimes the begin is a bit more complicated...
Some other points: - I tried to find these Youtube videos by Design Fusion, but all except two are for Fusion360, and the S.E. video is about surface modelling.
I had a look into the S.E. Forums and went straight back. There's not really a chapter for beginner's question, but what I found are people complaining about the way the forum works. In Onshape (yes, again...) I could ask questions and sometimes even got answers back directly from the developers.
Ok, enough for today. I will be away for 2 or 3 days, but I will come back!
Kind regards
Hans
14/05/2020 22:56:27
I did just see that Barrie Lever started this thread as promised. So I jump in, full force.
Also, because I'm stuck quite hard atm.
Perhaps a word about me and my CAD 'experience' if I can call that like this. I never used any program professionally, but learned/used/dabbled in Autocad, TurboCad, GraphicsWork, TrueCad, ChoiceCad, AllyCad... and maybe some I have forgotten. I was one of the first 100000 users getting Xcad for free, which then later became Alibre. In none of these programs I got over more than a couple of simple drawings. Now, since some years, I'm using Onshaape and love it. So why trying to learn another program? Maybe just curiosity, and maybe because some things are integrated which in Onshape need paid extensions.
Jump forward to Solid edge now.
After I downloaded Solid Edge, nothing worked, as I had written before, but in this I was not alone. After a couple of days this problem was solved, and I started checking the tutorial videos. First disappointment was, that I found nothing about how to set up the program, as it has gazillions of 'levels' as it seems. It is very difficult to find a line in these videos. I had also a look into waht is available on Youtube, and there is some interesting stuff. But it is not easy to follow which actions someone executes on a video.
And this leads me also to the first problem. Almost in every video I see the Toolbar looks different, and these toolbars look Very different from that on my screen. To clarify, what I call Toolbar is the array on top of the screen, where the drawing tools are arranged.
Tutorial 1:videotutorial.jpg
Tutorial 2:anothertutorial.jpg
My Toolbar:mytools.jpg
And the clean Onshape-Toolbar:onshape_toolbar.jpg
So, what's the matter here?
Problem #2 maybe tomorrow
Kind regards,
Hans
Thread: Siemens does not like me...!
13/05/2020 12:45:39
As starter of this thread, I'm glad to report that Siemens again likes me... smiley
But after my first very modest trial, I already am in difficulties. As this thread has gone wildly off-topic (the inch conundrum), I'm asking if it would be appropriate to discuss these problems here (esp. with Mr. Lever, who it seems has good knowledge), or if it would be better to start a dedicated Solid Edge thread? (hopefully staying on-topic).
Opinions welcome!
Hans
09/05/2020 17:16:56
So I wanted also to see what all this noise about Solid edge is. Download Thursday night, went to sleep and installed on Friday. No hiccup, all ok. Then I clicked on one of the offered instruction files, and learned something about the different setups. But I had much trouble reading all, it's is in a very small and fuzzy font, and light blue on white is poison for my eyes. So when I stopped I was shown a box asking if this was helpful. I clicked 'no' and had the opportunity to write a remark. So I did, mentioning the two points above.
Returning today for another try, and nothing works. All the instruction boxes on the start screen are inaccessible...
Maybe that's the end with Solid Edge for me.
Hans
Thread: Things bought from ebay
04/05/2020 16:01:53
And maybe it's important to remember that the sign of these packages is the sign of the Red Cross, not the flag of Switzerland. So they must be sharp, the ambulance is coming in a hurry if you cut your finger!cheeky
Regaeds, Hans
Edited By Versaboss on 04/05/2020 16:02:38
Thread: Drilling carbon fibre
14/04/2020 12:42:36
I used to drill larger holes (10 -12 mm) in CF plates with Diamond core drills.Quite sure I got them from ARC in England.
So for smaller holes I think I would also use the small diamond burrs, e. g. from Eternal Tools:
here
Hans
Thread: Old model engineer magazines
11/03/2020 13:35:23
More of the same problem here...
I have a complete set of M.E. from 1924 (because I wanted 'all from L.S.B.C' to 2013. Sorry having to say, they will all end in the recycling bin, rather sooner than later. But if someone wants a couple and agrees to pay the horrendous postage, then ask...
Kind regards,
Hans
Thread: brazilian lathe restoration
07/03/2020 23:17:09
Posted by celso ari schlichting on 07/03/2020 20:37:30:
Posted by Brian H on 07/03/2020 08:07:11:
You are making an excellent job of what looks like a nice lathe. The only reference to the make that I could find was this;
Brian
tha plate STB means Sociedade Tecnica Bremensis. A company that imported lathes from Europe to Brazil and closed its doors in 1945. It is a very rare machine.
sorry my english is not very good, here we speak portuguese
greetings from Brazil
Celso Ari
Hello Celso (and Brian),
sorry but that is completely wrong. Your lathe is not the STB from Brian's link, and in his case STB means 'Fabrique d'Horlogerie de Saint Blaise S.A, Saint-Blaise (Suisse).
I own a filing machine from STB, the sign in the casting is exactly the same, but the number is '20'.
If necessary I can make a picture to prove.
More so, maybe your lathe is a Bremensis (never heard that, but what do I know...). I now have to watch the video, somewhere Brian must have found the letters? So possibly there is a firm using the same abbreviation.
Kind regards
Hans
P.S. Ok, I have seen it. So  what remains now is that Brian's STB is not your STB. My apology...
Edited By Versaboss on 07/03/2020 23:20:38
Thread: Drilling small holes in hardend steel
17/02/2020 22:23:54
It's nice to see that Mr. C.T-T finally also has learned how to quote correctly. For such an old git like me it is really cumbersome to find out who has written what. I sincerely hope that from now on, as you wrote, you will move on.
Kind regards,
Hans
rapid Direct
JD Metals
walker midge
Dreweatts
