Here is a list of all the postings Versaboss has made in our forums. Click on a thread name to jump to the thread.
Thread: Anybody already tried to download Solidedge ? |
24/09/2012 21:40:28 |
Good to know I'm not alone with this problem! I will try again tomorrow, and when the problem persists, call the phone number given on the website. Greetings, Hansrudolf |
24/09/2012 17:30:19 |
Just received MEW 195 today. A most interesting article about free CAD software got my attention. First time I heard that parametric 2D programs exist in the form of Solidedge 2D from Siemens. After almost useless struggling with non-parametric programs I was hooked. I use the parametric 3D program Alibre, but for simple 2D drawings this is not very suitable or comfortable Ok, made the registration with all the obligatory fields, but the download resulted in a (very strange) error message. I tried two browsers and several languages (for the software), but no success. To make the bucket full, the message contains an invalid email address. So has someone successfully downloaded this prog ? if yes, how? Greetings, Hansrudolf |
Thread: Going to put companies out of business? |
21/09/2012 22:05:57 |
Interested to read your comments about THIS latest development in 3D printing: Greetings, Hansrudolf Edit: trying to produce a link -ok seems to work! Edited By Versaboss on 21/09/2012 22:09:40 |
Thread: IXL lathe change wheels |
19/09/2012 21:44:35 |
Hi Keith, while I cannot help you with the gears, I would advise you - in case you decide to make the gears from aluminium - to replace the gearing for the power feeds with simple vee pulleys. I did that with my lathe a long time ago; until now I broke only one of the small Bando Polyurethane v-belts. It will be a joy for your ears when the hissing sound from fast running metal gears changes to almost absolute silence Second thought: not only for Aluminium gears, the benefit is there for steel/iron ones too! Greetings, Hansrudolf Edited By Versaboss on 19/09/2012 21:45:09 |
Thread: Small honing tools |
19/09/2012 18:15:18 |
For such an application lapping is much easier than (real) honing. Small honing tools are available, but at a price driving water into your eyes!!! Google pemamo. A lapping tool can even made from hard wood, and Chinese diamond pastes are cheap. Greetings, Hansrudolf
Thread: Drawing Projections |
19/09/2012 11:59:29 |
The all important words 'position / positioning' were mentioned first by TerryD (17.9./13:24), then by Keith Long (17.9./15:01), then Michael Gilligan (17.9./19:34). Words with similar meaning (e,g, Stub Mandrel: arranged) even much earlier. Sometimes it needs a long time to sink the simplest things into our brains, Greetings, Hansrudolf Edited By Versaboss on 19/09/2012 11:59:48 (name correction) Edited By Versaboss on 19/09/2012 12:00:48 |
16/09/2012 12:41:32 |
Oh well, let me try my definition. We have two drawings of the same thingie, one to the left, the other to the right. First angle: the picture on the right side shows the item as seen looking from left. Third angle: the picture on the right side shows the item as seen looking from right. In the case of that truncated cone it does not make much difference, but this also serves only to show which type of drawing it is. As was already told, in drawings of more complex nature it can make all the difference. By the way, all drawings I get in my semi-professional work are in first angle. Greetings, Hansrudolf
Thread: soldering copper to steel |
14/09/2012 21:59:53 |
It is not widely known - it seems - that an oxy-acetylene burner takes a lot of oxygen from the surrounding air. So I would be among these thinking that's a bad idea with the soldering of the tubes. Our club has a loco with expanded tubes. For this I made already two roller expanders (the first reached the end of its travel), and although the rolling was not too easy in the confined space, all went well and the loco doing fine again. For this tool I found a sketch in an old M.Eng; if there is interest I can dig out the issue. Maybe it's in Dias Costa's index?. There are no measures; you have to adapt the dimensions for your case. But it's not too difficult; I built it in about 4 hours (thanks to the Stevenson indexing blocks!). Greeting, Hansrudolf |
Thread: Machining graphite? |
13/09/2012 12:04:10 |
Almost on topic question Jack: where did you buy that graphite, and in which diameter(s)? There are some sellers in the U.S., but postage is often much more than the material. Greetings, Hansrudolf
Thread: Cylinder Boring Techniques for Steam Engines |
05/09/2012 19:37:22 |
Well, if you understand it THAT way what Clive wrote... he did not tell anything about fittings imho. Naturally you can use any thread you like, but you need more 'meat' in the fittings because the coarse threads are much deeper, and finally you have maybe only 3 or 4 turns in those short lengths. So take your choice. For a model with scale appearance the fittings should not be too clumsy. The boring tool size 1 would be best for the dimensions you gave.
Thread: metric fine grub screws |
05/09/2012 11:41:52 |
Posted by SLOTDRILLER on 05/09/2012 05:49:10:
Hi Garry. I had a dig around on the net and you can get M10x 50 Socket head set screws but none state the thread pitch and it seems only in stainless . A note for all the metrically challenged around here: Whenever you see a thread designated Mxx it is ALWAYS the standard (coarse) pitch for that diameter. All other (fine) pitches are correctly called MFxx. You can see that in the table above, posted by Michael. Greetings, Hansrudolf |
04/09/2012 23:13:09 |
Posted by Clive Hartland on 04/09/2012 22:17:43:
Will, I only use the standard series of Metric threads though I have a set of fine threads. As far as I can see there is no need to use the fine series for model work.
First thanks for the nice words Will and Clive Clive, what you write might be correct for fasteners, but not for steam fittings. Remember that the ME threads (as used on Imperial fittings) are also much finer than Whitworth!!!.
I could insert a page from the Imech Catalog, but you know it's a nuisance to insert a screenshot here Greetings, Hansrudolf (P.S.: Will, I have a 20 mm reamer...) |
Thread: Scrapyard Experience |
04/09/2012 22:59:13 |
Interesting story from Andrew. Well here it's a bit easier. I had some not so good experiences with the smaller scrap merchants around here (Method: have a look, tell a minimal amount) I went to the bigger ones. I have to say that I collected much material from a house demolition; usually I bring the steel stuff from the workshop to the communal recycling center. So I had a trailer full of steel/iron; most weight consisting of the heater radiators. At this place the same method as Andrew described: over the weighbridge, then they lifted the whole stuff with a large magnet (lifting the trailer too in the first tries!), then to the weighbridge again and getting some cash there. Steel price: CHF 160 per ton (I had 420 kg). Just paid a tank filling, but that's what I wanted. 1 CHF = £ 0.66 = $ 1.05 approx. For the other stuff (at a later date) I went to a really large scrapyard. No hard hat, no red jacket, no id card necessary there. But you had to keep the eyes wide open: swarms of forklifts driving around; large trucks everywhere and railway waggons being shunted around. You park the car in a safe corner and thell the very friendly man at the weighbridge what you have. As I had 4 different materials (copper from the rain gutters, brass from faucets, aluminium as profile stuff and swarf) he directed one of the forklifts to bring 4 containers (which had their empty weight written on a plate) around the car. Stuff went into the containers and off to the weighbridge. What's your name please; the office is over there. In the office there was some busy calculations, then I signed the receipt and a nice girl handed me quite a nice pocket money. They paid: for Copper: CHF 5.65 / kg (my first delivery a xouple of weeks ago it was around CHF 6, so the prices are quite volatile) Brass: 3.40 / kg Aluminium: 0.80 / kg (both swarf and large pieces the same, but treated as two articles) Unfortunately it is not possible to raid the large heaps full of interesting stuff. I wish they would open a small shop... Greetings, Hansrudolf |
04/09/2012 15:47:29 |
Not too bad if you interpret the points sensibly, David. I think he wants them 50 mm long. However, I have never seen grub screws with fine threads. Actually having troubles to see the catalog of my usual screw suppliers, so cannot definitely say if they exist or not. Threaded rods with fine threads exist, but not finer than 1 mm pitch. I would get a 10 x 0.75 die and thread them myself - or even on the lathe. Greetings, Hansrudolf |
Thread: Stringer EW lathe |
30/08/2012 21:42:39 |
7 days is far too less by a wide margin, David! Make it 70 at least!!!
Greetings, Hansrudplf |
27/08/2012 22:38:10 |
Posted by Will Robertson on 27/08/2012 19:16:06:
Hi Jason,
Will, I was not quite sure what you want, but stuff like that you can get almost literally just around the corner. Have a look here. and search in the "Katalog" Greetings, Hansrudolf |
25/08/2012 23:29:17 |
Posted by Will Robertson on 25/08/2012 17:28:23:
... Hi Hansrudolf, I live at the North end of canton Schwytz - near kussnacht am Rigi and Luzern. Look-a-there! Well it's Schwyz (with a long yyy), but Search.ch knows you nonetheless.Nice coincidence, just next to my garage. But the car was serviced 2 weeks ago, so no visit planned in the near future. I will send you my address via PM, so if you feel inclined you can come over for a bit of workshop talk. Greetings, Hansrudolf |
Thread: Silver Solder Identification |
25/08/2012 12:31:49 |
You still can get Castolin 1802 (similar to Easyflow) without problems in Switzerland. But the German site of Castolin does not mention it... Greetings, Hansrudolf |
25/08/2012 12:31:46 |
Thread: Sulphuric acid |
25/08/2012 12:19:56 |
Well, well Fizzy, don't exaggerate! I handled 98% sulfuric acid (in a glass bottle) when I was less than 14 years old, and I'm nearing 70 now. I don't think the small boo-boos I suffer now are reminiscences of the couple of skin burns I got from that stuff. SpeedyBuilder, it is a long time wish of me to make a visit in one of these French shops. Unfortunately I don't know any names, and cannot raid all possible shops in a reasonable time. So I would be pleased to learn some (chain shop?) names to be able to make a direct jump. It is quite well known that all kind of interesting stuff is still available there. Greetings, Hansrudolf
