Member postings for Versaboss
Here is a list of all the postings Versaboss has made in our forums. Click on a thread name to jump to the thread.
Thread: American Sites for you
18/01/2021 21:33:04
Accessing without problems from Switzerland (not in EU). Let's hope they realise the change soon...
Hans
Thread: Binocular loupe
14/01/2021 21:51:24
I have several lsmall oupes with LED lights, they are good for very short distances. I have also one similar (or possibly the same) as that in Nealeb's link. One problem with these is that it is difficult to adjust the lenses to point at an angle (hope you know what I mean) so that they focus at one point, the other is they are very heavy. Even with the rubber ribbon they don't keep position in front of the eyes. I have also very different sight between left and right eye, that's another problem. The adjustable light is good - well at least one positive remark!
Hans
Thread: The Old One - Broken Tap Removal?
02/12/2020 16:29:36
Supposed you own a grinder, it should be easy to test the remnant of your tap if it is carbon steel or HSS?
The sparks are very different looking...
I would mill it out with a carbide cutter,
Hans
Thread: Designspark 2.0
17/10/2020 12:04:39
Can it be that you are a bit in behind, Adi? Here I am on DS Mechanical 5.0...
Hans
Thread: Overseas Distribution to restart
13/10/2020 22:22:01
peezee, I went through the same problem. But quite by accident - because it is NEVER mentioned here in this forum - I discovered that all surplus mags go to an (unrelated to MTM?) organisation called www.mags-uk.com .
There is a small link on the second page of MEW (at least usually, I think).
Through this firm I could get the two (in my case) missing numbers, although I had to pay them again. But it was worth for me.
Kind regards,
Hans
Thread: Does anyone watch Mr crispin
06/10/2020 22:33:37
I saw one of his videos just a couple of days ago. What did astonish me was his dialect. Can someone here tell me from where he comes?
Hans
Thread: F2G Swiss championship, 19/09/2020
25/09/2020 16:15:39
Well, as I was quite active in control line flying, many years ago, I was quite 'electrified' when I saw that one of the very few events this year was the Swiss championship in Electro speed, class F2G. This class is only about 8 years old and maybe not so famous up to now, but I was really surprised! There were only 4 contestants, but the event ended with a world record of 302 km/h, and the 'slower' ones were not much in behind. This is even more astonishing because these motors have only about half the power of the best 2.5 ccm I.C. engines.
Here a couple of pictures, you may also see the reports in MG Breitenbach
and Fesselflug.ch
In German, but G... is your friend, you know smiley
The record holder:
The contestants
And we also had the honour of a visit by Mr. Bond, James! (or at least his car)
Kind regards,
Hans
Thread: Emco 8.6 - Tumble Reverse Position for Screwcutting?
05/09/2020 00:25:43
Reading that stuss above from Avery, (hi A. use that translator!*), I'm beginning to loose my will to live...
- the knob on the tumbler reverse lever is not the one which changes the feed speeds!!! This is on the side of the cover, see Jason's picture.
- I am old and cannot always trust my memory, but I am quite sure that for screwcutting that double gear is always removed, or in other words: a screwcutting setup never transmits over that double gear. The picture on p. 28 of the manual above shows the setup for normal turning., and the feeds 0.12 and 0.05 mm work only in that setup!
Jason displayed all very clearly in the piccies above, so I retreat now...
* ok, I do it for you: a nice word I found is balderdash...
Hans
03/09/2020 22:58:40
I'm quite sure what Avery mentions is the push-pull knob which changes between the coarse (0.12 mm) and the fine (0-05 mm) feed .
Many years ago I owned a Emcomat 8.6, and I am absolutely sure the tumbler gear didn't change the pitch of a thread.
I would be interested to see that >>visual indication/guidance/reminder cast into the change gear case door. It shows when the tumble reverse is in the up position, less screw threads result.<<
Hans
Thread: HSS replacement tool tips.
09/08/2020 16:32:56
Another, not very well known manufacturer, is Alesa
Here, the HSS inserts, but beware: they are not cheap! It is possible to get them piecewise, though.
HSS tooling
Hans
Thread: Arduino low power alternatives
08/08/2020 14:39:05
Posted by Andy Stopford on 07/08/2020 20:53:10:
Lastly, do yourself a favour and ditch the Arduino IDE - there are much better, easier to use alternatives, with full code completion, hints, colour coding, etc.
I use PlatformIO; it's available as a code editor plugin. I like the Atom editor, but you can use it with VSCode, and, possibly, others.
Hi Andy,
as a sometimes Arduino user I'm always interested in such stuff. However, all is not so easy. I managed to install the Atom editor, and then tried in vain to cooperate it with PlatformIO. What I now have, if I start Atom, is a black screen with a menu bar. There is also a menu point for PlatformIO. But after say a minute I get the message 'editor isnot responding.
I deleted Atom and re-installed it, with the same result.
And btw, IF that system would work, how could one compile the code and load it up into an Arduino? Copy/Paste to the Arduino IDE?
Hans
Thread: Emco FB2 Quirks and Additions
30/07/2020 22:51:16
I have sold my Emco mill, but know the buyer. For an easy solution to the oil problem, would it be possible to drill a say 1 mm hole through the hex key opening, and then fill that opening with a piece of foam or plastic sponge. Air can escape, and dirt cannot go in.
Kind regards,
Hans
24/07/2020 12:53:32
Ok, I was away from home for a couple of days, and something has happened in between.
It must be clear now that the missing MEW issues had been edited and printed, they just did not make it to the post office. First hint was the post from Mr. Dias Costa, stating that he managed to byi these issues. So I started searching around and found - just to the left side from the Editor's bench! - a line in the imprint with a web address for 'Current and back issues'. : www.mags-uk.com. I don't know if this is part of MTM, at least it was never mentioned in this thread. So I went there and could place an order for the two issues I miss, and as the order was accepted I hope I will get them some day.
My thanks goes to Neil, he at least wrote that he could do something also. I suppose this is not necessary now. But this email story he mentioned: I never got an email from MTM - until last Tuesday, 21/7.,when the ball was already rolling here. It came from a Ms. Kate Parkes, email customer services, stating: " I'm sorry to read that you haven't been receiving your magazine. I have arranged for replacement copies to be dispatched, please allow up to 10-14 days for these to arrive within Europe and up to 28 days for the rest of the world."
So it seems that in a couple of days I will mot only have the missing issues, but TWO of them... I just hope there is not a subscriber getting nothing because of that. In case, he can write me...
Here we have a saying: where there is a will, there is a way. But sometimes the will is missing...or working very slowly at least.
Hans
20/07/2020 22:58:14
Posted by JasonB on 20/07/2020 18:22:30:
Tim, all subscribers who did not get the mags were given free access to the digital versions plus the whole of the rest of the digital archive.
Jason, it would be VERY nice of you if you could explain in detail how we all, which miss MEW 293 and 294, can get access to these digital versions. Does somebody over there REALLY know that we didn't get them? At least I, as a 'paper' subscriber, have heard nothing from MTM. That they are unable to supply the missing paper issues is a shame. To the left from the 'Editor's Bench' there is a tel. nr. and website for 'current and back numbers'. Is that futile?
A bit miffed greetings,
Hans
Thread: cateracts.
15/07/2020 14:53:27
Ok, don't think I want to spread panic among the prospective users of silicone replacement lenses - but it must be said. Well, seems that I wrote about this somewhere in 2016, but repetition does not hurt.
Fact is, the docs always tell you about a surgery with absolutely no problems, but that is not always true. And when something goes wrong, then it is too late.
In my case, somehow the retina was badly damaged, and now in my left eye I have a totally distorted view. What it makes even worse is that there are none of the so-called positive effects of the cataract surgery, e.g. diminished blending and reflections. The only difference is that the untreated (read undamaged) eye sees white as just a little bit yellow.
I had then a second eye surgery, removing of the glass body (Leo says vitreous body), but with no positive result.
Just about a month ago I had again a scan of my eyes (retinas, to be exact), here are the two pics, so you can judge for yourself. Sorry, I didn't manage to bring both in the correct orientation, I can rotate the pics on the screen, but found no way to store them afterwards.
right (normal):
left (damaged):
Hans
Edited By Versaboss on 15/07/2020 14:54:40
Thread: SuperGlue as a means of holding in lathe
14/07/2020 22:07:29
MichaelG, falling for a troll (again?)...
Hans
Thread: MEW295
08/07/2020 13:42:45
Do I read that correctly, you are speaking about something in MEW issue 295???
The last issue I received was 293, May 2020. Something lost in transit, how long should I wait before taking action?
Waiting too long, and the leftovers are on the recycling skip.
Hans
Thread: What filament material do you use on your 3D printer?
06/07/2020 14:32:18
While I don' want to detain someone using ABS filament, I gave up after just a few trials and gave my spools away,
What I use now is ASA, with a bet temp of 80-90°, and a nozzle temp. of 235-240°. According to my IR thermometer, the real bed temp. is somewhat less. The print surface is BuildTak, anything holds perfectly on that.
material #2 is PET-G, bed temp 70°, nozzle temp 225°. No problems with the prints.
My printer is an Ortur, quite happy, although the print surface as delivered was scrap, and the leveling sensor does not work correctly. But the guides are imho better than what is used on Creality and Anet and similar ones.
Hans
Thread: Free or inexpensive 2D cad for clock wheels
01/07/2020 22:10:11
Well, I was interested in some features in this (up to now unknown to me) CAD app 'Back to the Drawing Board'.
Tried the whole evening to download the trial version, but no success. Although I had a MS account, and I could login to it, the download window did not recognise it. I went then through the quite complicated route to reset my password and rejoined with a new one. But what happened with that: yes, just the same. I can login to my account, but the download site says sorry, your password is wrong.
As the app is available for different hardware, it seems that the PC (this PC) should be known to the MS account. But what to do to register it - I dunno. Maybe I'm really too old for stuff like that.
Kind regards
Hans
P.S: would Mr, TickToc kplease stop citing every line in every entry, and then answering with one line... ISTR that we had this before, many weeks ago.
Edited By Versaboss on 01/07/2020 22:15:53
Edited By Versaboss on 01/07/2020 22:16:21
Thread: How to glue plastics
07/06/2020 17:13:28
Posted by Dave Halford on 07/06/2020 09:43:13:
You can glue most hard plastics except ABS (which requires a specialist glue)
Ok, here I cannot have my mouth shut. I suppose in that sentence a 'not' is missing.
ABS is one of the easiest plastics to glue. It can be dissolved in Acetone (every 3D-printer knows that), and bonds also to Epoxies and Acrylics.
For 'most hard plastics', the secret lies in the preparation. I see that the flame treatment has already been mentioned, and with this method I glued two plates from (I suppose) Polypropylene, and it would be very hard to separate them again.
The method consists of 'brushing' the parts with a Propane torch or similar, without melting the plastic, but it becomes then hydrophilic (in contrary to the water-repellent or hydrophobe surface the plastic usually has).
It is best to try this before if you have an offcut , if water builds a film instead of dropping off, you got it right.
I think I saw this method in one of the well-known Dan Gelbart videos.
Hans
EngineDIY
