Here is a list of all the postings Dennis R has made in our forums. Click on a thread name to jump to the thread.
Thread: Engineering / Modelling Books for Winter Evenings? |
13/02/2021 22:14:47 |
Hi Dr_GMJN, Try " Intoducing model traction engine construction by John Haining " Available for around £7 from various sources. Dennis |
Thread: Insert tool cutting angles |
11/01/2021 21:07:58 |
Just Googled VCGT carbide insert angles and it came up with 35* Dennis |
Thread: How to apply grease to old machine |
31/12/2020 17:24:41 |
Check out stauffer grease cup on the internet. |
Thread: Which adhesive to use |
29/11/2020 21:32:59 |
When I made mine probably 18 months ago, used Gorilla Glue Clear, no problems so far. Left the dressed belt side out gluing on the rougher side. Best lathe update I've ever done. Dennis |
Thread: Electronic Lead Screw Project |
29/11/2020 20:02:20 |
Further update. Somewhere along the line of building and installing the ELS I missed or skipped the Part 7 Video by Clough42 see ( https://www.youtube.com/watch?v=10Ketpqq-eM ) on metric and hybrid threading. In this video he cuts imperial threads on an imperial lathe using a thread dial indicator ( ie opening and closing the half nuts ) and metric threads leaving the half nuts closed and reversing with the forward/reverse switch on the lathe itself. So problem solved I think. Dennis |
26/11/2020 21:07:28 |
A quick update. Finally got a very good thread 3/8" x 16tpi ( thread picked because had a nut and die ), by leaving the half nuts engaged but using the VFD reverse function rather than reverse on the control box. Thanks again for the tip Alan So will leave for now, more experimentation if time allows. Dennis |
Thread: Calling all Startrite Mercury drill owners - opinion on noise |
25/11/2020 22:37:46 |
Just checked my floor standing model, pullies 9mm at top and belt fills groove, belt is a Picador Z995. Belt has been in service for at least 20 years and no problems. Dennis |
23/11/2020 21:59:27 |
Thankyou for the replies and suggestions, over the next few days will check everything that I can and report back hopefully reporting a success. Thanks again Dennis |
22/11/2020 23:30:58 |
The half nuts were left engaged and the lathe reversed after backing off the cut. Dennis |
22/11/2020 22:45:07 |
Problem with ELS Having set up my hardware on the lathe using a stepper/servo motor and driver CL57Y , the motor encoder resolution being 1000 and the motor to leadscrew drive being 1:2 ratio. Decided to test the set up whilst all the electrical side was still on the bench, with a light cut on scrap went through most of the thread TPIs and feed rates and all seemed well. However on attempting to cut a 20 tpi thread it turned out very rough and difficult to see exactly why, so cleaned up end of bar, blackened with permanent marker, changed to 8tpi, put on 0.003" cut and got a perfect first pass, but on second pass with same 0.003" cut was approx 1/16" away and on subsequent cuts filled the bar end. Even tried changing software back to version 1.1 made no difference. See photos
Thanks Dennis |
Thread: Live Steam Brevete Stork Leg Loco renovation |
23/10/2020 20:55:29 |
Hi Alan Threads 1.2mm (0.047" ) o/d are 13 BA size. Dennis Edited By Dennis R on 23/10/2020 20:56:16 |
Thread: Engineering Sights on Google Streetview |
03/10/2020 23:21:33 |
Steam engine in Darwen Lancashire with India Mill Chimney in the background https://www.google.com/maps/@53.69148,-2.4664448,3a,75y,90h,89.99t/data=!3m6!1e1!3m4!1sS7KmM1IyAV5I9NwqaMfCgg!2e0!7i13312!8i6656 Dennis |
Thread: Clarkson autolock help |
28/04/2020 23:55:11 |
Go to this site for instructions on Clarkson Autolock chucks. Dennis |
Thread: Startrite Mercury drill |
21/04/2020 22:54:54 |
My old Startrite floor standing machine, serial number 73698 has a 5/8" x 14 BSF thread, confirmed with thread gauge. |
Thread: Websites for the Bored |
25/03/2020 22:37:29 |
As a volunteer at the Bolton Steam Museum I can thoroughly recommend this site https://nmes.org/ , with its large collection of mill engines and ancillaries. Dennis |
Thread: Silvers soldering |
24/02/2020 19:24:05 |
Tipp-ex rapid double pack is on offer at £2.99 in W H Smiths today, seems very good value. Dennis |
21/01/2020 20:11:48 |
Dias I made top hat buttons with slightly domed heads from a small piece of hard plastic found in my scrap box, they were all made circular. Where Clough42 has triangular buttons mine are a larger diameter, a bit fiddly to do, just make one and try for size then adjust as necessary. Dennis |
23/12/2019 22:11:11 |
Mine was due anywhere between Jan 2 and Feb 12, but arrived early on Dec 18, very fast service. Dennis |
Thread: Castings, creating a datum before milling |
21/12/2019 18:05:58 |
Garry There was a series by Stan Bray in Model Engineer under the heading of Bray's Bench starting in Vol 176 No 4009 in 1996 about building "Tina" from the castings from GLR Kennions together with a follow on of building the boiler. Harold Hall also did part of the engine in one of his series in MEW, I think on using a milling attachment he had made. Dennis |
06/12/2019 23:04:29 |
Came across this example of an all in one package for a Nema 34 with driver and power supply, do you think this is a good deal and would be OK for an ML7? Dennis https://www.ebay.co.uk/itm/8-5Nm-NEMA34-Stepper-Motor-Driver-Power-Supply-Closed-Loop-8-5N-m-Hybrid-Drive/223770601237?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D61046%26meid%3D273350ecaba14a628828b44ff26609cb%26pid%3D100005%26rk%3D1%26rkt%3D12%26sd%3D283094369235%26itm%3D223770601237%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851 Edited By Dennis R on 06/12/2019 23:07:34 |
