Member postings for Stueeee
Here is a list of all the postings Stueeee has made in our forums. Click on a thread name to jump to the thread.
Thread: Thread chart
18/06/2015 23:04:50
Glad to see the threading chart pullout in the latest ME workshop. The one on my workshop wall (which came from a long ago MEW) has become yellowed and a bit coolant spattered so is getting rather hard for me to read!
old MEW wall chart
Keep up the good work!
Thread: What did you do today (2015)
18/06/2015 22:54:36
Today I machined a 1929 Ford model A cylinder head for a mate.
Ford A cylinder head on my Bridgeport
It was bought to me because it was warped, I could easily get an .008" feeler under the centre of the head when it was on my surface plate. But it needed .050" off to clean up the corrosion around the waterways on the head face -these motors must have seen years of no or at best minimal maintenance, so antifreeze not being changed (or even used) is bound to have left its mark.
An unlooked for minor drama whilst machining the head was one of the contactors burning out. I had noticed a slight burning Shellac aroma whilst working earlier and had checked that the spindle motor, coolant pump and table power feed motor weren't overheating. A while later a plume of smoke came out of the mill's electrics box, and this was the item responsible for the burnt Shellac smell.
burnt out contactor
A quick hunt through my "it'll come in useful one day box" turned up a contactor with a 415V coil which had came out of a old Schaublin lathe. Wrestled it into place on the Bridgeport and finished the cylinder head off rather later in the day than planned.
new contactor wired in
Still, all's well that ends well eh?
Edited By Stueeee on 18/06/2015 22:55:51
Thread: Bridgeport Contactor Problem
14/06/2015 19:49:25
Have you checked that the aux contact is making OK when the contactor is operated? Would have thought it has to be either a problem with the aux contact not making or the stop button (which usually just breaks the aux circuit when pressed) being permanently open circuit.
10/06/2015 21:31:06
Just got this finished today -it's a complete "spare" 4W toolpost for my S & B lathe -it's a complete unit that will just slide into the visible tee slot in the topslide.
4 way toolpost top view
4 way toolpost bottom view
I made the original (on the left in the photos) about 35 years ago just after I bought the lathe -the machine had come with an incomplete single way toolpost. The minimum order of this size of steel from the stockholder's turned out to be big enough to make three toolposts. Of course, once one was made, the other two pieces that I had cut with my donkey saw languished in the "short ends" box. Over the years, one of them has been lost in the couple of house/workshop moves since.
It wasn't any attack of engineering zeal that caused me to finally get round to making a second toolpost (which is now loaded with four different tools to create an alternative quick change tool setup). Two months ago I had an accident at home and had a short stay hospital stay where they kindly added some Titanium into my leg and put a plaster cast round it. I have discovered that being on crutches or in a wheelchair means that machining is still acheivable from a seated position, the only downside is being positioned at exactly the right level to get a facefull of hot swarf or coolant.
lathe with luxury seating
Not sure if this is the usage that the NHS had in mind when they issued my new workshop stool!
milling machine with seat
The plaster cast is off now, so looking forward to spending more "upright" time in the workshop once I get some more movement back in my foot.
Ausee.com.au
