Here is a list of all the postings JohnF has made in our forums. Click on a thread name to jump to the thread.
Thread: Do they exist? |
17/05/2022 11:49:00 |
Yes metric edge finders are available, Starrett do one but not a wiggler, personally I don't like wigglers, sometimes use the pin & plasticine as Dave [SOD] says but much prefer the ones shown here. The magnetic type suit either system, mine is a Hauser but there are other brands. Or use the age old method [ 2nd photo] of a spigot and slip gauge, this could be either imperial or metric. As with all tools if you want accuracy it will cost ! John |
Thread: What type of Collet are these please? |
30/04/2022 20:41:30 |
Also often used in milling diving fixtures, milled lots of hexagons, fork ends etc using these on horizontal mills a great many years go ! |
Thread: Hello from New Zealand |
17/04/2022 10:35:03 |
Welcome Leon, that's a really nice and spacious workshop you have, where in Aotearoa are you ? What are the vintage cars you have? John |
Thread: Which bonding agent |
21/03/2022 10:54:48 |
I would think an epoxy would be the best, maybe researching what the aircraft and car makers use ! Jaguar Landrover use it on aluminium bodied vehicles and much of what was riveted on aircraft is now bonded I believe. Just my thoughts, John |
Thread: hello from Italy |
14/03/2022 20:53:35 |
Welcome Fabio lots of information and help on here, where about in Italy are you ? Guess with a boat its either the coast or a lake ? John |
Thread: Femi 782 bandsaw |
11/03/2022 11:32:16 |
Hi, I have added some more photos and jpg of the simple hand drawn sketch to assist construction for anyone who is interested -- see here Femi Album John |
10/03/2022 14:01:39 |
Posted by John Haine on 12/06/2020 12:24:39:
Thanks Jason, just the job. Are you pleased with it? Do you have the horizontal table as well? Hi John, here are a couple of photo's of mine and I do have the table, somewhere I have a sketch I did for another member to help them make one. They are quite expensive for what they are and fairly easy to make one, if you want the sketch PM me with your email -- isa a pdf doc I think so cannot load it on here. John |
Thread: Cheap silver oxide batteries. |
08/03/2022 17:59:10 |
Plus one for SOD and Tony’s comments in particular about leakage! Whats the cost (difference in cost) of a known brand from a known and trusted vendor compared to the cost of your precious tool ? I have had a cheapo calliper destroyed by cheap batteries no way would I put them in my Mitutoyo etc. However most by far of my tools are old fashioned analog no batteries needed ! John |
Thread: How hard is gauge plate? |
07/03/2022 09:49:31 |
It maybe worth investigating here **LINK** or look for OMPS & Noma around the Brescia or Gardone VT area, lots of gunmaking and Engineering in that area, OMPS is very much aligned to that trade but if you ask either company if they can recommend where you can get what you want. John |
Thread: ARC website issues with Apple-Safari 15.3, Plusnet, VPN |
06/03/2022 23:15:55 |
Hi Ketan, Early 2013 MacBook pro and Safari Version 15.3 (17612.4.9.1.8) all seems Ok ran though an oder right up to payment charged delivery address etc -- all worked as it should as far as I can see --- cleared the order at the end. Regards John Edit use BT internet at the moment Edited By JohnF on 06/03/2022 23:16:37 |
Thread: Steel Blue recommendations |
05/03/2022 10:15:33 |
Hi here is a video I came across a while back, I have never tried the method but see no reason it should not work, I do use rust blueing but a much longer process, **LINK** All the cold blues are similar and based on the same chemicals, they work OK on smaller items but none offer particularly good rust prevention, better than nothing but traditional rust bluing and hot bluing offers a better protection, rust bluing being the better IMO. However iron + H2O always = rust ! John |
Thread: Hi from Naples italy |
02/03/2022 17:33:57 |
Chris, welcome to the forum, there are at least another couple of members from Italy, maybe more? As far the oil gun goes look here at Press Parts they do one that works quite well, one problem with it is it does not fit the rear spindle bearing nipple as well as it might but a bit of clean cotton cloth over the nipple helps. John |
Thread: 1.5" 6tpi thread for Harisson chuck |
22/02/2022 22:53:12 |
HI Chris, I agree with John H as far as getting the cart before the horse !! however it still may be possible with careful setting in a 4 -jaw, difficult to advise fully without seeing the job. As for the tool since its a one off job would grind one from HSS and use it in a substantial boring bar, assuming there is a shoulder inside the work I would arrange to start inside with an undercut and screw-cut outwards L -R just make sure you are cutting a RH thread ! Because of the size I would also arrange things so as the thread gets deeper you can feed in say 2 thou on the cross slide and 1 thou on the top slide thus reducing the cutting load on the tool. Might be wise to make a male gauge first to test the work. John |
Thread: Delapena External Hones |
21/02/2022 21:33:03 |
Ian please see your messages, The original method of fixing the stones to the carriers was a powder adhesive you applied to the mount then heated it on a hot plate [i use an old flat iron upturned] the worn stones can be removed with heat. I guess now its possible to use an epoxy, John |
Thread: shaper and planer gauge |
21/02/2022 20:44:43 |
I would say you have a good case if not "as described" good idea to save the photos if still available and a screen shot of the advert then open a case with eBay complaints asking for a refund --- or I think you can just ask to return the item for a refund ? look at eBay help. John |
Thread: Meddings Pillar Drill chuck change |
20/02/2022 12:34:14 |
Hi Martin, what model is your machine? Maybe a photo will help to ID the machine or see the problem John |
Thread: Graham meek reduction unit |
17/02/2022 10:05:56 |
Posted by Peter Love 1 on 17/02/2022 09:57:21:
Thank you Mark I have bought various from Tacey tools in the past. Peter. Peter, Steve Tracey is not Tracy tools see your messages for Steve’s details John |
Thread: Drill sets on offer 2022.02 |
11/02/2022 23:09:26 |
Hi, noticed some Hertel 1.5 - 5.9mm drill sets on offer this month at a particularly good price [in my opinion] Offer sheet no connection other than a customer, these folks generally sell good quality tooling. The Lyndon HSS tap sets are also a good buy. Regards John
Thread: Running a Myford S7 in Reverse |
10/02/2022 15:03:38 |
Mitch, have a look at this thread for metric threads on a Myford with a gearbox **LINK** As far as cutting in reverse unless it's a very large course thread its unlikely to cause you a problem, I do it regularly when cutting internal threads in a blind bore. John |
Thread: Internal threading |
10/02/2022 10:37:19 |
Geoff, have a look at this photo of hand ground HSS tools, first & third from the LHS **LINK**. Made to work with the lathe running in reverse and the carriage traveling Left to Right — away from the chuck thus cuts a RH thread from a shoulder or blind hole with an undercut. John |
