Member postings for Philip Rowe
Here is a list of all the postings Philip Rowe has made in our forums. Click on a thread name to jump to the thread.
Thread: What does your casting setup look like, and results?
03/07/2022 11:31:02
I know less than nothing about casting metal, apart from what I read here but those results are mind blowing. You must be very proud of your achievements. Phil
Thread: Nut Making
29/05/2022 16:08:53
Going back to the nut making video, can anyone shed any light on the tumbler process? It looked as if the operative added a bowl full of wood shavings to the tumbler, what good would that do apart from absorbing oil but later they are flooding with some kind of cutting fluid during the tapping process?
Maybe I'm just being dense!
Phil
Thread: MEW No.316 just arrived - but what is that smell?
17/05/2022 16:03:17
Just settled down to read my copy which arrived earlier but I can't detect any strange odour. Phil
Thread: Before calculators
15/04/2022 11:53:08
I recall when Sinclair brought out his first calculator in the early seventies it was around £60 - £70 if my memory is correct. Browsing the stationery alise in a local supermarket the other day l spotted a perfectly respectable scientific calculator for less than £4! Phil
Thread: Possible Myford 7 safety issue
02/02/2022 12:40:09
One thing that I believe a lot of contributers may be overlooking, is that for many years a Myford lathe even when new was not supplied with a motor, it was always an extra. Consequently a lot of machines that are around today only ever had an owner fitted motor and who knows what sort of standards where applied in those instances. Phil
Thread: Silver Steel
06/01/2022 15:49:29
Forging a piece of silver steel was the very first exercise I did as an apprentice nearly sixty years ago. Under the tutoring of the apprentice instructor four of us had to produce a fairly basic screwdriver from 1/4" dia silver steel, the end being flared out to maybe 3/8" wide. The other end was forged into a tapered square section which was later burnt into a file handle, lots of smoke and smells! The blade was then hardened and tempered, polished and I'm sorry to say never ever used as a screwdriver but it did teach me quite a lot about silver steel. Phil
Thread: Fitting new motor and VFD to a Super 7
28/12/2021 16:18:33
Posted by John Haine on 28/12/2021 13:00:24:
  1. Was the new motor a direct fit on the motor mounting plate or was any fettling needed?
  2. Is there any provision for axial adjustment of the motor to help in lining up the pulleys with the headstock?
  3. Any tips for access and methods to tighten the set screw?
  4. I will have to move the lathe on its stand to get access to the motor as it sits against a wall - any suggestions as to how this can be done?
  5. Any other tips or advice?
Thanks in advance for any information!
1. Direct replacement, just make sure you buy the correct motor shaft size i.e. 5/8" or 20mm dia.
2. Axial adjustment isn't needed, just slide the pulley along the motor shaft to line up with the counter shaft pulley.
3. Can't comment, mine came undone easily and tightened easily with a long ball ended allen key.
4. I used a crow bar to tilt the lathe to enable me to insert some old gas barrel under the stand and rolled the lathe forward on that. Beware of over tilting the lathe as it is very top heavy.
5. Although I used a Transwave system, the principles are the same. It really is a very simple operation and you will wonder why you hadn't done the change years ago as it makes a tremendous difference to using the lathe.
Phil
Thread: What thread?
21/12/2021 14:10:41
Posted by Andrew Johnston on 21/12/2021 12:55:32:
The ME thread series are, of course, Whitworth form. They were introduced in the late 1940s
Andrew, are you sure about this? I have LBSC designed models, an 0 gauge "Sir Morris de Cowley" and a 2 1/2" gauge "Annie Bodie" built by my grandfather in the 20s and 30s and they both use 32 and 40 tpi threads. Phil
Thread: Myford Serial number help
20/12/2021 12:35:24
Posted by Peter Thistleton on 19/12/2021 23:19:52:
Just because I can I rechecked that serial number in better light and it was
L
894
Which still doesn't come up on anything I have looked at but I suppose it doesn't matter in the bigger scheme of things.
Peter, this is indeed the serial number stamped into a raised machined pad. I can't help with it's manufacturing year but I had an ML2 passed to me by my father who bought it new in 1934/5 and its serial number was L277. I sometimes regret selling it some 30 years ago when I got my Super7 but you can only keep so much in a small workshop.
Phil
Thread: Myford ML1 ? or 2 ?
12/12/2021 15:52:32
Posted in error, deleted.
Edited By Philip Rowe on 12/12/2021 15:54:12
06/12/2021 12:16:56
I had a ML2 passed onto me by my father who purchased it new in 1933/4. It was originally fitted with flat belt pulleys but I later converted it to v pulleys as it suited my drive system and I was able to squeeze four diameters in the space of the original three to give a greater speed variation. This is something that I know quite a few owners have done over the years. It's serial number was L277 which was stamped into a small machined pad on the left hand side of the bed below the back gear. To the best of my knowledge Myford never used separately attached number plates and as Lee says the cast numbers will fry your brain.
One thing that easily identifies a ML1 is the headstock and bed are one casting, whereas with the ML2 and onwards the headstock was a separate casting bolted to the bed. Also the ML2 had a centre height of 3 1/8" not 3 1/2" which further aids identification.
As to colour my father's was originally a very dark greeny blue which by the time I had it had become almost like black. Hope some of this helps.
Phil
Thread: Wanner grease-gun thread ?
02/11/2021 17:56:49
I grease my Fobco with my original Myford supplied oil gun, filled with grease. As its pretty useless as an oil gun it has at least redeemed itself in lubricating my drill. Phil
Thread: An Uninvited Guest!
26/10/2021 13:33:08
It looks like an ivy to me and in all fairness it does grow very rapidly but not overnight. Seems you do need to spend some time out there if only to clear your visitor. Phil
Thread: Myford super 7 with gearbox - leadscrew stopped turning
24/08/2021 14:41:07
Also check that the high/low gear selector on the top of the gear box is either in high or low, the mid position will give you another neutral. Normally I keep mine in this mid position as it allows me to turn the leadscrew with it's handwheel without all the added friction of turning the gears in the gearbox. Phil
Thread: Amazing Engineering Video
21/08/2021 13:37:18
That was truly amazing, not only for the skills that were available during WWl but for the devotion of this chap in producing the video. I'm also in awe of the manufacture of the component parts some of which I wonder how they were produced without the benefits of today's cnc manufacturing. Phil
Thread: The beginnings of Mobile Telephony
21/07/2021 11:25:09
The first mobile phone l had was a company one for me to use at the Farnborough Air Show in the mid 1980s, can't remember the exact year. It comprised of a battery pack the size of a briefcase, the handset not too dissimilar to conventional phones of the day with the keypad on the back of the handset. Weighed a ton and l was threatened on pain of of death not to use it because of the high charges, it was effectively just to look good in front of prospective customers. How times have changed! Phil
Thread: re-magnetising magnetic base
11/07/2021 12:50:05
I also have gone through the problem of an extremely stiff push button on an Eclipse base. I tried various methods of easing, paraffin, clock cleaner and WD40. Nothing worked so eventually I put it in a club auction and bought a new switch type, vastly superior can now turn it on and off with two fingers.
On the subject of remagnetising, many years ago as an apprentice I was given the rask of constructing a magnetiser for magnetron magnets. This was at a division of GEC that manufactured valves and cathode Ray tubes, a laboratory lash up had been made to prove the process and my job was to make the whole thing into a workable device in a cabinet that could be used in production. The details are now quite hazy but basically a simple power supply charged up a huge bank of capacitors and when they were fully charged the charge was released via a device called an ignetron into a length of very heavy copper braid which had been tightly wound around the metal shape that was to form the magnet. The one thing that has always stuck in my mind was that the magnet being charged would leap 2 - 3 feet in the air as the charge was released. I can't recall exactly what was done in the production process to stop this happening, the only thing I do remember was the whole process was carried out on a wooden bench in a fairly substantial wooden cupboard. Phil
Thread: Fusible plug in a 5" gauge copper boiler?
28/06/2021 13:32:13
I suppose its like any insurance policy, a waste of time/money until you need to claim! Phil
Thread: MYFord Super 7 quick change gearbox questions - bushings
28/06/2021 13:29:10
One thing that a lot of folks seem to be unaware of is that oilite bearings are deliberately made oversize and the action of pressing them into the housing will reduce the bore down to the correct size. Phil
Thread: Reilang oil cans, fit for purpose?
09/06/2021 11:22:09
Anybody remember the the round pressed steel container oil dispenser with a screw in nozzle? I seem to recall they were supplied with bicycle tool kits, the nozzle had a screw on brass cap which prevented oil from leaking - always assuming you didn't lose it. I always had one of those in my saddle bag and I don't recall them ever leaking. Phil
Edited By Philip Rowe on 09/06/2021 11:23:35
Dreweatts
Rapid RC
