Here is a list of all the postings Paul White 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: Multi page threads. |
24/05/2018 11:02:50 |
Grumpy hat on: Neil or other knowledgeable person. I have noted that with some multi page threads selecting the thread brings up the latest page with the posting, this would seem to be the obvious desire of the of the person selecting the post. This is by far the exception, most threads take the enquirer through a series of actions to get at the latest post in a particular thread. Can the enquirer change all threads to always go to the latest post, as would be, in my opinion the ideal? Here's hoping. Paul. |
Thread: Repurposing a 25cc strimmer engine |
15/05/2018 12:34:28 |
I would like to thank all the respondents to this thread for their time and sharing of experience. The net of information seems to be trial and error as the method of setting. This I shall have to use as the procedure I adopt.
Thanks to all. Paul. |
13/05/2018 15:40:33 |
Vintagengineer, Thanks for your very fast response to my cry for help. The problem I have is not understanding how the cdi unit is fired, at what position the flywheel magnets need to be relative to the metal core of the cdi. Does the statement of "-setting the cdi just after the magnet" mean the back end of the passing magnets aligning with the back end of the cdi core.?
13/05/2018 14:44:37 |
In the amazing pool of information within this forum can anybody help me with setting the timing on a 25cc petrol ex strimmer engine . The motor suffered failure of the ignition unit, a DIRECT replacement being unavailable a replacement unit has been obtained but has a different mounting thus the usual -just screw on the new one , does not work. I have done a web search but cannot find how the cdi unit is positioned relative to the flywheel magnets on these motors. All help gratefully received. Thanks Paul.
Thread: Vintage lathe meets 21st Century |
11/04/2018 09:33:06 |
John, Not wishing to be pedantic but I think you have one" C" to many . NC does the job, see Joe Noci mod to his EMCO. regards paul.
10/04/2018 11:36:44 |
Hello Andrew. I am also a mover into the next century of old equipment capability. I'm very impressed by your drive system, can you give more detail of motor and inverter. Many thanks Looking forward to your next posting. Paul. |
Thread: Our Wildlife and Conservation Activieties in Nambia |
31/03/2018 11:59:36 |
My amazement at the work, both technically and volume wise done by the team Noci knows no bounds. Do you never rest? Thanks for sharing Joe, very, very interesting and impressive. Paul |
Thread: Motor speed control on AC motor? |
25/01/2018 12:00:25 |
XD351. Thanks for pointing us at a source of very interesting information. It is good to see the response of "here is how to do it" after all the can't be done statements. Comment on the info from our electronic whizzes would be very welcome.
paul |
Thread: Clamping |
12/12/2017 10:24:33 |
Given that the bearing will require some form of protection and the apparent wall thickness around the bearing, would not a bearing protector that has screw fixing into the end wall and flanged enough for the attachment by screws to the square plate cover two requirements here. Edited By Paul White 3 on 12/12/2017 10:25:58 |
Thread: Label making for tools |
11/12/2017 11:33:34 |
Oh dear, now I have posted a response to your posting in the 12995 post. Many thanks for your very quick post, yes that was the one.
Regards paul
Thread: Would anyone know where I can source On Off Decals? |
11/12/2017 11:21:56 |
That's the one, extremely quick response many many thanks.
regards paul. |
11/12/2017 10:00:22 |
Some months ago a thread was posted regarding labeling on a drilling machine. Many of the posts contained good advice on method and drawing packages for the process. I cannot find the thread and would be most grateful for any help. What I was looking for is a SIMPLE 2D drawing package and or the thread reference . Many thanks paul |
Thread: PCB CNC |
10/12/2017 16:54:56 |
John, thanks for the above info. At the present I just want a package to print labels as I do not have engraving facilities Joe kindly offered me a label making method,
Thanks for the response paul. |
10/12/2017 12:51:12 |
Joe, another amazing project from your stable, the construction and design are remarkable . The labeling on your facia leads me to ask what are you using to produce it?
paul |
Thread: Has anybody come across one of these |
02/12/2017 09:04:59 |
Bazyle, not a recent acquisition, I have had it for some 20 years.
Alan, the vice ,indexing chuck and swarf tray are all items I made to use the tool. The mandrel has 2 cutters with a spacer to suite whatever across flat dimension I want to produce. In the photo. there is nothing shown in the chuck. It can of course be used with end mills. Thanks for the responses. Paul Edited By Paul White 3 on 02/12/2017 09:07:31 |
01/12/2017 15:13:16 |
David, thank you, a very interesting LINK. You could well be correct in the derivation of the name.
paul. |
01/12/2017 14:56:26 |
The latter { I think). paul
01/12/2017 14:35:11 |
Thanks Alan, I have one of those! Paul. |
01/12/2017 14:09:08 |
Alan, thanks for the reply. The item is a horizontal mill for second operations, made up of a very solid base with a powered vertical slide and a 2 way table. Do you know if the Erma you mentioned were at Wembley? Paul. |
01/12/2017 13:43:58 |
This verb age should have been with the photo above. The name of this item describes the tool. its robustness indicates an industrial purpose. The photo shows my use of it to reduce the size of hexagon heads. Any info would be most welcome. Thanks. Paul. |
