Member postings for IanT
Here is a list of all the postings IanT has made in our forums. Click on a thread name to jump to the thread.
Thread: New To CAD? No, but....
17/05/2022 11:12:45
You need to lock the plane using F3 otherwise SE will not know what you are trying to reference.
Examples of locating holes are shown in this recent YouTube by Dr Seif. It's probably more advanced than you need just now but ignore the first part and just jump to timeslot 13.22 for the hole placement part....
Solid Edge Tutorial - Bearing Base - Exercise 8 - YouTube
I'll repeat my view that you need to be systematic when learning a modern 3D CAD system - jumping in without establishing the basic skills is going to be very frustrating.
IanT
16/05/2022 13:02:00
Posted by SillyOldDuffer on 16/05/2022 10:03:05:
Perhaps Nigel's biggest problem with TurboCAD is no-one else on the forum seems to be using it! ......
.......To be fair, the help provided by other CAD software isn't perfect either! Solid Edge's website is the slowest I use, and the formal documentation makes the mistake of being written for people who already know the ropes: for example, describing a tool's function in detail without showing what the button icon looks like or saying which toolbar it's in.)
Well that's probably because (25 years ago) when I first started using TurboCAD (DLv4) - it was a very competent 2D drawing product (when used correctly). However, the 3D capabilities were beyond my patience to learn quite frankly - a view reinforced by Paul (the CAD) who stated that you really needed the 'Pro' version to use 3D.
Now (25 years later) there are clearly better options than TC available - and my choice has been Solid Edge.
With regards your " what the button icon looks like or saying which toolbar it's in" - then maybe the authors are assuming that users have already worked through the basic training that encourages new users to use that little box at the bottom of the screen, marked 'Find a Command' - which not only shows you the associated icon but also it's place in the toolbar when you hover over it.....
However - I think Blowlamp has just summarised my sentiments about this thread very well.
IanT
06/05/2022 11:44:10
Hi Nigel,
I'm afraid that my heart sank a little when I saw your post.
My experience has been that the only way to learn (any) 3D CAD programme is to be methodical in your learning approach. I would not recommend anyone trying to learn 3D CAD just using videos for instance. Indeed I went to some trouble to outline a learning strategy for Solid Edge in this thread:
Solid Edge - Community Edition | Model Engineer (model-engineer.co.uk)
To be honest, I don't think Fusion or any other 3D CAD is going to really suit you, unless you are prepared to invest some time in learning the basics and then practicing them. However, if you really feel that video tutorials best suit your learning needs, then I would recommend Dr Mohammed Seif's YouTubes. This one covers the basics of SE Sketching and is the starting point for his series of SE videos.
Introduction to Solid Edge - Part A - YouTube
IanT
Thread: 3D-CAD Package Shootout - Cotton Reel Example
19/04/2022 21:59:29
That's looking very good Duncan.
IanT
Edited By IanT on 19/04/2022 22:00:08
19/04/2022 17:57:47
Hi Duncan,
Good to see you making progress.
The steering wheel is one way to do this but when you are setting assembly relationships in Solid Edge, you can also use 'drag component' - with a choice of either a 'move' (relative to an edge or axis), rotate (about an edge or axis) or 'freemove' (which is an unconstrained drag). You can also define the exact amount of 'drag' should you need to.
So I think this capability would also have solved your problem - although I cannot claim to have fully mastered it myself quite yet.
IanT
18/04/2022 23:44:53
Duncan,
Not sure exactly the problem but your relates should over-ride the part orientation.
In Assembly - try experimenting with the assembly relationships - Mate, Planer Align & Axial Align. You can assemble most things with just these three commands. If it's not working the way you think it should do, then try the 'Flip' option to swop the relationship.
Assembly needs a little practice but is one of those things that will suddenly click (at least it did for me). Still working on my part 'dragging' though....
IanT
18/04/2022 09:23:41
That file type is for Siemens NX (their other CAD system) so I don't think it will help.
I assume the problem is that a six month Alibre trial has finished, so you can't re-open the old files and export them Duncan?
IanT
16/04/2022 12:26:45
Posted by SillyOldDuffer on 16/04/2022 11:26:19:
Solid Edge is a Hybrid: optimistically it gives the designer the best of both worlds, though a pessimist might whinge it increases the software's complexity!
Dave, coming from (non parametric) TurboCAD all I can really say is that with SE it's wonderful having any small change automatically update across all related assemblies and drawings. I had assumed that "parametric" was just a term to describe any CAD system that offered this feature.
I have found using Solid Edge easier than the other systems I tried originally but I wasn't aware of the technical differences between them at the time. I didn't think the 'synchronous' aspect of Solid Edge was unique to it either but it seems it might be.
Fortunately, whatever complexity exists under the bonnet of SE - it's not apparent to the user and I've found both versions of SE (2020 & 2022) that I've used so far very stable.
IanT
16/04/2022 10:11:35
Pleased I could help Duncan - I'm still learning all this clever new stuff myself. I do find it becomes a little easier with use though, as you slowly get used to things. Had a small "Ah-Ha" moment last week, when I twigged how to do something that had previously puzzled me...
Jason - I think that would be true in Solid Edge if using 'Ordered' mode - but in 'Synchronous' mode you have more ability to manipulate design features without stepping back in history. Also as a 2D sketch is consumed (e.g. extruded) it ceases to be part of the active model because you can now work on the new faces/planes directly.
You do have a list of 'features' (the actions used to build your part) and you can select them to look at/modify the design 'intent' for that feature - e.g. what SE assumes you want it's relationships to be - but the initial sketch used to design the feature becomes "used" . You can still re-open a 'used' sketch if you need to, maybe to find a previous [consumed] reference point for instance - but I rarely do so.
I posted a video link recently that explains the main differences between Synchronous & Ordered modes much better than I can (a picture being worth a thousand words etc) and for anyone who is curious, here it is again...
(1) Synchronous vs Ordered Modes in Solid Edge - YouTube
IanT
15/04/2022 23:33:27
Hi Duncan,
If I understand your problem correctly, then set your working plane at the end (on the face) you want to infill, draw/sketch your new infill section and extrude it to the depth required. I'm assuming you are using synchronous mode but it may work in ordered too (not sure, as I don't generally use it myself)
IanT
13/04/2022 10:04:45
Posted by PatJ on 13/04/2022 00:42:10:
I think an interesting comparison would be to see which program(s) easily allow the modification of the various types of generated shapes, such as the spindle.
I have not kept track of such things, but I have noticed it from time to time, that I can't edit some shapes as easily as others.
I am not sure if this is due to limitations of Solidworks, or whether it is inherit in the way all 3D modeling programs work.
I know very little about other CAD systems Pat - but my understanding is that most use what is called "Ordered" mode - that is one based upon a build history. Solid Edge offers both "Ordered" and "Synchronous" modes and you can switch between them if required. Normally you set a default design mode and I decided from the outset to (learn to) use synchronous mode, as it seems to be preferable in general use.
More experienced CAD users (coming from other 3D systems) may find ordered mode more familiar. In terms of my general design work though, synchronous seems to be the better choice. This may be a feature unique to Solid Edge but I don't really know.
This short video explains the differences between the two modes better than I can.
(2) Synchronous vs Ordered Modes in Solid Edge - YouTube
IanT
12/04/2022 13:54:40
Posted by SillyOldDuffer on 12/04/2022 13:07:31:
For example, starting with a sketch that models the spokes first creates a structure less resilient to change than one that cuts the spokes much later. Will the model break if the customer suddenly announces the reel's diameter should be bigger or smaller?
Let's see what happens in Solid Edge Dave....taking my existing Cotton Reel model...
Used smart dimension to select the outside reel diameter and change it to 40mm (from 30mm). I can do this because it is not a dependent dimension.
So then do the same for the internal diameter... (radius from 12.25 to 18mm)
Spokes still look OK. Might not have been as predictable if I'd tried to increase the internal diameter to exceed the external one first though. To be clear, I've only changed the two diameters here - nothing else was altered.
IanT
12/04/2022 00:06:04
It's way past my bedtime Dave! frown
However - here we are. Circles by centre - just click and enter the dims (or size it later)
Did this a bit differently, drew a reference line and then rectangle by centre, then trimmed. Think it was quicker using lines...
Then extruded the spoke to length...
Used Pattern by Circle to make six spokes...
Then extruded cylinders to length (forgot to turn off extrude symmetry for screen grab - but corrected it)
Which gave me the basic reel shape
Set my working plane to the end face (note F3 padlock icon) and sketched new rim.
Extruded this sketch and repeated at both ends. Could have done half model and mirrored - but didn't.
Selected rim edge to round it....
And clicked to round it - same at other end...and that finished it...
Edited By IanT on 12/04/2022 00:11:55
11/04/2022 21:43:54
PS - When I first started 3D Printing, a friend suggested Open SCAD for my design tool.
It's very easy to get into but does benefit from a more 'programmatic' way of thinking. I'm a bit more 'visual' in nature and also need engineering drawing capability, so moved on to Solid Edge. However, I've written a few simple SCAD models that can be easily modified to suit different applications - and it's very easy to share them too - just a text file.
Adrian's SCAD model was a simple cut n' paste and worked fine in Open SCAD itself - I've no idea about using the FreeCAD version I'm afraid.
IanT
Adrians Cotton Reel
Edited By IanT on 11/04/2022 21:44:50
11/04/2022 21:27:45
Didn't bother taking snapshots as I went along & I also think this can be done in a number of ways. Nor do I really see the point of this exercise quite frankly, because to a large extent - a) the result must depend on the skill of the user (and I'm certainly not the most skilled SE user, so certainly not the best to champion it) and b) I'm pretty sure most CAD systems could do this quite easily.
However, in Solid Edge, I did the following;
Sketched the basic reel outline (circles by centre) & then dimensioned them, added a spoke (two lines). Extruded the spoke and used circular pattern to create six of them. Extruded circular elements to length. As an after thought added the two outside rims and rounded them. Could have used mirroring but didn't.
IanT
Thread: Best Budget 3D Cad software
09/04/2022 15:36:48
It was a while ago now Huub but I think one of the issues is that when you are trying to learn something new (and it doesn't seem to work) it really helps if you have some confidence that it SHOULD work somehow and that the most likely the cause of any problem is your lack of understanding.
Even though I didn't stick with Fusion, I was always pretty sure that any issues were probably caused by my poor product skills, rather than any undiscovered 'features' (e.g. bugs). I had the same confidence later when starting out with Solid Edge (and I still do). Having really good documentation also helps.
However, I was never completely sure with FreeCAD, which didn't help, because it's much easier to give up when you hit a problem.
IanT
Edited By IanT on 09/04/2022 15:39:02
09/04/2022 12:59:40
As Business Development Manager for my divisions software products in UK a long time ago, one of my main targets centred around product adoption - in other words market share. I spent a great deal of my time presenting and promoting our products to both trade and end users. I was always very happy to hear from anyone who could help me promote my products to a wider audience. I therefore very much doubt that any Marketing Department worth their salt would object to someone promoting their products in a positive light.
However, it's really not a point that will interest most people here.
David, why not just buy an Alibre CAD license and be done with it. MEW has actively promoted Alibre in the past and I assume that they have an existing relationship with them. You may even get a 'freebie' license from Alibre marketing to base your work on. I have no idea how Alibre CAD compares in detail with other modern CAD packages but it looked quite capable from the MEW articles and Jason hasn't moved his allegiance yet.
Of course, very many more hobbyist CAD users will use 'free' licenses from the likes of Autodesk and Siemens than will ever purchase Alibre licenses. Whilst many ME/MEW articles are fairly generic in nature (e.g. you don't need a specific 'brand' of lathe/mill to do most operations) that's not quite so true in the CAD space I'm afraid, although it may be more so in terms of 3D printing.
IanT
PS In support of Huub's comments, whilst it's been a good while since I last tried FreeCAD, it was very much a Curates Egg back then. From memory some things worked very well, others didn't (or maybe I just couldn't make them). I'm sure FC will have improved but frankly (as I found a better alternative) I'm not tempted to go and take another look unless I really need to.
08/04/2022 14:52:24
So when people produce material (i.e. articles) - both online and in print about Fusion 360 - Autodesk would see that as a commercial activity and sue the author? Youtube'ers get paid by the number of views and there's no lack of them around. Haven't checked recent ME/MEW articles about CAD but some of those may have had Fusion content too.
I'm sorry Dave - I don't think so. I worked for one of the largest software publishers in the world and their UK 'Infringement' team didn't even get out of bed for less than £1M and that was several decades ago.
I strongly that suspect that both Autodesk and Siemens would see any article about their CAD products just as free publicity (assuming they even notice it) - and also assuming David didn't write anything defamatory about them. After all, that's why they make 'Hobbyists' version available isn't it? - to spread the word.
IanT
08/04/2022 10:03:08
I don't think your assertion is true Gary - I think 'Top Down' vs 'Bottom Up' is probably more just about how you decide to approach your design work, although I'm certainly a bottom up kind of guy!
CAD basics: Top down modeling (3dcadworld.com)
However should I ever need/want to do 'Top Down' - then Solid Edge can certainly do so.
How to Create a Top Down Assembly | Solid Edge (siemens.com)
I suspect this will be true of other commercial CAD systems too, given it's uses within a Team environment.
IanT
07/04/2022 17:19:43
David - whilst Solid Edge supports a number of different drawing types for 3D (parts, assemblies etc) - it's 'Draft' documents are essentially just 2D drawings and you can import your existing TC work into SE Draft format using .DXF files. SE Draft documents also support 'layers' which you should find very useful when coming from TC.
I've imported some of my TC drawings in this way and it's generally worked very well, although SE quickly highlighted how many 'un-joined' snaps I had in my older TC work. With some of my more complex TC drawings (where I had everything in a single model) it did help to save a simpler version that contained just the object I wanted to model in 3D. Once imported into Draft, you can modify/save your .DXFs in native mode using SE's 2D 'Sketching' tools (which are provided only in the Draft mode). However, these tools are pretty much the same as those you use when 3D sketching, so do not then need re-learning. You might find this a simpler route to get to know a new CAD system before diving straight into the full 3D works - a half-way house so to speak.
There are also features within SE that will take 2D 1st/3rd angle drawings and convert them straight to 3D drawings but that's still a bit beyond my current paygrade I'm afraid. Generally, I've found it easier to just import the most detailed 2D 'face' directly into a 'Part' document and then simply modify/extrude it manually using the 3D tools. Very easy to do with simpler things like loco frames etc and it can save a deal of work.
I don't know what Fusion is capable of in this area (in terms of DXF import/2D drawing etc) - others will have to advise you. All these modern systems are very capable but they do differ in the detail I imagine.
I certainly think this approach might be better than trying to use retrograde/old "shareware". Have a look at my link at the beginning of this thread to see the pros/cons of SE. You may prefer to use Mac or Linux for instance, in which case SE will not be for you. But Solid edge has much to recommend it and may be a very good fit in your case!
IanT
Rapid RC
Dreweatts
