Here is a list of all the postings steamdave has made in our forums. Click on a thread name to jump to the thread.
Thread: Soft jaws |
05/08/2022 20:02:37 |
Just to show that I do follow up on the answers to my questions. Well, some of them! These are my soft jaws. 2-1/4" Ali hex. The holes are .700" and the jaws are locked in place by M3 cap screws with the heads reduced in diameter a few thou. The front faces have deliberately not been faced. Dave
Thread: The best advice I was ever given/gleaned - Keep it on the Stock! |
01/08/2022 12:00:31 |
"Good judgement is the result of experience and experience is the result of bad judgement." Mark Twain Dave
Thread: Soft jaws |
29/07/2022 16:54:39 |
Posted by DC31k on 29/07/2022 14:34:45:
There is another version here: https://www.cgtk.co.uk/metalwork/m250/hexsoftjaws and that references MEW 224. That's it DC. Many thanks. Also, your idea Mike was one I had seen before but had forgotten about. Now to put some redundant ali hex to good use. Dave |
29/07/2022 10:07:31 |
That's £30 too much for me Clive! Dave |
29/07/2022 09:57:47 |
Somewhere, sometime ago there was a description of how to make soft jaws for a 3 jaw chuck. The method used hex aluminium with holes bored through the centre to fit over each jaw projection and secured somehow to the jaws. Does anyone remember the design and where I would be able to find it? A Google search doesn't bring up anything for me. I have seen Harold Hall's design, but I don't want to drill the jaws of my Pratt Burnerd chuck. Dave
Thread: Sanding belt cleaner |
26/07/2022 22:52:50 |
Vic. If I get enough plastic film, I'll give your idea a try. In the meantime, I have a new official one winging its way here. Mark. Nothing out of the ordinary for a detached garage workshop, so I'll just make sure to keep it out of sunlight so that it doesn't roast. Dave
26/07/2022 21:05:01 |
I have a sanding belt cleaner - one of those rubber sticks that you press against the belt as it's running. Had it maybe about 3 or 4 years. Went to use it today and it just melted and clogged up the belt. Belt ruined. Looking at the cleaner, it has gone very spongy. Has anyone any ideas how/why this could happen? I've ordered a new one and don't want to let the same thing happen to it. Dave |
Thread: Ajet |
25/07/2022 11:57:36 |
And then there was MiniBrix - rubber blocks that clipped together somewhat like Lego. Dave |
Thread: What Did you do Today 2022 |
22/07/2022 14:22:30 |
Another good book is 'Making the Most Of The Unimat' by Rex Tingey. Should be available for download off the Internet, but if you can't find it, I can let you have a copy. Dave |
Thread: Quick change tool post ? |
04/07/2022 10:58:26 |
I used to have a GHT 4 way indexing toolpost for my Myford. Actually I made 2, one for machining ferrous metals, the other for non-ferrous. Surprisingly I very rarely changed between the two blocks, it was quicker to swap out the cutting tools (which were kept pre-shimmed). A few years ago when 'everybody' was advocating the QCTP made by a company supplying Myford, I changed over. Biggest mistake I ever made. It maybe 'quick change', but not as quick as spinning the turret round one or 2 places. It is definitely not as rigid as the GHT toolpost. One thing that hasn't come up this time is that people complaining they snag their hands on the non-cutting tools. I don't remember doing that and I can be quite careless. For those folk, there is always the Lammas 3 way toolpost. Dave |
Thread: THE MIDLAND - THE ONLY SHOW IN TOWN ! |
27/06/2022 20:01:54 |
I'll be coming over from Ireland and combining a visit to the show (on Friday) with a trip to see family members in darkest West Country. Dave |
Thread: Looking for a Sharpening Service for End Mills & Slot Drills please |
15/05/2022 15:07:12 |
Posted by IanH on 15/05/2022 12:32:30:
My last lot cost between £3 and £10 each depending on the size of the cutter. Vat on top I guess. Ian Unless they are very special cutters, is it really worth paying £3 - £10 for resharpening when new cutters won't cost much more, if anything, with careful shopping around? Dave |
Thread: Harrison M300 advice |
26/04/2022 20:50:39 |
Dougie This is the best I can do. I sold the lathe a couple of years ago. From memory, the angle of the V is 70 degrees, but you had better check it! Dave |
26/04/2022 11:41:20 |
Here's an auxiliary boring table that I made for my M300. Clamps to the cross slide with wedge blocks as per Harrison's design. Plate was ex 12mm and screw holes are M10. Dave |
Thread: ME handbook Capstan and Turret Lathes |
23/04/2022 23:14:17 |
I also have a copy but postage from Ireland will be quite expensive. If you can wait until July time, I will be in Blighty then if you haven't been satisfied beforehand. Dave |
Thread: High Speed Bench Drill? |
23/04/2022 17:13:18 |
ega Send me a private message with your email address and I'll send you all the info. There is too much to put here. Dave |
23/04/2022 12:49:45 |
Posted by Mike Poole on 22/04/2022 21:31:28:
A sensitive feed is an important part of a high speed drilling spindle, sub millimetre drills need a high speed and sensitive feel to avoid breakage, the sensitive feel is probably more important than the optimum speed which can reach extremely high levels for non ferrous materials. Mike Chuck Fellows (RIP) described a small sensitive drill table and I based mine on his design. It uses a linear bearing for the vertical slide. The screw holes are spaced to accept a Myford vice and extra counterweights are available to maintain a neutral balance. It mounts on the milling machine table or in the main vice easily. It may not suit Barry's requirements for the high speed but Mike mentioned a very valid point about sensitivity. Dave Edited By steamdave on 23/04/2022 12:50:15 Edited By steamdave on 23/04/2022 12:51:13 |
Thread: Help with choosing band saw |
18/04/2022 11:34:56 |
I would second JB's opinion of the Femi bandsaws. Stakesy's was the cheapest place when I was looking and service was also good. Dave |
Thread: Thread with steep helix angle? |
13/04/2022 11:14:19 |
Here's another way to make a rope knurl http://www.frets.com/HomeShopTech/Projects/RopeKnurl/ropeknurl.html Dave |
Thread: Help with Excel |
03/04/2022 10:33:28 |
At long last, I have machined the .375" concave radius in the parts that I was making. Thanks to all the suggestions and help offered. Dave |
