Member postings for anchorman
Here is a list of all the postings anchorman has made in our forums. Click on a thread name to jump to the thread.
Thread: Building Stand
27/09/2020 10:22:51
Does anyone know where I can obtain plans for a building stand ,so that I can rotate a 3 1/2" loco easily
Thanks
Thread: scam emails
21/08/2019 15:19:06
I just thought I'd let the forum know of a email scam I've just received supposedly from the BBC licencing department. They say my last direct debit has not gone through and I must set up a new one .They even say that my licence may be cancelled if I do not renew (chance would be a fine thing ) it was sent by someone @columboworld.com (not very original ) and they spelled it License and further down Licence . Just thought I'd let everone aware
Thread: Heavy Lifting
02/04/2018 19:00:01
How do people move and store ,heavy models and equipment around the workshop and into any transport they use for transporting large models .
Thread: Display Cases
15/11/2016 11:16:59
JA
If you visit the web site www.sorashowcases.com it shows the cases far better than I can
regards Anchorman
15/11/2016 10:29:40
I'd like to say from the outset that I have no connection with the following company other than as a satisfied customer .If anyone wants a display case at a resonable price, then I can recommend a German company, Sora-Shop. web site www.sorashowcases.com .I wanted a case to display my Stuart Triple .I sent them the measurements and the web site gives you an instant price including p&p to the UK .It came as a kit about a week later via courier and in less than half an hour was displaying my model on the shelf ,very satisfied .
Thread: Band saw running off true
24/04/2015 11:13:53
I have an old 4 1/2" metal cutting bandsaw which has suddenly started running off true.
I tried to cut a 1/2" square piece of mild steel and noticed that it had cut about 45degrees out of true, does anyone know why this has suddenly started to happen . The blade is tight and the guide rollers are as near to the cut as I can get them .
Thread: boxford model aud
13/06/2013 18:19:12
Thanks for the replies .I think I may have traced it to the segmented belt which may be slipping because I replaced the V belt and the motor always seems to run at the same speed no matter what the spindle speed is.
13/06/2013 18:16:06
Posted by anchorman on 24/02/2013 11:28:59:
I have an old ( around late 60's) Boxford model AUD . All through the winter it has run very slowly , I've put this down to the workshop being very cold overnight and the grease in the headstock slowing things down as it gets thicker . I seem to think the same thing happened last year but can't be sure.could it be the cold, or could it be the motor getting tired . Iv'e tried warming it up ,but with it being such a high mass it dose not seem to work.
24/02/2013 11:28:59
Thread: Doris
20/01/2010 14:23:24
Does anyone know where I can get the instructions for Doris By L.B.S.C.
I know they were published in "Model Engineer " around 1948 but I have never seen a book published for this model
                   Colin Fox
walker midge
JD Metals
