Member postings for keithmart
Here is a list of all the postings keithmart has made in our forums. Click on a thread name to jump to the thread.
Thread: Where do you get raw materials from?
12/11/2016 10:05:36
Hi
I use these:
http://buynow.metalsupermarkets.co.uk/landing-page/?city=leeds&gclid=CNalia_7otACFVUo0wodJvMIrQ
we have a branch in Leeds
Keith
Leeds UK
Thread: how many 'one time' tools do you have?
30/11/2015 08:02:35
Hi
That is interesting as I do the same. Only yesterday I modified a special tool I made some years ago, for a 'one off''
job. I modified it for a similar job, where it was just not quite right.
Yes they are worth hanging on to!
Keith
Leeds UK
Thread: Another band saw blade snapped Have I got the tension wrong.
03/11/2015 10:32:10
Quote: Keith these metal cutting band saws don't have tires
Sorry about that, but is the blade running smoothly within the cast wheel? any lumps and bumps?
Is the blade sitting centrally?
03/11/2015 08:25:44
Hi
Just a final thought, have you checked the state of the tyres on the wheels. If damaged this can cause BIG problems, and tends to be overlooked.
It is a good idea to go through all the settings by the book, not a quick look ' that seems ok'. measure gaps, check free running, watch and listen when running the blade. It is surprisin how much better a bandsaw will work with the right settings!
Good luck
Keith
Leeds UK
01/11/2015 20:54:16
Hi
If it jumps at the weld it suggests the blades you are using are poor quality. The weld should be as smooth as the rest of the blade.
If the blade breaks at the weld,most suppliers will give a free replacement
Keith
Leeds UK
Thread: What angers/upsets you in the Workshop?
15/04/2015 15:33:48
My biggest gripe is that my workshop is not like the Tardis. Ie bigger on the inside!!!!!!!!!
Keith
Leeds uk
Thread: TV Volume control
24/01/2015 13:51:00
Hi
Most tv sets have a headphone socket. Can you persuade her to use headphones. They will mute the tv speakers.
Keith
Leeds UK
Thread: Mini Lathe Owners - how do you fix your lathe? Or not?
22/01/2015 16:27:33
hi
Mine is just sat oh the bench with its rubber feet.
Never had any problems with it in 10 years, I purchased mine second hand, and it is a chester conquest.
I hope that helps
Keith
Leeds UK
Thread: Free Plan: A Simple Lathe
01/10/2014 15:46:29
the link should be:
http://www.model-engineer.co.uk/news/article/free-plan-a-simple-lathe/19501/
regards
Keith
Leeds UK
Thread: Issue 218 will be a bit special...
25/06/2014 16:22:46
Hi
If the magazine is heading that way, perhaps we should drop the word MODEL!
Bending and welding is part of engineering, but relevant to model makers?
Best regards
Keith
Leeds UK
Thread: Tools From the pages of MEW
09/05/2014 19:00:03
Hi
Is there any chance of reprints of these plans?
regards
Keith
Leeds UK
Thread: Infestation
11/01/2014 07:26:01
Hi
For the record I use Opera, and I don't get the problem.
Keith
Leeds UK
Thread: Dimmer Switch
11/11/2013 15:26:05
Hi
I have used a dimmer switch to run an ex sewing machine motor driving a small lathe. I have had no problems, although you wouldn't be able to claim under manufacturers guarantee if it went wrong.
A dimmer switch from screwfix is only about a fiver, so it is worth trying.
Keith
Leeds UK
Thread: Is it just me?
05/09/2013 22:27:38
Hi
I was also dissapointed wth this mag.
One of my gripes is the long, waffling articles over many issues, and other overly simple short articles.
Where is the happy medium we used to hav?
Keith
Leeds UK
Thread: New subscriptions, am I thick or what?
02/08/2013 09:15:07
Hi
[quote]
You have three options now
Digital only
Print only
Print + digital
Where does it say you can have digital only, and how much will it be?
Keith
Leeds UK
Thread: Richard Feynman (Surely you're joking)
19/07/2013 21:33:54
try
http://buffman.net/ebooks/Richard_P_Feynman-Surely_Youre_Joking_Mr_Feynman_v5.pdf
Edited By keithmart on 19/07/2013 21:34:42
Thread: Help required in South/West Yorkshire Area
07/06/2013 22:00:41
Hi
I am in Leeds if it is any help
Keith
Leeds UK
Thread: Taps and Dies
02/06/2013 06:50:23
Hi
I purchased a set of these about 5 years ago. Still going strong, having tapped and died plenty.
http://www.maplin.co.uk/40-piece-tap-and-die-set-30641
Mind you they were only about £17.00 then. Inflation!!
regards
Keith
Leeds UK
Thread: download
25/05/2013 11:27:18
Hi
...... and I use PDFSAM to join them all together again.
That is free as well.
As so many of us are saving the whole magazine, maybe those in authority should think about making it a downloadable file. It is not going to detract much, if any from the profits. After all if you have a paper copy you can still give it away, or sell it!
My twopennorth
regards
Keith
Leeds UK
Thread: A usefull tool?
10/04/2013 10:44:22
Hi
I found this you tube vice, which was apparently done as an april fools trick, but could be a usefull idea.
What does the team think?
regards
Keith
Leeds UK
Rapid RC
Dreweatts
