Here is a list of all the postings Jasper Bower has made in our forums. Click on a thread name to jump to the thread.
Thread: RDG 30VSM-Parts Needed |
26/03/2022 10:47:17 |
Posted by Ian Parkin on 26/03/2022 10:20:29:
Are you sure on the fixed pair of gears? i have a set off a 30vsm spare and they are 31 and 56 and the helical is 39 Having recounted. You are correct! that gearing is what I need. THANK YOU!! |
26/03/2022 10:38:44 |
Hi Ian,
I have messaged you. Thank You |
26/03/2022 10:00:54 |
Having no luck at the moment with gears, I am looking at fitting an AC motor with belt and pulleys. The current DC motor is 1100W, what is the AC equivalent please? Any links to suitable belts? Thank You. |
26/03/2022 09:06:47 |
Posted by Packmule on 25/03/2022 22:22:18:
If you look on thingiverse for G0704 gears there are both spur & helical listed , may fit
Thank you.
23/03/2022 19:53:51 |
Posted by Packmule on 23/03/2022 12:39:44:
Know anyone with a 3d printer ?
Yes, if someone has the .stl files? That would be fantastic
21/03/2022 19:25:23 |
Posted by Ian Parkin on 21/03/2022 14:39:42:
Isn’t a 30 the same as a wm 18? if so i think i have a spare off to look now… Thank You. I do not know! |
21/03/2022 19:24:45 |
Posted by Ian Parkin on 21/03/2022 14:47:06:
Is it a 56 and a 31 tooth? if so i have one The single Large Helical is 39. Large is 56 Fixed to 30 |
21/03/2022 13:37:47 |
Unfortunately no joy. The answer was "we got them from the same places as Warco". |
20/03/2022 17:40:26 |
I have emailed them and await a response. |
20/03/2022 14:04:28 |
Hi, I have an RDG 30VSM which has mashed its gears. Could someone please point me in the direction of where to get replacements, please? Looking at the forum, it seems they are similar to the Warco WM16, but the gearing looks different? Thank You. https://www.ebay.co.uk/itm/113999695630 |
